Driver preset memory buttons not working
Old Oct 18, 2016 | 11:30 AM
rns's Avatar
rns
Default Driver preset memory buttons not working
Preset buttons in the driver's door for seat, steering wheel, mirror positions stopped working today in Rx400.
Seat controls, steering wheel tilt, distance and mirrors work when you move them from their switches.
Pressing preset buttons 1,2 or set there is no response or beep when program it. And this has been checked gearlever in Park and car Ready-mode.
Has this happened to someone? I did not find threads concerning this.
I could think it might be wiring issue in the door cable harness? Worn cables?
I will plug it to Techstream for DTCs, haven't this function got its own ecu?
Old Oct 18, 2016 | 11:55 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
pull the key out and open/close the door
then try again....
Old Oct 18, 2016 | 02:35 PM
thomas1's Avatar
thomas1
Hold the set button and than push button 1 or 2....
Old Nov 3, 2016 | 02:37 AM
rns's Avatar
rns
then try again....
Thanks, I tried to fiddle with those preset buttons that day but nothing worked.
Next day when getting into car all was ok, I don't know what happened there.
I could think that if there is bad contact in wiring or connectors it could cause symptoms like this to appear and disappear.
Cut wire in harness, oxidation in connector??
Must keep alert if problem comes back.
jimisbell
Feb 6, 2018 09:35 PM
mdsty
Apr 17, 2011 01:32 PM
Da Hapa
Sep 30, 2006 03:52 PM
25cliffy
GX - 1st Gen (2003-2009)
Dec 19, 2005 03:04 PM
terrysc400
Nov 29, 2001 08:51 AM
