Tein CS setup...
Old Sep 20, 2004 | 06:41 AM
silv-SC's Avatar
silv-SC
Default Tein CS setup...
What is a good starting setup for this particular system? I am going to have 19" wheels on my car and will be getting everything setup at the same time. My SC430 is my primary vehicle, although I do have a secondary. I am relatively illiterate when it comes to the modification world, so go easy on me.....
Thanks for any advice.
Old Sep 20, 2004 | 07:14 AM
bt430's Avatar
bt430
I had mine setup to drop the car 1 1/2 " front and back. I’m thinking about dropping it a bit more in the front but I want to give this setup a bit more time. It's pretty good over speed bumps but you have to be careful with them as well as in and out of driveways. I've tried setting the dampening every which way but I’ve settled at the Tein suggested of 6 in the front and 10 in the rear. For the roads I’m on and the type of driving I’m doing it seems to be the best. You will want to be able to change the dampening settings so make sure to have your installer drills access holes in the side panels in the trunk so you can get to them. It’s also very important to get the wheels aligned after the system is installed.
BT
Old Sep 21, 2004 | 02:33 AM
rominl's Avatar
rominl
exclusive matchup
try to set the dampening to about 12 clicks away from the stiffest setup, i think that would ba e good start for you to get a taste of what's soft. you shoudl like it. i have CS on my gs4 with 20s, and i run 10 in the back and 8 in the front, no complains from anyone i put in the car at all
RI-Lex
Aug 5, 2009 07:15 PM
Rock-a-Lex
Suspension and Brakes
12
Sep 22, 2007 07:31 AM
YoungP08
Mar 22, 2006 02:33 AM
SharpCreas
Oct 4, 2005 12:52 PM
antbo
Oct 11, 2004 09:34 PM
