(RX300) VSC Problem
Old Aug 5, 2011 | 06:34 PM
kennethc's Avatar
kennethc
Default (RX300) VSC Problem
I have a 2003 RX300 and I recently changed the air/fuel sensors, the CEL turned off, but the VSC and Trac Off light remains on. They remain off when I start my truck but when I put it in drive they come back on. Does anyone know how to troubleshoot this issuse or what the problem might be?
Thanks
Old Aug 5, 2011 | 09:04 PM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
Thanks
the VSC and Trac lights generally have nothing to do with the O2 sensor / AFR sensors, though they can come on because the check engine light is on...
so, if the check engine light is cleared and the VSC/Trac lights are still on, then you may have another problem, if all 3 remain on, you might still have the same issue...
There is also a possibility that you are suffering from the same issue many Highlander and other VSC enabled Toyotas suffer from, essentially requiring a calibration of the VSC computer and nothing more... here's a link, I recommend reading through it carefully, then downloading the PDF with the procedure... http://us.lexusownersclub.com/forums...howtopic=49724
Old Aug 5, 2011 | 09:30 PM
GS4_Fiend's Avatar
GS4_Fiend
Good find. Learned something new.
Old Aug 8, 2011 | 11:20 PM
kennethc's Avatar
kennethc
Default Procedure for VSC/Trac Light Reset
Hello, I appreciate your help! I clicked on the link you provided for the procedure on how to fix the VSC/Trac light problem, but I did not find the procedure. Can you please refer to a link that can help me?
Old Aug 9, 2011 | 04:38 AM
mitsuguy's Avatar
mitsuguy
Um, I just went back and reread that forum posting and there a few different desctiptions as well as pictures...
You can lead a horse to water, but.....
Old Aug 15, 2011 | 09:08 PM
kennethc's Avatar
kennethc
Default VSC/Trac Light Problem Fix
Thanks again! The horse drank the water... I found the link and fixed the problem in under 10mins. You saved me alot of money by just using a paper clip.
Old Feb 20, 2013 | 06:42 PM
KeyKeeper's Avatar
KeyKeeper
I need to do zero point but cannot locate the correct terminals on the obd connector. There appears to only be 3 or 4 terminals and they do not match any of the pics ive seen on the net or here. I know this is old thread but this vsc light is driving me bonkers.car is a 98 gs300.
Old Feb 21, 2013 | 10:33 AM
KeyKeeper's Avatar
KeyKeeper
Well after scouring the internet and this forum I think I may have a solution. Found this thread and going to check some things this weekend. I bought this car used and it appears to have the original alternator on it. 200,000+ miles. Last night I had run down to the corner store and my batt light illuminated at idle. A little throttle and it went away. I also hear a whining noise in the rear speakers. Im thinking the alternator is bad.
Derrick H.
Old Feb 22, 2013 | 05:45 AM
KeyKeeper's Avatar
KeyKeeper
13.2v at idle with nothing on. 9.8v idle with AC/WIPERS/STEREO/HEADLAMPS on, rev motor a little bit and I get maybe 10.5v.........yeah, alternator is on its last leg...
Jeckel30
GX - 1st Gen (2003-2009)
May 29, 2017 03:25 PM
randr
RX - 1st Gen (1999-2003)
Aug 18, 2014 09:26 AM
chico55
May 15, 2014 08:24 PM
FinLIFE
Apr 9, 2010 05:01 PM
HGill
Jun 15, 2007 10:28 PM
