wood trim problem
Old Oct 5, 2004 | 08:12 PM
tommy420's Avatar
tommy420
Default wood trim problem
the wood trim around my driver side door is like popping out...it stays in there but is pushed out
hard to explain ill put pics up tomo...i just want to know if this is a common problem that can be fixed easily
also the door lights fall out when ever the door is shut....the driver side one is not bad but the passenger side does it all the time
easy fixes?
Old Oct 5, 2004 | 08:31 PM
Dx3's Avatar
Dx3
Default Re: wood trim problem
easy fixes?
For the lights there is a metal part that is bendable, just bend it out more and it will stay in there. I have had that problem before. Never encountered the wood prob though - good luck,
jonny
Old Oct 5, 2004 | 09:06 PM
B1TEM3's Avatar
B1TEM3
the wood on the driver door panel is secured with nuts. you would need to use screwdriver to take all the bolts of the door panel first. its easy.
take the 2 long bolts out forn the side compartment, its on the midle of the door panel below the arm rest
then take 2 srews from the one near the door hinch.
take the i think is 3 srews on the bottom door panel (i think it was 3)
use the flat screwdriver take the switches console up (you can pry it up, it just hold with 3 clips)
then grab the arm rest then lifts up, the whole door panel is off.
disconnect the harness.
then you can fix the nuts that secure the wood trim. (its most likely just loose)
lastly put everything back on reverse.
Old Oct 5, 2004 | 09:27 PM
tommy420's Avatar
tommy420
much thanks!
will do so in the morning, hmm my magnaflows arrive tomo also
Old Oct 6, 2004 | 01:19 AM
vredniykot's Avatar
vredniykot
Old Oct 6, 2004 | 06:30 AM
MeehSoFly's Avatar
MeehSoFly
easy fixes?
Hey....same shiet happened to me....passenger lights fell out too...now i can't find it.
My driver side door trim fell was out too. When I bought it didn't really noticed it until b4 I got my alarm installed. Seems like the **** i bought my car from a while back didn't know when he took the door apart that there was a screw behind the black cover on the door lever. I've been looking for a new passenger door panel. Right now i just taped it w/ duct tape.
Old Oct 6, 2004 | 07:36 AM
Caanon's Avatar
Caanon
Here's guides to get door panel off: (remember the screw by door handle)
Brief explaination of steps:
http://www.planetsoarer.com/doortrim...rim_Repair.htm
Step by step with pictures:
http://www.carstereohelp.com/stereor...sSC300FSpk.htm
g26
Oct 8, 2010 12:16 AM
EUROJulian
SC400 / 300 Classifieds
Aug 18, 2010 08:27 AM
Rockero28
Feb 2, 2006 02:31 PM
Phoenix88
Jun 4, 2003 09:05 PM
rboorgu
Nov 25, 2001 10:08 PM
