Sponsored by: CARiD
Headlights Question
Old Aug 2, 2008 | 12:53 AM
ARISTO-105's Avatar
ARISTO-105
Default Headlights Question
I have cracked OEM HID headlights and I want to replace them with Sport Design headlights but can not afford the ones with HID. I was wondering if I put aftermarket HIDs, would I lose my autoleveling option. If so, would there be a way to hook up the autoleveling motors to the new headlights???
Old Aug 2, 2008 | 11:25 AM
icantsee's Avatar
icantsee
ARISTO-105...sorry, but Sport Design what? GS, IS, etc?
And I apologize again, but not to sound literally, but did you crack your HID Headlight bulb or Headlight housing?
If it's just a bulb, it's just swap-a-roo "out w/ the old, in w/ the new"
Old Aug 2, 2008 | 12:48 PM
ARISTO-105's Avatar
ARISTO-105
It is for the GS and I cracked the headlight housing and wanted to replace them with non HID headlights with aftermarket HIDs and wondered if I can hook up my autoleveling option from my old headlights.
Old Aug 2, 2008 | 09:58 PM
pingu's Avatar
pingu
I believe auto leveling is only used with hid headlights.
Old Aug 3, 2008 | 03:24 PM
Kyle Harty's Avatar
Kyle Harty
He's wondering if he can transfer the leveling motors to the non-HID housing and make it work. I think the question is do non-HID housings have the mounting bracket or space for the motors?
I haven't really looked at non-HID housings and haven't opened up my stock HID housings yet, but if the non-HID housing has the mounting points for the motor, I don't see why you couldn't transfer the motors and reflector bowls from your HID's into a non-HID light; as long as the adjustment pins line up as well and I'd assume they would. I'm assuming the non-HID bowls don't have the slot or pin to attach to the leveling motor so you'd have to swap the HID bowls as well. That's better anyway if you're going to that much trouble, that way you could still use your current HID bulbs and have a better beam pattern than a kit in halogen reflectors.
You could also do a retrofit since you're tearing everything apart anyway.
Pivo154
Apr 21, 2014 03:35 AM
TruPlaya26
Sep 19, 2012 11:40 AM
scooter58
Lighting
Mar 13, 2008 05:08 PM
DrewGS350
Aug 27, 2005 10:29 PM
