View Full Version : Performance
- S&S Headers question
- 1UZFE Idle Air Controller Location?
- Is it possible?
- carson B pipe and hks hi power
- Looking for digital pictures of installed SRT Intake on GS300
- GS 430 turbo?
- More bling bling for the engine bay....
- gs300 turbo swap
- anyone want a short-ram intake? uber-cheap...
- GS stalled while driving
- ADAMGAMZ! JEFFTSAI! this one's for you guys...
- Help Me Please!
- Apexi WS2
- S&S Headers Update - No cracking on current design
- Can Someone Please Post Up Sound Clips Of Different Gs300 Exhaust?
- Aristo 2jzgte vvti ECU
- gs400 and 125 shot of ....
- Any known problems using Amsoil ATF Tranny fluid???
- Tanabe exhaust systems
- redline limit on built engine
- Launch.
- Gas Mileage Down The Drain
- Mufflers
- What Do You Think Of The 5zigen....
- Tm Vs Hm
- Torque Converters
- Dart Izumi Exhaust.....
- Driver Side Floor wet any suggestions
- ...HOLY crap! Loose spark plugs!
- Open wastegate- Yay or Nay?
- Total Cost Of Manual, Turbo Gs300...
- K&N Filter
- Twin Turbo Gs Totaled
- check engine light code p0763/p0715
- The new complete built cylander heads from MVP what do you guys think.
- Replacement filter
- SRT Turbo kit.
- Exhaust vibrates my bumber
- 01 gs300 shift time
- Which after market exhaust is the quietest?
- Rear Differential question
- Something people always forget to factor in when boosting...
- Air filter
- Leaking radiatior lead to blown engine head???
- gs400 turbo
- 1/4 mile time for V8 cars with TC and 3.76 LSD
- Any Negatives to running a SAFC?
- Apexi Neo/Cam gears
- Help with exterior areo setup...
- The GS4 auto trannies
- Air Filter Question...
- titan exhaust air jack
- Anyone with S&S headers?
- Mobil 1 Synthetic ATF now approved for use in our trannies
- Apexi WSII
- Top 10 1/4 Mile Times GS300/GS400/GS430
- ~~Help, I'm scared~~
- Who's running Borla Exhaust Tips?
- Trany Cooler
- Question about SRT and smog check
- GS300 Intake + Exhaust question
- Pics of your custom x-pipes
- Drone
- Any one Running a custom MAGNAFLO setup ?
- Easiest way to make power for less?
- xerd headers on gs300
- arc induction box will it fit?
- Went to the track tonight
- Arc Induction Box Will It Fit?
- gs300 2jzgte swap
- Differential Fluid Change ?
- 02 GS3 2jzgte vvti swap (searched)
- Turbo specs and horse power potential
- 80-90 valvoline Synthetic Blend Gear Oil .. good enough for torsen 3.76 auto lsd ?
- Injectors flooded!!
- Is 3" exhaust piping good for NA
- Tundra supercharger: BOLT ON to 1UZ
- Question about -gte swap into 2nd gen
- GS400 Factory Harness Extension
- Is there sucha thing as A tune up kit?
- Flowmasters 40 series on the GS400 (Vid inside)
- HELP identifying lip and exhaust
- Whats better, SRT+ECU or K&N+NEO?
- Magnaflow
- 3.76 Dyi Help!
- Magnaflow exhaust
- 3.76 Diff oil 75W90 brand?? HELP!
- Where are the 02 sensors for the GS400
- The mad scientist! New turbo!
- wastegate question
- Thinking of supercharging...again revisited; some questions
- Tanabe or TOP SPEED 2000 GS300
- Exhaust Installed!!!
- Turbo vs. Swap
- Transmission Fluid
- Supra Store Turbo's
- Will GS400 airbox fit in GS430 ???
- custom exhaust. from headers to cat-back - suggestions?
- Tanabe hyper medallion?
- buying a gs need help
- SRT Intake Problem
- need some help asap please
- Opinions needed please...
- ATTN: Modders a new GS project
- Aftermarket Exhaust and Smog
- low idle problem
- 20% more hp for $15
- Transmission Mount DIY
- Turbocharger Question
- Injen Air Intake
- Carson Tuned Exhaust, feedback on how it sounds, only 3 results when I searched
- Brian Crower 264 2JZ-VVTi Cams: Install, Tune, Results, and DIY
- Oxygen Sensor Help
- PushinLEX: Tanabe Touring Medallion Exhaust
- PI TC SEVERE VIBRATION at 2800 RPM
- help:car will not start
- BFI Intake GS300 Build (w/pics)
- Makeover time!! GS400TT upgrade/build has begun (pic happy)
- intake system
- intake air
- Plan for my new GS400
- Can the Magnaflow 14832 exhaust fit on 2nd GSs
- Should I get this Exhaust? Will it fit?
- New custom exhaust underway for my 430!!!
- HELP! Noise from the exhaust?
- need help please...
- PI TC, VB upgrade tranny leak?
- Just installed Borla Exhaust
- Exhaust scrape?
- Question about the hks hi power exhaust
- Update on custom exhaust installed.. kind of disappointed
- My Tranny went out
- Need opinion or advice on custom magnaflow muffler setup - GS430
- Please Help!!Coil-Packs & Injectors!!
- which is the best exhaust
- looking to buy a intake need some ideas? what type
- Where do I find a MAF connector?
- New pics w/ Tanabe exhaust
- Name that exhaust - video inside - need your help
- Pioneer of GS Performance
- Needed: Definitive answers from qualified individuals on 2JZ-GTE in a 2nd gen...
- SRT Intake on gs 300??
- quickest 2nd gen GS300 / GS400 / Gs430 on the planet
- exhaust options for gs400's?
- 2jz-gte vvti into 99 GS300 help
- Supercharger kit. BS?
- Turboing a GS400 Questions?
- tanabe medalion touring vs. borla mufflers FITMENT/CLEARANCE question...
- Lextreme TC anyone have one?
- What built tranny are you GTE auto guys using?
- Are Injen air filters pre-oiled and washable??
- Turbo Timer (Need Help)
- Wringo's HKS Exhaust(Pic's)!
- Good info on the GE motor
- Intercooler for GS300
- When to the race track last night...
- Question to those with K@N intake system
- Twin Turbo GS4 listen.
- Cold Air Intake vs Drop In Filter
- Cold Air Box + K&N Intake 2001 GS430
- 1st gen exhaust on a 2nd gen?
- Greddy Evo exhaust
- Installing MagnaFlows (99 GS400)
- Changing internals on (non-FI) GS400/430...has any1 done it?
- transmission hose
- Newest Supercharger Kit for Gs400 VVTi Engine..?
- superchargin 98 gs400 costs?
- IS this normal?(Exhaust)
- Are the Lex family different?
- HELP :>> Is Magnaflow Exhaust model #14829 the right one for the GS?
- Need Help: Will Magnaflow Exhaust #14829 fit my 02 GS300?
- K&N for GS 300
- Has anyone ever tried this at all?..
- upgraded motor mounts?
- Borla Exhaust
- some pics of my gs300 turbo
- Successful V160 Getrag swap into GS400/430... Anyone?
- New K&N cold air intake too loud..any suggestions to make quieter??
- srt intake DIY? Writeup?
- Finally got my PI TC installed. WOW!
- best air intake system for the gs?
- Philly Shark Twin Turbo
- Someone's GS400 burnout video
- questions about gs coilover
- question 05 gs 300 turbo kit
- Quesion?? Removing resonators? 99 GS300
- if i remove resonator will i still pass emissons??
- Is the Greddy Evo 2 Safe for N/A GS300's??
- Looking for some help
- What exhaust comes as a full cat-back(Y-pipe back) system?
- Does any1 have pics of 1st batch S&S headers?
- anyone use Top Speed exhaust system?
- Input Wanted: Best Exhaust for a 02' GS300
- Borla Exhaust
- possible n00b question...
- Very quick ques. Will my GS400 pass inspection with S&S headers?
- Whats ur Thought on Greddy Evo 2 or Blitz Nur Spec Exhausts??
- Let's try this again....2GS Airbox mods?
- HKS Exhaust installed
- Just poking around out here....
- SBM GS3 & S4 twin turbo tint pictures
- JIC Twin Spartan catback
- Rear Mount Turbo Set-up !!!!!!
- Looking for a quite exhaust system...
- Little mini review on : SRT Intake with Greddy Evo 2 dual exhaust
- Can anyone recommend good tunning shop in NJ?
- Exhaust piping size.
- what gasket do you use for a aftermarket header and y pipe
- Need intake advice
- question to people that have aftermarket headers
- GS 430 SRT intake +ECU
- GS400 to 300 turbo Can it be done?
- jza80 manual LSD the same as auto LSD? will it fit??? please help
- Twin Turbo GS400
- Any1 know about the new Amsoil nanotechnology air filters?
- SRT Intake
- How much to install headers on GS400 / GS430?
- Exhaust for boosted 2gs
- Need Help Now!!!
- i want to get a gte gs built!!
- Borla claims 7 to 15% increase in hp. Is it true?
- Looking for a PIC with the RMM rear bumper and Tanabe Medallion exhaust(s)
- hestitating problem
- NGK Iridium IX SparkPlug's for a GS3?
- GS Transmission Help Needed
- Could someone verify ECU pin for me?
- Srt Gs430 Intake
- CHECK OUT THIS VIDEO: My 2001 GS430 Exhaust vs 2008 Mustang GT exhaust!!!
- I wish there were lightweight axles and driveshafts for our cars...
- Octane Ratings
- When doing 3.76 lsd, change axles?
- Red Coolant cost
- Anyone with a PI TC & 3.76 LSD???
- where can i get new injectors
- Car Bogs And Hesitates!
- walbro 255 fuel pump
- O.K guys I changed my turbo.
- red SRT filter and intake tube couplers for GS430...
- PI TC GS430 Installed!
- OBX headers question
- Anyone ever bought a Pro-1 exhaust for a GS400 or GS430?
- Anyone had issues with their coil packs after using Torque Masters?
- trying to get turbo boost on 00 gs300
- Has anyone tried the Pulstar spark plug?
- Tanabe Medallion Touring vs. Greddy EVO II
- Chip Module worth buying?
- New Custom Exhaust system put on (pics & vid inside!)
- SRT: Are they a respected tuner brand or ????
- JoeZ intake for 2nd Gen GS's?
- Question about Nitrious.
