Aristo Torsen LSD fit a GS4 rear end?
Old Feb 23, 2009 | 01:53 PM
kit cat's Avatar
kit cat
Default Aristo Torsen LSD fit a GS4 rear end?
Hey guys, I'm tired of open diff and RWD so I'm looking into an Aristo torsen LSD. I've searched around but couldn't find anyone that has done this swap. I'll probably retain the stock 3.26 unless I can locate a 3.76 for cheap.
Anyways, I was wondering if anyone has done this and if it'll bolt up. With the interchangeability of our cars, I am hoping this would work w/o fabrication to the pumpkin, half shaft, flanges, etc.
And please don't make this a thread about "what is a torsen?".
kthxbai.
Old Feb 23, 2009 | 06:18 PM
ROPADOPA's Avatar
ROPADOPA
a good start would be to find out what the JDM axle code is and if it is the same a yours, If you read your axle code you will find out that it is an A series.
If the soarer is an A series then you can take the diff (the thorsen unit) aka lsd unit and put it in yours.
In my case i used a A series differential from a USA mk4 auto tt as they are A series.
The axle code can be found on the door or firewall on the vin tag.
Old Feb 23, 2009 | 08:40 PM
kit cat's Avatar
kit cat
i found it at a junkyard in Japan so no VIN tag . It came off a JZS161 w/ torsen unit...so I am guessing it'll fit...
Old Feb 23, 2009 | 09:02 PM
krappy's Avatar
krappy
I dont see why not, the rear subframes are the same arent they? (correct me if im wrong) so it should just bolt up to the regular mounting locations with no problems...
Old Feb 23, 2009 | 10:14 PM
kit cat's Avatar
kit cat
Sorry, I should have clarified.
The unit I found is just the LSD, not the pumpkin and the assy. I bet the pumpkin would fit, but I was wondering if the Aristo torsen would fit in a GS4 pumpkin w/ GS4 final.
Old Feb 23, 2009 | 11:08 PM
ExileLakai's Avatar
ExileLakai
yeah my GS has the aristo torsion in it. My car also started out as a GS4. I believe the rear end came with the swap so they threw it on. I don't know specifics but it locks up good.
Old Mar 10, 2009 | 09:29 PM
tom steele's Avatar
tom steele
will any 10 hole lsd from supras work or does it have to be certain years i know the auto is the 10 hole and the stick is 12 holes is there a difference between the two can you use a stick version in an auto as long as it has the 3.7 gears
Old Mar 13, 2009 | 12:33 AM
sam430's Avatar
sam430
sounds interesting.
Old Mar 13, 2009 | 01:03 AM
macd7919's Avatar
macd7919
Nope, it wont fit, just sell it to me for $100 lol...
Goochie
GS - 1st Gen (1993-1997)
15
Nov 4, 2024 05:23 AM
justablkv8
Mar 26, 2013 09:11 PM
Dew23
Performance
Jan 30, 2012 12:48 AM
soarer13oy
Jul 1, 2011 12:14 AM
nakedterro
Sep 7, 2006 06:40 PM
