View Full Version : Suspension and Brakes
- Picture Request: 19"s On Stock Springs/Coilovers
- where to get oem LCA bushings
- roberuta cup
- For those w/ bilstein shocks
- Disappointed in brakes on GS400!
- Noise in Front Right Side
- If the tein coilovers are green what model is that?
- sway bar bushing size Q
- iRotors make noise after 6 months!!
- Identify this Part PLEASE!!
- Full Brake Job???
- Bushings?
- Need help,Brakes
- Brake Caliper Sticker
- Intrax Sway bar
- stuck parking brake
- Hub bolt size? Trying to replace wheel studs.
- Question about STB
- weird problem, car more lower from driver side
- Do we know if the 4 caliper 3GS brakes fit the 2GS?
- brake clearance for rims question
- Suspension Noise
- 60bucks for 2-3 degree camber fix?
- New rotors now have rust!
- newbie HERE
- want LS460 brakes?
- Changing brakepads
- turn or replace warped rotors
- ****Help for 98 gs400 Rookie DYI'R
- Help! Anyone with 18x8" OEMs and supra TT BBK
- Brakes question for 2004 gs300
- Help me out guys, i need new brakes
- 1300 good price?
- Help, Brake Pedal Sticks!
- Loud rubbing noise coming from brakes
- my TRD sway bars installation + experience (many pics)
- Is brake upgrade needed for 20s?
- DIY Brake Flush??
- My Brakes Suck
- TRD Sway Bars installation / cost / tips
- Has anyone received there SR bushings from Sewell yet?
- Broken Tein
- Brake Problem after Dropping Vehicle
- Carson's GS300 Supra BBK
- What brake pads do you like?
- Can you do incremental brake fluid change just like the power steering fluid change?
- Bilstein...? Does the SC suspeion fit the GS?
- DIY Lower Ball Joints for the 2nd Gen GS. - Step by Step Instructions and Pictures
- Tein Strut Tower Bars Review
- Caliper stickers ?
- are stock rear pistons flat?
- drop links or anti-roll bar bushings?
- Will adding a rubber insert between the shock upper mount reduce noise?
- Front Struts
- I Broke Daizen rear sway
- Q about new steering rack bushings
- 18" 07 GS wheels OEM on 98-05 GS???
- Best price I can get oem brake pads
- Tom's calipers?
- strange brake behavior on super slow turns
- Best price of Tein Cs-v2
- Finally installed Tein CS V2
- brake question
- Installed Tom's 6 Link and rear brace - now somethings creeking in the rear - HELP!
- Help choosing shocks
- Need Help with how to remove and grease Daizen front sway bar bushings.
- Toms Advox Sports coilovers - anyone here experienced them?
- Are Supra's rear brakes direct fit for the GS?
- Help guys! Need to repaint TT calipers...
- Reaonable Price for Rear Pads + Rotors and Labor.
- Upgrade brake question
- squeaking noise from left rear wheel/suspension
- squeaking noise from front end
- Sustec Pro S-0C anybody?
- Do I get rid of my 20's
- Daizen VS. TRD Blue Sway bars
- Opinions needed on Supra Brakes
- Help Pleasee..my 2001 Gs300
- Strange metal grinding noise from my rear passenger side wheel when I brake.
- install full daizen control arm bushing kit or partial? help!
- Ball Joint part#s & price @ Sewell
- do i have warped rotors?
- Rattling Noise When Going Over Some Bumps
- Taking out the brake lamps
- 2000 GS300 sport control arms
- clunking sound when braking .
- Supra TT question
- replaced rotors, brake lines and pads. Now grinding noise.....
- Tein CS adjusting question
- Daizen Lower Control Bushing
- lowest drop with Tein CS
- funny diy brake caliper post
- Break-in procedure...rotors yes but pads say no?
- Do we have screws that hold our brake discs to the hub?! I just had my rotors.....
- New Calipers on My GS
- Hawk HPS and Goodridge Lines
- ABS, VSC, Signal Lights on after changing lower Ball Joints?
- Suggestions on the size and kind of spacers that I should get?
- Brakes
- goodridge ss brakelines; are all four the same length?
- Tein CST
- Tein EDFC
- Brake Caliper Question
- Popping noise when braking
- Akebono Pro-ACT...yes but which ones?
- MY Bilstein Review
- Changing to ls400 calipers...
- L-Tuned Shocks - Pros & Cons?
- Rear Calipers Will Not Bleed...
- Alignment goes bad after a month
- Comparison of Bilstein HD/Ltuned combo to Tein Flex
- What have you guys heard about the Megan racing coilovers?
- Installed Ball Joints
- Like a 5-series
- Rubbing...
- Billet Bars GB is up and running
- Lower rear braces: Toms or Ebay?
- brake fluid leaking?
- Passenger Side Clicking Noise
- Tein STB
- Steering wheel shakes?
- 1999 GS 400 cost for new OEM Shocks & install
- Help: copy for Instruction on Tanabe coilover
- finally got a couple of pics of my car
- Looking for a BBK?
- So I just changed my front brakes....
- newbie in trouble with brakes
- are my brakes bad?
- cheap bbk on ebay!!
- 2-pc Racingbrake oem sport rotors
- tein Cs Gap ?
- where to buy daizen steering rack bushings?
- Brake pads and rotors
- Trinet ???
- Has anyone used Just Brakes??
- Tein Super Street Damper question.
- i was told by my friend that ls400(1995+) calipers/rotors are direct swap
- which color would you paint the caliper.....
- Just installed Tein strut bar, pics
- Front end squeaking over bumps..
- Tanabe Coilovers
- ureathane bushings
- How much drop to get VIP camber ?
- Teaser--Tein CS & 20's
- opinions needed on TEIN SS COILOVERS
- Wondering If any Big Brake Kit would fit?
- Strange Vibration when braking
- OPINIONS on Tein S-Tech w/L-Tuned shocks. Please help....
- Camber Bolts & Spacers?
- HKS Hipermax RS vs. Tein CS v.2 coilovers
- Any GS owners using Energy Sway bushings?
- Question on struts
- HELP! my rotor is being eaten away alive
- Need advice on brakes...suggestions???
- Drilled/Slotted not good?
- weird clicking sound coming from back maybe brakes
- castor vs control arms? bushings-confused...
- Need Whell Spacer to Clear BBK!
- Best Aftermarket Brake Pad?
- Help me this noise
- I need directions on how to replace the front Lower Control Arms
- Tanabe NF210 & KYB GR-2 - Before & After
- Vibration @ 60 after Braking Upgrade..Why??
- How to: Sprint springs and OEM struts.
- Rotora 12 piston brakes
- spring opp!!!
- need info on wheel studs
- Suprise..Suprise..JDM Rear Lower Brace
- WILL THESE RIMS CLEAR BBK?? 20x9.5 all around +20 offset
- Help..Camber Problems...
- Need Help Fast. Camber Kit
- C-One type G coilovers?
- New TEIN CS coil-overs, where in the HELL did all that noise come from???
- brembo calipers and rotors can anyone chime in?
- Anyone know if I can buy replacement Tein dust boot?
- L-Tuned Spring/Shocks or L-Tuned Spring/kyb combo questions
- "Lexus" caliper stickers
- L-Tuned Rear Springs -20mm
- Espelir/Bilstein combo anyone?
- ULTIMATE REFERENCE - Springs, Shocks, Wheels, Pics [merged threads]
- Tein Coilover owners**I need your HELP***
- Pyro Ball's - Better alternative to Daizen bushings?
- Ahoy! My GS swayeth like a cruise vessel not to be confused with a cruise missle
- Now the fun begins (got kybs)
- Lower suspension arm (castor arm) bushing worn. Go OEM or Daizen?
- Oops...dropped the coilovers too low
- DIY brake caliper paint write-up (with pics)
- Appearence VS riding stiffness
- How to soften KYB/L-Tuned Setup?
- Soft brakes
- brake rotor dust shield
- rear l tuned springs
- Caster Arm Bushings, Replaceable?
- Pics of my Tein CS V2
- Rotors on Right????
- Anyone experience rubbing?
- tom's brakes and coilovers
- aftermarket SPRING rate Thread!(Not coilovers)
- Lower Drop on 17": Tanabe NF210 or L-Tuned?
- 20s with Stock Suspension?
- anyone heard of or had any experience with these coilovers?
- anyone knows the spring rates of the stock suspension?
- TRD Big Brake Kit
- SPRINT springs and OEM struts. 2000 GS400.
- What's Good?! what are the best rotors?
- Tein CS 2 came in!
- does my car look weird?
- Picked the 20s.. now the SPRINGS?!
- For those of you with KYB shocks with aftermarket springs post your mileage!
- What makes Tein CS coilovers make noise?
- will stock 07 gs rims fit 01 with supra brakes
- Do G3 18s clear TT Brakes?
- Vibration above 75, my wife's gonna kill me!
- Quick question about L-tuned springs
- Midas brake pads
- Stainless Steel Brake Lines - which to choose?
- Anyone running Rotora front BBK with H6 pads?
- Suspension advice, please
- MUST READ - Steering Rack the Culprit?????
- Are KYB shocks same as L-tuned shocks?
- Just bought a GS400. Need advice.
- Which Setup Gives U That "Boing-Boing" Ride
- Difference between Tein CS V.1 and V.2?
- Bigger arms?
- Espelir springs discontinued?
- clicking noise
- OEM vs. Aftermarket swaysbars? whats the diffrence?
- brake pads.. where to get them?
- Ques. on brakes and need to get new pads; suggestions???
- New! Nagisa Auto suspension parts for GS300
- For Those Who Have Lowered, Your Advice Would Be Appreciated
- For Everyone with the Daizen questions: DAIZENS & 20's!
- Bilstein HD and Lowering Springs
- Choosing Springs...need help
- Where to set my Tein Flex
- rotor moves?
- Question about Espelir Springs
- Can I achieve this stance? Coilover owners HELP!!
- So... the coilovers are on finally. Hanh!
- Caliper Decals???
- Busted ball joints at 20k miles?
- steering wheel free play?
- never heard of these coilovers? your thoughts..
- PLEASE I need help or advise, All confused!!!
- L-tuned Install Question
- need help: how to lower my gs300
- Lowered the GS300 with TEIN SS Coilovers
- Daizens on 20's
- Front Brake Fitting Kit Orientation
