S&S Headers Update - No cracking on current design
Old Sep 25, 2008 | 09:04 AM
JBrady's Avatar
JBrady
Default S&S Headers Update - No cracking on current design
I just spoke with S&S Headers owner/designer Mr. Loren Barnes.
There has been NO reported failures/cracking of the current Lexus V8 headers.
The first run of headers, aproximately 30 sets, tended to have tubing cracks develop after several thousand miles of use. This resulted in S&S changing both the steel tubing thickness and welding pattern.
Original tubing thickness was 16 gauge = 0.065 inch tubing wall thickness
Upgrade/current design is 14 gauge = 0.083 inch tubing wall thickness
This is an increase in tubing thickness of 28%
Old Sep 25, 2008 | 12:43 PM
ZippyGuy's Avatar
ZippyGuy
Is Mr. Barnes going to have a limited run of 14 gauge on headers for both the GS300, 430, and 400 or only one of the listed?
If he decides to build one for the GS300 feel free to have him contact me. The only header on the market now is OBX, another choice would be welcomed.
Old Sep 27, 2008 | 09:44 AM
JBrady's Avatar
JBrady
I believe the V8 headers are in stock. 14 gauge is the current spec. These are a direct bolt in fit for all GS400, GS430 as well as 2001-2005 SC430 and LS430. Fitment on the 2006 and newer cars using the 3uzfe may be good as well. They also bolt on to all other 1uzfe, 2uzfe and 3uzfe engines but will require some changes to fit to the remainder of the exhaust and EGR connections on vehicles so equiped.
For the 2JZ-GE I like the Mazzuri Super. Although built for the IS300 it should be workable for the GS300. The primary size is better suited for the powerband than I believe the OBX is and the use of merge collectors that much better.
http://www.mazzurisuper.com/shop/htm...eaders/45.html
Old Sep 27, 2008 | 10:49 AM
aquanuke's Avatar
aquanuke
Ive had mine for about 5 months now and no problems.
Old Sep 29, 2008 | 08:32 PM
slowdiver's Avatar
slowdiver
jb....thanks for the update.
I have been out of the loop for awhile and logged in tonight just to get an update on the 2nd batch of S&S headers.
I'm currently on my 3rd re-weld with the original batch and have experienced another crack.
I wonder if S&S will give me some sort of discount on another set.
Anyone have Loren's direct email address?
Old Oct 1, 2008 | 08:16 AM
JBrady's Avatar
JBrady
PM on email sent.
Loren and S&S have made every effort to resolve all customer problems.
Let the forum know what happens.
Old Oct 4, 2008 | 04:48 PM
chuckb's Avatar
chuckb
I hope to hear they have held up after a year or so. maybe down the road I'll get them once I know the bugs are worked out.
do they bolt right up where the stock manifolds do now? no other exhaust changes necessary? I'm guessing the car will still be quiet with otherwise stock exhaust?
Old Oct 4, 2008 | 06:13 PM
JBrady's Avatar
JBrady
If that makes you comfortable. I would prefer to enjoy the car more for a year. The toughest part of the install is removing the stock manifolds due to the heat shields. The easiest vehicle is the GS430. Once the headers are in if they need to be removed it is MUCH easier since there are no heat sheilds.
Yes, they bolt right in. I actually recommend keeping the stock exhaust. Car sound is not noticeable. Maybe very slightly more noise at full acceleration since you are making more power.
Old Oct 4, 2008 | 06:48 PM
chuckb's Avatar
chuckb
I just wouldn't want to deal with an exhaust leak, at all. that would be a pain for me and my wallet. I am pretty good at diy, but I doubt I'd tackle this. don't you have to loosen motor mounts and raise engine a little to remove the stock manifolds?
also, with stock exhaust will I lose any low end power with the headers?
thanks jbrady, I know most of this has been discussed before, but I'm just now starting to look at this seriously since they seem to have the cracking issues worked out.
Old Oct 5, 2008 | 08:55 AM
JBrady's Avatar
JBrady
The 430 cars have single tube stock manifolds vs dual tube on GS400s. This makes the stock assembly smaller and much easier to get to the bolts. Pearlpower installed on his SC430 (same stock manifold as GS430) in 4.5 hours with a lunch break. He is a highly experience auto tech with many tools and estimates the average guy would take 6-7 hours.
Read his entire very informative post here:
https://www.clublexus.com/forums/sho...headers&page=3
Specific install post
https://www.clublexus.com/forums/sho...9&postcount=37
Here are a couple of quotes that may help with your questions.
Originally Posted by Pearlpower
OK, everything is in and complete. I took my time, yet still managed to complete around 4.5 hours or so with lunch and breaks in between. Figure 5 hrs for your average Lexus mechanic if you take it in. Keep in mind that Lexus books the manifold install to include removing the engine which is completely not necessary. I also have many years experience with working on cars and have more tools than your Lexus dealer tech minus the lifts and Lexus scanner so the average Joe is going to take much longer. Perhaps as long as 6-7 hours even with the right tools.
Performance: There is without question a performance increase throughout the entire range and not just up top. The car no longer feels held back and instead launches forward and duplicates the feat in 2nd and still pulls hard into and through 3rd. I would rather not guestimate as to how much HP/TQ is gained and I am too tired to get the G-Tech out and install it but this car is much quicker and acceleration is very smooth or jolting depending on what your asking for.
Put another way ,I am feeling quicker acceleration with the headers than with the SRT intake install. Could be that the exhaust, intake, and headers are working in concert to obtain these results.
Part throttle acceleration is much better and the power/tq increase can be felt from just off idle straight to redline regardless of where the throttle is. This is more than I expected.
Old Oct 5, 2008 | 03:02 PM
GS FONZy's Avatar
GS FONZy
I didn't have to raise my engine on my 400, but I did have to modify a wrench to get to the middle bolt on the driver's side manifold. I think it took about 4 or 5hrs, but half of that time was removing that one bolt and ripping the heat shields out, oh yeah and letting the car cool down
Old Mar 7, 2009 | 11:29 AM
sam430's Avatar
sam430
So...no failure yet? GS GONZy... did you get to keep your heat shield or did you have to remove it? I would like to tip the installer of what to expect.
Old Mar 8, 2009 | 11:01 AM
JBrady's Avatar
JBrady
The 430 heat shields will not fit the S&S headers. The GS400 shields fit but their is no provision for attaching them. The headers are designed to be used without the shields. It would be possible to weld brackets on the headers to accept the bolts from the 400s shields but I am unaware of anyone doing so yet.
Old Mar 8, 2009 | 11:06 AM
LiCelsior's Avatar
LiCelsior
Retired
CL Folding 500,000
this is a good update! i wish i could do this but there is very little clearance in the 1gen LS400 so doing it myself is going to be tough.
Old Mar 8, 2009 | 06:20 PM
sam430's Avatar
sam430
I'm sure it's a no or I don't know answer but... Can I purchase the heat shield of a gs400 and use it on the GS430 (after SS)?
