View Full Version : Performance
- Manifold removal
- stock tip removal
- bout air filiters....
- ****removing stock exhaust tip****
- Swap Stock for Greedy PE exhaust???
- Serpentine belt problem?
- what do you guys think about this Front/center pipe?
- Borla exhaust tip
- ThrottleBody ByPass: Done
- is GS430 header same as LS430's??
- HELP - Throttle Body By Pass
- GS300 inquiry
- Help starter
- cheap way to do what you want
- 1/4 run with the SRT twin turbo GS400
- Cleaning the SRT filter?
- Supercharger kits.
- O2 Sensor
- 300/430 Exhaust System Diferences
- Cs55, Na 380 Hp!
- looking for a synthetic tranny fluid.
- What will it take to get a GS400 in the 13s w/o F/I?
- 2nd Gen. GS300 twin turbo. Who's is it?
- Hey guys, what exhaust system is this? Thanks =)
- 1995 GS300 engine/ecu/harness
- Anybody in the Bay Area
- My Blitz adapter
- Which LSD for GS300?
- *need expert's help....what kinda Diff oil i need for the SUPRA 3.76 LSD???*
- ***Firment Problems with Borla Exhaust***
- manual tranny conv. possible on gs400?
- Installed LSD last night REVIEW
- Twin Turbo GS400 Dyno Specs
- Bouncing idle with SRT intake
- Does the piggyback ecu from SRT make a big difference?
- Is there a fix for low idle?
- Torque Converter Question
- Oil Consumption
- Finally took some pics of the GS and Turbo
- replacement filter
- transmission lag
- TTE Quad Exhaust
- ATS Carbon LSD and PI TC Install, At Last!
- coldair intakes
- Twin Turbo vs. Single Turbo.
- Prolex intake
- Manualy advancing timing: does it work?
- Something wrong with SRT intakes?
- Drooping Tip!
- Gs400 engine
- Borla Exhaust
- greddy evo exhaust
- Low Idle Investigation
- RMM exaust question
- Tanabe HM Owners in So Cal?
- Cam gear??
- lsd ? how do i test
- HELP, Im having tranny issues..I think!!!
- Another exhaust questions
- Louder OEM exhaust
- ***Most quiet aftermarket exhaust?***
- whats the highest possible NA HP for GS430?
- computer chip
- sparkplugs gs400
- wis there a 2jzgte vvti engine for the gs
- Spark plug replacement
- Netz Sport exhaust question
- Engine Ticking
- HKS, APEXi or TANABE?
- E-shifty
- comparing 430 and 300 engines...
- Blitz Air Cleaner
- just looking for opinions....
- K&N Intake - WOW
- Doggone 3.5 inch filter.
- Air filter
- Injen or SRT,,, Help
- Stage 1 Turbo package from dealer...need opinions
- Any high milage 98 or Newer GS400
- gs 400 cost of ownership
- just installed the Supra differential LSD, DIY post on my site
- RMM supercharger Blow off valve & Pulley
- Intake Education.....
- starter
- Adding performance to a GS300?
- l-tuned exhaust upgrade decision
- Who has sounds clips of most of exhausts? Trying to decide which one to purchase!
- L Tuned Exhaust Too Loud
- Installed an Injen Intake
- Headers
- Make your engine roarrr??
- Need your input on what it could be?
- Apexi WS vs Tanabe HSM ?
- Where is the fuel Filter in the gs400??
- Long term use of e-shift - problems?
- Smog check with SRT chip & stock box
- Help...I don't know which Intake buy
- What engine type is the G3 G4 G430
- Exhaust Fitment Problems
- Torque Master Spark Plugs
- Update on performance gains
- Installed a Tanabe exhaust
- Installed HKS Exhaust today
- Tc
- Has anyone ever had to (or heard of someone having to) rebuild a GS4 motor or tranny?
- Is there any way to FORCE e-shift to hold a gear?
- Low Idle Problem Fixed... Everyone Read This
- Torque Converter
- torque converter upgrade
- turbocharged or supercharged?
- Lexus L-Tuned replacement exhaust mufflers/tips
- Akimoto intake problem
- Thumping under acceleration
- First impressions on PI TC, SRT intake, rotors...
- I modded my RMM exhaust!
- price of an exhaust?
- Next mod - Performance mods question
- Chip
- Apexi WS exhaust questions
- Having my TRD LSD installed – but a SERIOUS question has come up.
- Is an aftermarket exhaust worth it???
- rmm intake on ebay
- 1998 GS400 oil filter
- performance chips
- Will the Exhaust Manifold & Turbos From a 94 Twin Turbo Supra Fit my GS300??
- Got my RMM Supercharger installed
- Added K&N intake...
- GS400 - resonators = ????
- chroming
- 6 Speed Tranny
- srt intake
- TRD supercharger
- peel out....
- To turbo or not.
- exhaust for gs3
- pozy track (not sure if spelt right)
- I need some good advice on a power adder
- Did the "search" on LSD... still so confused
- Ok guys I went to the track yesterday. 2000 gs300 bone stock->
- People with Intakes, is your engine bay dirtier
- E.C.U. Manager
- 45K Service - Best Prices in SF Bay Area?
- Anyone know part number for TRD LSD?
- Remus exhaust
- POP Quiz Hot Shot
- where to get quad exhaust
- Can someone tell me what this is???? (Borla Carbon Fiber Exhaust)
- weapon r intake
- Topic Again, Rod Millen Exhaust.
- what would a GS400 run with....
- Redline
- horsepower?
- supra TT torque converter?
- Main seal leak.
- How many people here have the low idle problem? please show count
- Drive Shaft
- Reducing Throttle Body Heat
- need reasonable $ mid-atlantic tc installer
- Exhaust Problem (Borla SS)
- Tranny Service?...
- hayden cooler??
- Changed differential fluid this weekend
- Question on torque converter
- And the tranny fluid is....
- time for 50,000 mile service?
- SRT supercharger or Turbocharger?
- Opinions on Torque Converter + LSD
- Engine Noise Anyone?
- Has anyone else had their waterpump go out on their GS400?
- spark plugs
- Question on going w/ a single turbo on GS300
- Catalytic Converter
- header and emission question
- just got some info on the Blitz Supercharger..
- Turbo Charged Nitrous fed GS300
- S-AFc II part 2
- weapon-r
- engine light need advice
- Nitrous kit question
- pics of engine
- Okay S-AFC II install part 1
- will torque converters make as much difference in gs3 just like gs4?
- Is Check Enging Light Urgent
- What does "ECT" "SNOW" "POWER" and "VSC OFF" do for me in my
- cheapest place to buy k & n cone filter?
- Transmission ECU upgrade
- Question about Intakes for 98-00 GS 400...
- two types of lsd?
- Need Some Clarification On an SC
- Supercharger
- GS400/SC400 engine difference
- Tranny question
- Borla vs. L-tuned exhaust on a 98 GS4
- Sound clips for L-Tuned exhaust??
- Exhaust Resonator removal with Greddy EVO Exhaust
- GS400 top speed-132 MPH!!!!
- Timing belt tips
- Rough Idle - Looks like the dealer fixed it!
- Got Pearlpower's tranny cooler kit installed!
- APEXi SuperAFC (Air/Fuel Controller)
- Exhaust manifold
- Power adder price tags....
- 2JZ-GTE conversion in a GS: What's needed?
- anyone know how i can get this front pipe?
- Look what I found - Injen intake
- Anybody with header experience?
- I Love The new GReddy EVO Exhaust
- what kind of sc spec you looking for?
- SRT intake with Borla exhaust DYNO test results
- ROD Millen Super charger FYI
- The New EVO Exhaust from GReddy
- 90k Maintenance $625
- The New Greddy Evo For GS400
- Check Engine Light
- Seen this Blitz Supercharger?
- quad exhuast
- GS400 Stalled Today?!?!
- Nagging question about exhaust setups...
- anyone have ideas about TOM's front pipe?
- kn ram air
- any tried using an octane booster?
- Question: Is the Tom's Barrel Exhaust LOUDER than Greddy?
- Just Intstalled SRT Intake w/Race ECU
- Torquemaster Plugs
- ruff idle rpms drop to about 500 intermittently
- Need a drop-in injector upgrade
- Soft Shift From 1st to 2nd on GS430
- Octane Boost Follow-Up
- Horse Power estimation..
- SC to GS SRT intake question
- Intake for a 00' Gs4
- valve body upgrade
- Install of TRD LSD
- Which supercharger Kit is better: Rod Milen vs Swift Racing
- Twin Turbo GS400 Update
- 2jz-gte swap vs. turbo vs. nitrous ?
- RMM Supercharger kit for GS400 released.
- APEXi N1 exhaust SILENCERS on GS300
- anyone tried fabricate TOM's intake and E-manage?
- Problems With 2jz-gte
- Getting "cold air" to my intake
- gs430 intake?
- intake system
- squeaking noise
- California Members - Octane Boost?
- Pictures, exhaust manifolds and broken engine
- Found a Good Muffler Shop in Orange County
- Cold Lexus Automatic Transmissions!!!
- exhausts
