GS300 twinturbo install
Old Dec 24, 2008 | 04:18 PM
GS300NL's Avatar
GS300NL
Default GS300 twinturbo install
is there anyone that installed a twin turbo from a Supra on a 2 gen GS300
Can somebody tell me what to do with the ECU do i have to reprograme or install a piggyback computer,or is a Vortech FMU and a fuelpomp enough for this setup I want to drive the boost max 0,4 bar.
I just bought a manifold incl the two turbo's and oil lines .
Old Dec 24, 2008 | 06:40 PM
jcat_350's Avatar
jcat_350
that's an interesting question....i think most people just either swap the GTE or go NA-T. If you don't mind my asking, how much did your setup run you? I would guess you could run a piggyback similar to NA-T but i'm not the expert.
Old Dec 24, 2008 | 07:11 PM
status....'s Avatar
status....
the way the manfold flange on the tt is different on the ge
Old Dec 24, 2008 | 09:45 PM
macd7919's Avatar
macd7919
Sorry to break the news but the Supra manifold won't fit on the Gs300 engine (non-gte 2jz). You should look into just buying a single turbo manifold and installing a small turbo like a 61mm etc....
As far as fuel you will need an upgraded pump, (walbro 255 for example) as well as larger injectors (the Gs injectors are tiny) and someway to control fuel, at the very very least an Apexi AFC but preferably a Haltech F10x.
Old Dec 25, 2008 | 02:28 AM
ErickGS300's Avatar
ErickGS300
What's the diffence then between a 2jz-GE and a 2jz-GTE?? Is there a big diffence??
Old Dec 26, 2008 | 05:13 AM
1fastlex's Avatar
1fastlex
well theres a lot a of differences betwen these two motors .....the turbo block has oil squirters in them lower compression pistons con rods....but if youre asking about the exhaust manifold fitment they would not interchange because of the differences in bolt pattern and ports not lining up ...........do u have any pics of the manifold??
Old Dec 27, 2008 | 09:04 PM
jriggs's Avatar
jriggs
a while ago i tried to have an old tt manifold with turbos mounted up on the gs300, it became apparent it was going to be a pia. i highly suggest going single on the vvti ge motor. i'm was running 8lbs daily on a fairly cheap set up and loved it but my tune some how dropped out of the system and it's going back to na for a while till i have time to chase down gremlins. the cost of making the tt work would have countered the saving on parts factor
Old Dec 27, 2008 | 10:21 PM
fordsvtmfl's Avatar
fordsvtmfl
http://straightlinespecialties.com/s...cPath=29_35_54
this shows the difference in the bolt patterns...
Old Dec 27, 2008 | 10:22 PM
fordsvtmfl's Avatar
fordsvtmfl
i wonder why toyota did that...
Old Dec 27, 2008 | 11:07 PM
jriggs's Avatar
jriggs
it's so simple it make you spit
to make it not work
you have to remember manufacturers make a profit of anything sold
Old Dec 28, 2008 | 02:57 AM
ErickGS300's Avatar
ErickGS300
Now i see. That's way different.
TheMadGS3
Dec 3, 2013 10:26 AM
eschristen
Performance
Mar 29, 2010 10:25 AM
blaznsc4
Performance
Nov 10, 2007 07:56 AM
BUSTN
Performance
17
Dec 30, 2006 08:54 AM
Xthread
Performance
Oct 7, 2006 08:32 PM
