- What to lookout for
- "Shriek" when turning wheel over hard in the morning.
- RX350 or RX330 Towbar instal
- Hatch and tail light issues
- Locate key for my 2006 Lexus rx330
- loud rattle in dash...
- 04 RX330... Keyfobs stopped working after new stereo
- Were there issues with the early 2nd gen RX?
- TPMS problems
- Where do people purchase a timing belt kit?
- Wiper question
- 4 or 5 speed gearbox
- 07 RX 350 with C1201 P0430 codes
- Blistering behind outside mirrors
- 2008 RX 350 rear wiper motor
- 05 rear hatch will only open part way
- My Rx400h Ambassador tuning
- Factory Nav audio works even without Factory amp
- Rear wheel hum - Rear bearings at fault?
- Stiff/bouncy air suspension
- Instrumental Cluster and Interior LEDs
- 2008 RX330 100k timing belt and water pump
- Replacing the Front Swaybar
- Lexuswiz's RX330
- RX300 purchase advice
- 2007 RX400H Tightening Axle Shaft Boot
- Need help with maintenance on my rx400
- Help with purchasing an RX please
- Anyone know a fix for broken climate buttons?
- help with installing techstream (sorry, no pirated software discussion allowed)
- What's a good price for 90k mile service (timing belt, water pump, gaskets, seals)
- 05 RX330 Bluetooth for Pandora?
- Dumb question about console...
- Serious engine noise after test drive
- Unbelieveable upgrade to factory Nav/Radio
- Need Help on a 2007 RX 350 Alternator Removal
- Driver preset memory buttons not working
- 2006 RX 330 aftermarket stereo setup
- Charges for repairs. Am I being ripped off?
- brake calipers/pads rotors
- 90K Miles service
- Rattle from Front bumper foam?
- Headlight lens restoration
- Low pitched sound with heat/ac
- color of my RX 350
- TPMS how-does-it-work question
- 2008 RX v iOS 10
- 2005 RX330 Rear Strut / Shock replacement - need guidance
- Eastern Catalytic - junk
- Power steering fluid 2007 RX350
- Tools to use
- Fluid in Drive Shaft?
- Purchase Japan made Headlight assembly w/o AFS?
- Pulled axle shaft out of differental, am I OK?
- 08 RX350 Exhaust system loose?
- 90915-YZZD3 oil filter on RX400H?
- New 2007 RX400H Owner
- 2009 RX350 Hard shifting
- Advice on 05 Rx330, lees than 25k miles
- Moving to 3rd Gen....
- RX350 DIY needed for Top motor mount and CV boot replacement
- Long-Term Use of Regular Gasoline
- Can't register new key
- Rattling noise underneath
- Strange misfire problem need help
- 2004-2006 Oil Change Video
- P0430 Code
- 2005 rx330
- Side Mirror Replacement
- four way side mirror actuator switch
- 2004 RX fluids
- key problem
- Service recommendations
- Transfer case rear leak
- 2004 RX330 Oxygen Sensor confirmation
- Lexus RX-2005 transmission
- Starting problem
- Avoid Overheating - Clean between condensor and radiator
- RX400h driver's door lock not working [repaired]
- Clanking noise on the cold engine
- Lexus RX330 Air Intakes
- 2006 RX330 Instruments Lights
- 2004 Lexus RX330 Front Differential Leaking
- 2004 330 Traction Control Issue
- Need Help on Water from AC Drainage problem on 2005 RX 330
- Possible new purchase 2009 RX 350 61 k any advice
- Coil Pack replacement
- RX 350 won't start. Help!
- Rack pinion nightmare
- LEXUS RX330 Air Suspension / Control Arm Bushing / Balljoint Advice Thread
- Downgrade from NAV to non-NAV???
- 2004 rx330
- Rear wiper MOTOR replacement help 07' RX350
- RX 350: Dash Removal guide?
- Wiper second speed setting too acts as automatic. Why?
- 2005 RX 330 Air Suspension Struts Top Bushing Loose
- Interesting Brake info on a 05 RX330
- Headlight Levelers
- Anybody who changed the key chip only?
- 2008 RX350 Ballast D2S or D2R?
- Adjusting my parking brake
- RX350 rear wheel bearing change info pdf request
- Can't find the part name/number for the black plastic cargo latch
- Repurpose steering wheel button
- Full carpet replacement?
- Loose 12v Power Socket/Outlet
- Rx Armrest
- 05 RX330 hesitation upon acceleration
- RX300 2004 Horrible suspension
- Can't get Tire Warning Light off
- parking Brake warning Light
- Belt area squealing noise after warm up
- Transmission shifting weird?
- Strut Questions
- Camshaft/crankshaft sensor problems
- Swapping Headrest on a RX400h
- Parking sensor wiring colors
- See Ya & Thanks!
- Bad transmission?
- Reverse Mirror tilt stopped working after battery change
- How do I remove under carpet padding?
- 2007 RX350 - DIY Transmission Fluid and Filter Replacement - EASY!!
- Advice on purchasing a RX350 2008
- Newbie with questions on '08 RX
- Leather seats rub together - annoying sound
- RX 350 Cam Gear Rattle
- Need some Help for 07 RX 350
- Audio Question about my new 400h
- Found a source for transponder keys
- Engine light flashing
- Clunk/Thump in rear after letting off throtle.
- Tire Wear Question
- Air filter box part # needed please
- Replacing Rx wheels
- replacing alternator
- Moving on... To another Lexus.
- Hatch loop has come loose - help please
- '07 RX 350 Running Hot?
- Loud lifters?
- 2006 RX330 Door lock reset
- When did RX 350 Radios Add Sirius XM?
- 04 RX330 w/NAV - Aftermarket HU
- Recent accident: Question about the front bumper and under area.
- 2008 RX aftermarket CD player suggestions?
- 2004 RX330- 109,000... Good buy?
- 09 vs 10 Rx350 first Lexus reliability maintenance/ upkeep value?
- HELP: 2007 RX350 high idle P0015 fault code
- Catalytic Convereter
- AC Light Blinking
- 2007 gx 350 no radio sound
- Help Diagnosing Noise
- Tire Recs for 2009 RX
- Counter steering on slanted roads?
- 2004 RX navigation blank screen
- 2008 RX350 Steering / Suspension Issue
- Lexus RX 350 Oil Control Valve - p0012
- 2005 rx 330 windshield molding coming loose
- Dvd screen in headrest
- Headlights!
- New member
- Front caliper slide pin rubber bushing
- How To Prolong Dash Live?
- 2009 RX350 Aftermarket Stereo Support
- Outer Sheetmetal Door Material? PepBoys dinged my car!
- Tire Cupping Problem, Need Input
- Mileage for an oil change & how much oil does your RX burn?
- CD Player not working
- Navigation Lane Assist
- Front Hood Lift Support Strut Replacement
- Lexus RX400H Door Dented
- Subtle-Dip
- 2005 RX330 Air Suspension Issues / Questions / Knocking Sound
- Thumping Noise after Accelerating
- RX 350 air suspension question
- Timing belt / Drive Belt / Power Steering Belt
- having issues misfire and overheating Lexus rx 350 2009
- Engine Oil Change Issue
- 2008 RX 350 LED interior mods
- Actually stopped working - evaporator core
- 2004 Rx330 ECU pinouts
- Steering Wheel Customization/RetroFit?
- Car Keeps forgetting Keys...help...
- Can I push an AWD RX330 a few (30) feet?
- Lexus RX 330 (2004) Navigation map problem
- Dash and Instrument Cluster lights
- VSC and CHECK ENGINE LIGHT, TRACK OFF + comes on and off
- 2005 RX330 AWD trans hesitation
- 2007 RX 350 Screen
- How to stop rearview side mirrors from pivoting down
- Akebono or Sumitomo Brakes?
- Hood won't open RX350
- Front Drive shaft
- Thug noise under when step on brakes after replacing front/rear brake pad/rotor disc.
- loss of driver control of rear windows, all sunroof buttons do the same thing!
- Head lights
- 2007 rx350 awd I have a noise coming from under the drivers side dash
- I think it's an illness.
- RX 330 Front Differential Bearing
- Tensioner Pulley Noise
- oil filter hatch?
- Need help. Need new ignition key.
- RX 350 Electrical Problem PLEASE HELP!
- 2007 Rx350 Struts
- External Brake Controller on RX Hybrid
- 6 CD Changes problem
- Loving the old RX330 beater car
- Help with custom wheels?
- 2009 RX 350 Maintenance
- 2007 rx350 - engine oil issue & cam actuators
- 2008 RX350 starting issue-dealer can't figure out
- 07 RX350 AC amplifier issue?
- Can you change oil filter without draining all the oil?
- Anyone have a 2 channel dash cam installed?
- RX 330 2004 Leaking sunroof
- Replaced knock sensors on my RX330
- Nav DVD will not eject
- What is this button for?
- Rx 330 with over 200k, reliable for college?
- 2009 RX 350 Oil Cooler Leak
- Center console cupholder missing divider?
- RX330 Burning oil and PCV replacement
- P0420 code, O2 sensor 1 at 0.00 volts?
- Locked Out -- Role of "Valet Key"
- Thinking of buying a 2004 RX330...what to know?
- How to remove fog light housing
- Keys stopped locking/unlocking doors.
- Cruise control light out and "AFS off" light on
- Dashboard problem
- 05 RX330 Luggage Rack rattling
- 400 RXH 2007 Windshield cracking issues
- Head light blinks
- HELP! help me diagnose the real problem...
- 2004 RX330 - Check Engine, VSC, Trac Off
- Looking to buy an RX330 350 or 400H
- RX330 Seatbelt Retraction-Replacement
- RX transmission issue
- Invertor Coolant Bubble
- Vibration at higher speed. Bad Wheel Bearing?
- RX400h brake issue
- HID AFS to Halogen
- What mileage to avoid buying?
- Belt part numbers? when to replace?
- Wetsanding gone wrong??
- Side mirrors not adjusting on hot day
- Do side mirror actuators use the same motors as the door locks?
- Passengers windows won't roll down from driver side master controls
- Check engine light likely cause
- Brake pad recomendation
- Energy Suspension - Sway Bar Bushing Part#
