4-speed supra auto into GS3
Old Jan 26, 2009 | 08:07 PM
fordsvtmfl's Avatar
fordsvtmfl
Default 4-speed supra auto into GS3
has anyone done this swap? how much of a pain would it be as far as electrical stuff, and will it even fit?
Thanks
Old Jan 27, 2009 | 04:39 AM
ROPADOPA's Avatar
ROPADOPA
It would fit but you would need the ecu to control it. Its one of the benefits of going with a true turbo swap.
Old Jan 27, 2009 | 09:37 AM
sakataj's Avatar
sakataj
is this just another ? just to know or something your planning/thinking bout doing....y not just build YOUR tranny or get a getrag (would be a awful drive on the street though)
whats your first name ford....is it "louie?"
Old Jan 27, 2009 | 02:09 PM
fordsvtmfl's Avatar
fordsvtmfl
its was just a ? and MY tranny has 150K on it...i would like to start fresh if i ever did do transmission work...and i would like to go with something a little stronger if possible w/out having to do a manual swap.
-Preston
Old Jan 30, 2009 | 02:35 AM
Caoboy's Avatar
Caoboy
Supra TT auto trans is good until about 450HP (rather BPU++ upgrades) before it will start slipping and needing to be built.
Get a built auto the first time, you'll save money.
Old Jan 30, 2009 | 08:51 AM
fordsvtmfl's Avatar
fordsvtmfl
yea...i know...but the main reason i started this thread is b/c you can get a built supra trans from supra store (forgot who makes it boost logic maybe?) for 2200...and personally it sounds like a deal for a built trans.
Old Jan 30, 2009 | 08:53 AM
fordsvtmfl's Avatar
fordsvtmfl
also...could you control the new trans with a AEM EMS? with the stock ecu? or would you need the supra ecu?
Old Jan 30, 2009 | 11:36 AM
Caoboy's Avatar
Caoboy
Did you check to see how much a built NA trans would be? I recall something like 1500 to get it built....something like that. Not sure though. I think Jeff Tsai knows though.
Also...is this built as in a new sprag gear/valve body? Or do they cryo treat the gears and stuff to make it bullet proof (lol)
Old Jan 30, 2009 | 12:41 PM
ElitistK's Avatar
ElitistK
aem ems only controls the engine. if you want to run the 4spd you will need an aristo v300 ecu. the sc300 98+ ecu might work, but don't quote me on it. obviously with an aristo ecu you will need a standalone to control the ge engine.
you should not bother with swapping in a 4spd auto unless you're also swapping in a vvti gte into your car.
Old Jan 30, 2009 | 12:49 PM
fordsvtmfl's Avatar
fordsvtmfl
Ya know...alot of ppl say stuff like this...but what exactly is the reason? seriously...i know the gte is a stronger motor..but the ge can accomplish basically the same if modded correctly.
Old Jan 30, 2009 | 12:51 PM
plex's Avatar
plex
1UZFE/2JZGTE
Why would the getrag be awful to drive on the street?
Old Feb 2, 2009 | 05:12 PM
gs30062-1's Avatar
gs30062-1
Im running a supra auto trans with a level 10 kit in it I use a aem from a supra to control the motor and trans
Old Feb 3, 2009 | 01:10 PM
sakataj's Avatar
sakataj
i had one i custom adapted in my old 82 cj-7 jeep that i had a chevy 350 in and didnt like it....but maybe it was just because of my 53" tires and 4.86 gears hahaha
BuffNStuff
Aug 13, 2014 06:19 PM
V8KLLA
May 29, 2012 08:12 AM
kevs98GS4
Performance
Apr 2, 2008 11:17 PM
bambooluv
Performance
Mar 28, 2005 11:41 PM
soarer NAT
Nov 19, 2003 10:43 AM
