View Full Version : Performance
- jdm exhaust will it fit?
- GS300 exhaust/header/hp upgrade final answers
- What is Faster?? Gs3-T or Gs4xx
- Fi/c vs. F10x
- Relearning!!!!
- Injen/Fujita CAI
- cold air intake
- Turbo question
- Tossing some ideas around... lets BS a little
- anyone know what CC are the stock GS400 injectors?
- About to pick up a 2jzgte vvti, please give some advice!
- my dyno day
- JDM 2JZ-GTE VVT-I Bottom End
- Are GS300 and GS400 torque converters the same?
- Best Spark Plugs for the GS 300
- what is the averge gas mileage for gs300 on regular and premium gas
- Cold air intake . . .
- Limited Slip?
- Throttle position sensor??
- 1uzfe vs 1uzfe vvti and trd supercharger questions.
- Throttle body cleaning...revisited
- Building a custom exhaust in the garage...
- fujita intake install car problem
- My GS gets Caged!
- Best Recommendation for exhaust system?
- !st purchase!!! vvti easy or not?
- Injectors & AEM FIC
- 2jz gte vvti 2001(Aristo engine) with r154 swap
- Non VVTI GE motor into a 2nd gen possible, VVTI, and management questions
- Apexi-Neo Tuned and Dynoed Today 3/6/09
- Missfire but no CEL code??
- Junction Produce Type III Exhaust Installed
- 5Zigen exhaust clip
- RMM SC rebuilding?
- Exhaust tip color...
- is a lsd worth buying right now for a gs3 w/ no turbo?
- Anyone have any experience with Xylene?
- Mtparker18's turbo build thread
- 2001 2JZGTE VVTI injector size...
- Boosted GS for sale-impossible to find?
- Aristo Torsen LSD fit a GS4 rear end?
- Turbo GS300 owners, MAF or JDM ECU?
- Import Tuner Magazine - GS400 Bolt Ons (Dyno Results Included)
- transmission whines when cold????
- Dyno Result (01 GS430): SRT intake w/Race ECU
- 2JZ-VVTi timing problem.....
- power gained with an srt intake???????
- Engine Management Question
- 99gs300 na-t with FI/C
- Slow start up?
- real quick question.. help!!!
- gs430
- firewall?????
- Camcon with Haltech ???
- Cam Gear
- JDM GTE guys, how many dropped strait in?
- Here's a question...
- downPipe to exhuast
- O2's are killing me
- k&n drop in filter
- rotors
- i want to make my 2000 gs300 faster!
- Basline dyno: Bone stock GS300
- standalone
- I need help withe my HKs SLD (Speed Limit Defencer) for my GS430
- FI/C help!!!
- Intake pipe source?
- rpm limit questions
- Tanabe SMT
- HKS Hi-Power Exhaust on Gs400/Gs430 sound request
- NA-T CEL Tune
- OBX headers for GS 300? Input please
- fic and wideband!
- When a single turbo just doesn't cut it anymore....
- intake sensors?
- tranny slip?
- help with SRT intake for GS430
- what turbo's are you GS's using?
- Will the '98-'00 SRT intake fit an '01+ GS 300?
- Nitrous and Meth inj.
- k&n cold air intake ?
- aem fic -8 install!
- NA-T 2JZ-GE GS300s, anyone running meth?
- 4-speed supra auto into GS3
- Dying
- 300 vs 400 exhaust question
- Is the JZS161 Aristo diff the same or no?
- GTE intake mani questions.
- SRT Air Intake + ECU
- Quick preview of new Turbo install..
- Pulled the fenders and have a new stance and new exhaust
- Will a LSD from a JDM Toyota Soarer fit the GS4?
- DIY Intake for GS300
- Injectors?
- GS4 track car build gets underway, 2jz, V160
- Turbo gs400..check it out
- Help me choose exhaust!
- Ffim???????
- Project SleepSter: Let's get to it.
- Tranny project????
- GS300 and AEM FIC Install
- P1349 VVT System Malfunction (Bank 1b) blocked oil control valve filter
- Which Intake Is Best?!?
- Pix please !
- F'it illegal turbo here i come
- Life expectancy of aftermarket exhaust
- Whiny 2GS in the extreme cold
- Turbo kit or aristo swap is the question?
- needs help plz!!!!!
- non vvti gte in 2nd gen gs
- smoking turbo and other problems
- Poor gas mileage!
- PIC request! RMM rear bumper w/any Tanabe exhaust
- Need some help with tuning car, didnt go as planned today on the dyno
- Oil on spark plugs?
- K&N FIPK replacement air filter = Amsoil's EaAU3560
- Junction Produce Exhaust Type 3
- Possible EZ 15-20 + hp increase 4.0 V8 ?
- Good places or Supra forums to try and find an auto 3.76 rear diff
- Engine source
- Oil type
- WaterPump/Thermostat/coolant flush
- help with a part list(94supra motor in a gs300)
- Getting close to turbo swap - few questions before I do
- Crank Pulley/Damper Weight- HELP ??? 1Uz or 3 Uz
- Chrome finish exhaust
- GS300 twinturbo install
- Who all has a turbo Gs3?
- I have 2 problems withe my Gs430 "04
- exhaust fitment
- Will these IS300 parts fit?
- Bad experience with ordering intake from Swift Racing
- new to changing spark plugs
- 98 GS400 exhaust manifolds/new engine
- What do you guys think of the hks hi-power
- AEM Dryflow Filter fitment with SRT intake on gs300
- Sneak peak: Y-Pipe anyone :) ... Little something from the shop
- Stock intake pipe where maf is hooked up 2.25" is that correct?
- Srt intake..filter replacement
- Update, got SS Headers installed!
- Apexi NEO wiring diagram help please
- NeeD MoRE PoWER !!!!!
- Finally made the damn install appointment!
- rc injectors
- Does anyone or has anyone ran the SRT intake and an Apexi Neo or something similar?
- Intake manifolds
- 1 month and still no turbo
- Any Interest in a K&N Intake for 01-05 GS300?
- 01-05 Fujita Intake
- Pinging
- Im sure its been asked and I searched for 30 mins but...
- Got my 02 GS430 dynoed today
- Freed up about 2 more hp
- BUILT tranny
- When is the best time to tune?
- Cam Gears and Pulleys
- Wastegate spring question
- 2jzgte head gasket
- AEM FI/C Questions
- Is Royal Purple Max Gear O.K. to use in the Supra 3.76 LSD?
- My turbo was stolen!!!!!!!!!!!
- Dynoed my 02' gs 430
- Cooling Fan After Key is removed?
- Help ! Great Confusion with my Exhaust sensor.. HELP !
- SS Headers input, question
- How many and where are the cats on a GS400?
- What should I do next????
- Gas Brand
- IS/GS Interchangeable Drivetrain?
- Anyone know the diameter of the Carson Tuned cat-back exhaust?
- original ECU wiring diagram for the gs430 2002 needed
- The ULTIMATE Turbo Q&A Thread!
- 4.7l tundra swap
- Turbo timers
- turbo
- Turbo....any good?
- Our Transmission (GS3)
- I have an extra Gen V M90 sitting around?!
- Has anyone seen this
- SUPER good deal on SRT intake + Ecu until 11/01
- anyone know the pro/cons of doing a "1.5" 2jz swap
- Tanabe Touring GS300
- Has anyone done Nitrous on their GS4?
- I know this is a long shot...but...
- 2jzgte?
- What piggy back????
- Exhaust system
- The over played topic: best performance options (intake combo)...
- another turbo question...
- turob questions
- Can our cars adapt to race gas/higher octane fuels and take advantage of them?
- *Help! I need instructions for Gs400 SRT Intake*
- What kind of diff fluid are you guys using for the RMM (Supra) LSD?
- Injen 2000 GS300 intake
- Squires Turbo Systems (STS) - has anyone heard of this
- Quotes for Work
- transmission upgrade''
- Your Assistance Needed, Magnaflo Vs (your favorite pre-built setup)
- Any Feedback on these guys?
- Axle Back Exhaust... removing one...
- Whats wrong with $600 ebay turbo kits?
- Help!!! Need 99 gs3 ecu pinout
- JP exhaust type III pics?
- CA laws on Nitrous?
- Searched a ton, please describe the chanes other than off the line w/ aftermarket TC
- Weapon R intake.
- Question for you Engine Gurus'!
- Problem with TANABE Exhaust hitting rear bumper
- Meth injection...
- went to the local drag strip
- Voltage systems/Grounding kits...any experiences?
- What do you guys think about this swap?
- Gs3 transmission
- Anyone running a Lextreme rebuilt torque converter, what stall speed?
- 98 GS300 Turbo Exhaust Suggestions
- How much HP can a slightly modded tranny hold?
- GS300 Intake question
- 8 Rwhp For $600
- i have a 2000 gs and i want an intake!
- resonators
- Haha, hate to keep asking so many questions BUT
- S&S Headers question
- 1UZFE Idle Air Controller Location?
- Is it possible?
- carson B pipe and hks hi power
- Looking for digital pictures of installed SRT Intake on GS300
- GS 430 turbo?
- More bling bling for the engine bay....
- gs300 turbo swap
- anyone want a short-ram intake? uber-cheap...
- GS stalled while driving
- ADAMGAMZ! JEFFTSAI! this one's for you guys...
- Help Me Please!
- Apexi WS2
- S&S Headers Update - No cracking on current design
- Can Someone Please Post Up Sound Clips Of Different Gs300 Exhaust?
- Aristo 2jzgte vvti ECU
- gs400 and 125 shot of ....
- Any known problems using Amsoil ATF Tranny fluid???
- Tanabe exhaust systems
- redline limit on built engine
- Launch.
- Gas Mileage Down The Drain
- Mufflers
- What Do You Think Of The 5zigen....
- Tm Vs Hm
- Torque Converters
- Driver Side Floor wet any suggestions
