- IUZ-fe obd2 ECU and state inspection?
- 1uzfe - plastic covers or no plastic covers
- anyone knows how to hook up a hks FCD for an aristo ecu?
- Anyone has the Diagram to Hook up a VPC
- Hints on removing P. Steering solenoid screen
- How do you remove the torque converter?
- auto to manual
- fuel line question
- Self made flamethrower
- intake plenum removal
- 2jzgte swap
- any cures for heat from trans tunnel
- trouble removeing intake mani y-pipe
- ...need help setting timing...
- Terrible Start-Ups Cold.
- Powering Steering Pump
- Tailshaft question, need a quick answer
- LS400 Upgrade help
- 1uz-fe throttle response.
- W58 rubber boot?
- K&N Filters
- question about big thorttle body on stock electronics
- STILL horrible acceleration and Stalling 93 auto
- 2jzgte vvti with GT3582R
- Help!!!help!!! White smoke!!!!!
- Parasitic Draw Draining Battery
- P.S. PUMP questions for 1jz swap!!!!!
- Looking to get a 1JZ t67 sc300...just a few questions..
- EGR block off plates?
- Car putts,radio turns off when I hit turn signal?
- where did you mount your FMIC to?
- 93 SC400 Serpentine belt /Tensioner issue
- Help! Bad ECU or Bad wiring? New swap
- Change of plan going na-t now
- Injector CC to large?
- BFI versus Injen cold intake
- question ecu swap?
- Oil change questions
- MAYBE 260 miles on a tank of gas
- Harsh auto shifting after na-t
- What's the best air filter and oil filter for the SC400? What oil you running?
- New rad, thermo, cap; not working out.
- I need help, I have a big question that I need info on. 5 speed swap.
- 1uz vvti intake question
- Reverse Lockout on Stock 5 Speed?
- IS 98 GE motor with VVT-i interference?
- Got any tips, going to change all SC400 coolant hoses ?
- trans prolbem
- This + This = :)
- sc300 starter question
- Installed the BFI kit
- Please confirm my idea about my misfire!
- Sc300 Troubles Dyes out at very low throttle and extreme hesitation HELP
- battery light on
- Need Help: How to read codes in 95 SC400
- Sudden rich condition out of nowhere
- '97 SC300 Repair Estimate: All New O2 Sensors & ONE Catalytic Convertor
- squealing noise when the AC is on
- Quick engine swap question
- quick mock up, what do you think?
- are the piston rings for a 95 sc300 the same measurements as a 93-97 supra??
- how to increase idle speed?
- Somebody help! Please!
- supra coolant line on 2jzgte swap
- Help after rebuilt engine wont start!!!
- r154 driveshaft?
- Couple motor issues, need help diagnosing
- 97 SC400 new serpentine belt not in "target" zone....
- Damn injectors!!!
- sc300 pedels into a soarer?
- Transmission Oil Service
- 1jz Intercooler options?
- Shifter question: w58 into 92 SC300
- 1jzgte Engine Harness
- fitting a getrag 6 speed into a 1993 5 speed tunnel
- Need Help! Clunk Sound on Front Brakes
- what does this control on the v8
- AEM UEGO install question
- Help!!! Could this be the timing belt?
- HKS Speed Cut Defencer?
- sc turbo?
- Are the axle-back exhausts for the SC400 a piece of garbage?
- Ahh, car is acting up again..
- almost done turbo build
- Map-ecu sc300
- SC300 Crankcase Vent Air Filter
- squeaky clutch pedal
- need some help here.
- HELP!!!! sc400 not shifting right
- broken bolt
- Well, its official... Thank you Scott and zach
- Need Help Car wants to stall at very low throttle
- cold start knock knock
- Which factory seats direct bolt in to a Sc300/400
- What is the thread size on the fuel tank?
- No heat?
- now that i removed my hardlines...
- Need help with my SC300's additional injectors
- yet another SEAFOAM question need help
- check engine bulb blown
- please help, R154 transmission
- Power Steering, AC
- "Need a quick answere" slave cylinder r154
- dynotune afr gauge?
- Help me out on this for sc400
- Will this downpipe/Y-pipe work for my 1J SC?
- Another LSD ?
- CEL code42 2JZGTE
- vacuum lines
- SC300 wont go past 4000rpm
- 2jz swap question NEED some help.
- 95 MAF to clean or not to clean
- Have a question...about injectors
- Question about Intake
- Tire pressure Question regarding handling
- Engine shuts off when hot
- crank pulley came off .. how?
- Why does this engine take so long to start?
- Is there an easy way to remove the IACV (idle air control valve) on the 1JZGTE motor?
- Removing heat shield?
- Mobile One v Castrol Edge
- please help
- Anyone Doing 1jz or 2jz swaps in michigan
- Radiator of cooling of engine oil on SC 300
- Problem wont end, multiple codes HELP!
- IMF headers
- 3:27 rear end ratio with w58
- Anyone who drilled oil return NA-T
- Maximum horsepower possible through stock SC mufflers?
- engine code
- Ecu plug help
- HELP ASAP! Do I Need A Manual ECU?
- SC300 Removing Cats: Gas smell, HP Increase, Sound Change?
- nitrous setup
- Exhaust and Suspension questions
- top feed fuel rail install
- Got Parts
- The 1 year plan Teaser- 1uzfe meet Holset
- Help! runs rough then stalls after starting
- Exhaust Flanges
- confused
- Union bolt/Gasket
- Diy bfi
- Catalytic Converter Cut, Need HELP!
- sc300 ge build
- SC400 2jz swap "with pics
- reputable repair services
- diagnostic question
- SC400 W58 Install thread(Parts thread now progress thread in a few weeks)
- Supra Engine into SC300 questions..
- 1UZ-FE Cams
- How to put NOS on a SC300 VVTi?
- 2jzgte swap questions
- Where is this motor from.. JDM 2jz lol
- Need Help!!!! (Electrical Problem)
- drivetrain problems
- Rough running 400 and super hot cat!
- Things to Check for Proper Gas MPG
- aristo 2jz-gte swap into sc300
- Is it me only...
- 2jzgte swap into 92 sc300
- SC400 Single Exhaust Pipe Diameter
- ANYONE W/ a 97 SC 5speed. NEED HELP!
- speed cut install help !!!!!!
- EGR delete questiong (with pics)
- 1jz swap + a/c issues + missing plug to a/c fan
- 5Zigen's on my '99 SC400
- rear seat weight
- CEL code 25 - VCG???
- idle drop with a/c on
- Pulling my 1uz-fe out of the SC400
- sc 400 questions?
- Cams leaking
- R154 into a soarer?
- HELP! Car wont start after trying to fix it!!
- ruff idle on a sc400
- Drive Shaft Linkage to Diff...
- Sounds like a new engine would be better
- New Header Idea....Do Want....
- A/C freon leaked out after 2JZ-GTE swap?
- Can you put a 01 is300 vvti motor in a 1992 sc300(non- vvti)
- What part is this ?!
- Excessive engine drag/deceleration
- IS 300 supercharger
- Oil change and Lucas oil questions
- Once you go 1JZ..
- Urgent help- 93 sc400 computer and camshaft power sensor
- 1993c300 dash lights
- Catalytic converter question
- Tachometer problem with J-spec 2JZGTE
- What is the diameter of the stock exhaust piping?
- Do All JDM Motors Have Sludge Issues?
- Aftermarket A/C condenser??
- should I (Convert Auto to Manual Trans)
- SC400 Power under 2800-3000
- Aristo 2jzgte into 1998 sc300
- Clutch creaking when pressing in?
- Help!! Wtf? (Actually means) Post Seafoam engine problems
- Alternator Plug ReWiring
- OK Now I Got A W58 ?? Whats the difference
- timing belt replacement
- Greddy Mx exhaust vid
- time to swap?
- The Strangest Problem...Dirty Injectors
- seafoaming?
- Underhood pic of 95 SC400 request
- Mobil 1 - How often?
- R154 on a 2JZGTE
- A Few Maintenance Questions & R154??
- Leaky rear main seal, temp fixes?
- Poor performance 96 sc300
- Starter Clicking *OPTIONS*
- 95+ W58 shifter HELP
- Sudden power loss..NOT the ignition coils.
- Hks turbo timer harness for sc300
- Clutch recomendation?
- quick spark plug question
- 97 SC300 Auto to Manual conversion - Who's done it?
- 1JZ issues any kind of thoughts and inputs welcome
- A/c gets cold slowly
- 1JZ Wiring Extending.. what gauge wire?
- Having TPS problems (just replaced with 90k service)
- High performance CAMS from TTC performance for NA
- Will an is300 turbo kit fit the sc300?
- Drilled oil retrun drain hole? help
- 4runner distri. cAP ON SC300???
- Conversion Automatic to Manual
- Weird accelerator noise...
- fuel pump upgrade??? please help
- broken mirror rotors or broken switch??
- New Exhaust Sound Clip
- MidMount Intercooler/ intercooler options?
- Fuel Pump Collecting Alcohol?
- 1jz radiator replacement?
- SC400 engine noise question
- Inspection Nightmare - Should I scrap my headers?
- HELP! Battery or alternator bad?
- Why don't more people rock this?
- **VIDEO** SC400 w/ 5Zigen Fireball Mega Exhaust
- upgrading my stock 4-speed (a340)
- Clutch pedal bushing
- Stock auto trans
- S&S Headers on 1998 sc400
- High pitched squeal in first gear high rpm
- Swaping internals between 1jz and 2jz?
- Tuning Shop
- 2002 SC430- Haunted?
- ECU for manual conversion
- New GTE Swap prob..warm idle rough and now it won't start
