Oil type
If you don"t know how to open the hood, then god help you. Give up on car maintenance and just let your local (certified) mechanic do all the work. Even if it's wrong, at least when your car blows up you can sue them.
anyways..i would put in 10w 30 because of the higher miles..synthetic is best..but if you have been using normal motor oil you will probably have a small leak (most likely at gaskets)
If your car is not working correctly, then you'll need to give some feedback on what is wrong with your car or what symptoms you are seeing (smoke, oil loss, rattling, etc).
Changing grades of oil is a stop-gap solution for when something is not right with your car and it is not cost effective to fix the real problem properly.
If you've already made up your mind that something different is got to be better, then you've already made up your mind that you are smarter then Toyota/Lexus, and there is probably not much anyone can say to change it
. Just try whatever floats your boat, and if it makes you feel better, it worked for you! There are many different schools of thought on oil and it's almost religious (go see bobistheoilguy forum), but personally I'd either just stick with manufacturer's rec, or the mechanic who will warranty the work and pay out if something goes wrong. Everything else is YMMV and something you heard from some guy on the internetz.
well...your partially correct...toyota/lexus recommends 5w30 OR 10w30... you would only run 5w30 if you lived in a state where you might see sub zero temps, and i dont think the OP is going to be seeing that in CA
seriously though can u ship me some?
find me a scientific proof that high mileage cars will certainly leak oil going from conventional to synthetic.
if you went from conventional to synthetic and you're getting leaks, that means your seals are bad in the first place; conventional oil just masks the problem because of less cleaning agents in the oil.
im not positive about leaks or anything but i do know that in switching from dino oil to synthetic you should run a blend for a couple oil change cycles to condition your seals to the new oil and flush out the dino sludge. As far as weight, i'm in new england and personally go by manufacturer's recommendation no matter what the case (my old ML used 0w-40 full synthetic year round). But in my GS particularly, I'll probably switch to synthetic in the summer, it'll last longer and maybe be a bit more forgiving if i miss my oil changes by a couple hundred miles.
