ignition coil 1
My 1992 sc400 would not start today. I removed the spark plug wire running to the ignition coil 1 and the car started. I noticed that the ignition coil was fireing off intermittedly. Help I think the last time this happen I removed the ignition coil 2 and the car started help
Any updates on this? I too am facing intermittent starting issues... Starter replaced, as well as battery, and wires from battery to starter/alt. about 6 months ago. Weird problem... Car ALWAYS starts on first try, even before replacing said parts... Problem is if I turn engine off within 5 minutes of starting, it won't restart. I may hear a subtle click, but the starter won't engage. I've tried wiggling coil wire, and sometimes that is enough to get the starter engaged again, sometimes not. I've tried placing key to the engine on position, and tapping brake, as well as moving gear selector from drive to park several times. Sometimes this will allow starter to engage again after placing in Park position? Battery checked and is holding 12.6V after allowing to sit for 6 hours+. I've also tried jumping from another battery when this happens to no avail... Especially weird, as car will restart again after letting it sit for 45 minutes or so...
Car is a '93 SC400 with 150k miles...
Any helpful suggestions would be appreciated. Perhaps replacing coli or coil wires? Is there some type of relay or sensor that tells when the car is in N or Park that might be faulty?
ltran82
Jul 25, 2012 05:24 AM
meanboy
Apr 22, 2008 02:22 PM
