- MY RIDE! A Modified 2010 Lexus IS 250
- IS350 Thoughts
- VSC, check engine and traction control light went off
- Swapping Rims '16 to '07
- Oil change/Transmission fluid
- Suspension bushings replacement?
- New member. 2008 IS350
- IS250 high flow fuel injectors?
- Would this subwoofer system work?
- What do i need to know when buying this '09 IS250?
- Taped down connector in front driver/passenger door?
- New wide body kit from Clinched for 2IS
- 2011 + Grill Emblem Question.
- Purchasing high mileage IS350!!!
- No Sound after Rainy day
- Help!? IS250 Down, Need a picture of Camshaft Sensor Wiring
- What's the best setup?
- 2006 rear brake rotor replacment question. *pics*
- Request Info On Trunk Emblem Spacing
- Best oil for 90,000 miles on is350?
- Custom Bumper
- Pic Request: OEM f sport grill + hella horns
- Goodbye Club Lexus
- Lexus IS 220d - Eberspächer, right timer for it
- Smell and see fumes from fuel door
- Squeaky rattle near center air vents
- Stinky smell after turning off AC
- 2006 IS 350 - potential new buyer
- hot temps = auto crack open window?
- Wrong Lift Point Bent Rail?
- 2010 climate/radio compatability question
- Replacing MAF sensor
- Good Idea to Daily a Fiberglass Bumper?
- IS220d Differential Options
- Newbie, 20%-25% drop in City MPG, highway MPG good
- Windshield fluid reservoir help
- Replacing A/F Sensor for IS350
- My door pocket thing fell off.. Any fix?
- Steering rack
- A question for those of you who have run 20" wheels
- VSC ABS Brake lights on after installed 78works tail light.
- Place to get wiring diagrams?
- 2009 IS250 Automatic
- IS 220d rpm stay on 1,200 when heating is on
- IS250 carbon buildup - What works? What doesn't?
- Oil leak help (pics)
- 3IS F-Sport Steering Wheel on 2IS?
- Please advise!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
- Another headlights pointing down issue
- Help AWD IS250 front airbag rubbing steering knuckle
- Wald Style Duck Tail Spoiler [eBay]
- Weird problems
- 245/40R19 for front tires??
- Computer changes during my dashboard replacement??
- Changed out wheel hub and now ABS light is on
- Stock 0-60 on 350 AWD?
- My IS250 cuts off in park
- VSC Light On, CEL On (Codes P0300 and P0301) NEED HELP!!!!
- Lexus IS250 2009- hit me up
- ML Swap from an old to a newer one
- Beware - eBay lexmaniac2 - Original Lexus Parts - LED Headlights
- Where to buy touch up paint?
- HID from Xenon Depot
- Pulling Fenders
- Anyone know a logo to fit this spoiler?
- Warranty
- 2006 IS350, 103k mi, Alaska
- help on ebay lip
- tilt side mirror
- Anyone with Pics? 07 AWD IS 250 with 18x8 all round....
- What 18" wheels are best for 2007 AWD IS 250. Non staggered set up
- Why was there a big jump in fuel economy in IS350?
- Smoke When Starting up?!? MY2012 IS350
- Fuel Line Rattle noise under car
- Any vendors for Aimgain wheels?
- Replace Parking Light with LED
- Review of my F-Sport shift knob
- Winter driving IS 350 RWD question
- Front End Screeching Noise
- Steering ECU Calibration - Going Back to Stock from upgraded ISF
- Brake pedal possible stuck when starting the car / 2006 IS 350
- How To Install Rear Diffuser?
- TPMS lasted for 10 years!
- What Tires Are Best for my 07 AWD IS 250
- Help me with my GPS please :(
- Tilting mirrors
- Steering Wheel Diameter
- Good All Weather Floor Mats for RWD IS350
- Cannot Adjust Headlight Aim
- Just another IS350
- Headlight ballast issue
- Lexus IS250/350 Trim/Packages HELP (06-13)
- Questions about daily driving a 2IS
- Upper Box Intake
- Tensioner pulley whole assemble AWD different to RWD ?
- 2008 Lexus IS250 F-Sport
- 2008 lexus is250 f sport car wont start
- Low dust pads
- Bulb Fell Into Headlight Housing!
- Sold my 2006 IS250
- Need advice on winter wheel setup
- AC Not Circulating and Bad Smell in the Car
- Do these LED bulbs fit for my side under mirror puddle lights?
- IS-F Headlights Fit IS250?
- Windshield Delamination
- Correct Plastic Engine Clips?
- Does any one know of a quality brand of headlight housing for my IS250?
- I need help with finding the right pair of headlights for my IS 250 2008
- IS250 AWD Automatic transmission problem
- Found a set of OEM headlights that are almost brand new. Whats a fair price for them?
- What Temp to Check AT Fluid '09 IS350?
- Help Cusco front sway bar for IS350
- Pic request: vertex front and sides and ings rear?
- Check Engine light and "TRAC OFF" Signals
- Air Conditioning
- How-To Tuesday: Replacing Your Tie Rod Ends
- Replacing seat bottom
- 2007 IS 250 Unpredictable shifting/hesitation
- Inner CV boot tear
- Engine Ticking When cold? ( With video ) Help Please
- AC Servo problem?
- 2009 IS250 to 2011 LED DRL Headlights
- IS250 won't start, please help...
- Pic request smokey mica with a matte black or cf roof?
- Repainting Lip
- 2011 Lexus IS 250 AWD
- 2008 Lexus IS250 Engine Noise
- Rear bumper
- Headlamp washer cover
- 2007 Lexus IS AWD Carbon Issues
- Where can I buy 2011+ spec headlights that fit an '06 IS350?
- Key troubles
- G Spyder Wheels forged
- AC not cold when hot outside
- Warranty
- Fuel Filter Replacement
- Upgrade-itis, is it normal?
- Southern California Lexus Owners Meet Ups??
- 2010 Lexus IS 250 - Air Bag Light
- Custom built ramps
- IS250 6MT Non-OE Transmission swap.
- Rear Brake Pads Look Wrong!
- How much longer will my car last? (IS 350 2007)
- Anyone run the 1/4 with tune yet?
- Where is a place to get rims??
- Coin Holder Install
- Anyone notice ride difference between 18 and 19 inch wheels
- Replace Mark Levinson sub or go aftermarket?
- Manual Transmission grinding in 3rd..
- ISx Seat Upgrades?
- DIY: for replacing Tensioner pulley arm on 06-13 Lexus IS please ?
- 07 IS 250 AWD vs 08-12
- Did Lexus Change The Maintenance Schedule on the IS?????
- IS350 Trans Fluid Exchange
- Wheels FTLOG
- Post Any Good Race You've Had!
- Center Console Trim Replacement
- Black Logos + new member !
- The lazy man's smart phone dock mod
- Aftermarket Steering Wheel - functions?
- 2011 IS250 Tail Light Swap
- Does anyone knows what caused that on my spark plug?
- IS 250 - whining noise
- What brand and size of HID do i need?
- Automatic Transmission Slipping 1>2
- Need some help transmission shifts
- delayed/hesitation while accelerating from a stop
- Should the rear shock bolt have some play?
- Rear Brake Pads
- AIT /se tuned rear canards installation
- Notch inside door for bike roof rack??
- What's making this noise?
- Rear Shocks Help
- Flat Tire twice a year! Headlight issue &More
- Ideas wanted for steering wheel design
- thinking of buildin 4gr/2gr -fse hybrid motor
- Header Question
- Popping sound when I hit the brakes
- Limited Slip Differental more observations.
- seafoam question
- Lexon front lip?????
- No sound through stereo
- Help with new car (Headlights)
- Fitment on a isf style rear bumper
- Engine Using Oil-Will Engine Need Replacement??
- Free Door Panel
- Cannot turn off the alarm
- New to Lexus
- Low pulse shake in car with AC on
- Continuous vibration throughout my car
- front footwell light
- OEM Lexus IS250 AWD All-Weather Floor Mats
- Ez bunny kit!?
- IS250 blocked cabin filter
- 2nd Gen or 3rd Gen
- Water in gas tank
- VSC Light + ABS, Brake, and Traction Lights
- Should I be worried?? Help!
- (Small) modifications or additions to your car that enhance experience
- What's this error code say (Japanese)
- 2008 IS 250 Navigation Screen completely black. Calgary Canada
- 2007 IS300 Automatic 4th Gear Problem
- No electrical power, can't figure it out
- 07 IS250 Spark Plugs
- 2006 IS350, 151k miles, good or bad buy?
- Growling/Bubbling Noise from under car/Exhaust
- 2007 Lexus IS250 LED lights
- Interior swap from tan to black
- 2007 IS250 acting up...
- Pic Request: 18" SSR SP3 on a 2is
- '06 IS250 amplifier circuit board diagram?
- Aimgain rear lip
- 2011 IS250 Radio Problems
- Exhaust tips that look similar?
- A/C issues... Typical
- Install ISF 201x Headunit on 2006-09 IS350 ML?
- Lexus corrosion warranty
- Starfire Pearl (077) OEM Touch Up Paint vs. Others?
- Need help a.s.a.p - Buying IS250 in two days
- 2012 IS250 Modification Suggestions
- Starter removal.
- IS250 part out in Dfw area
- Sound while shifting gear
- F-Sport Grille
- My (new to me) 2011 IS350 F-Sport
- Front fender liner clips
- Question about everyone elses stereo volume
- Best Salvage Yard for a new Gauge Cluster
- Tranny question
- Using defroster for a prolonged period of time
- Driver side rear squeaking when turning
- Clicking sound from engine area
- Potentially buy a IS250... need help
- Cluster Removal - Stuck
- Headlight Indicator on Dashboard
- 2012 Lexus IS250 rear bumper help!
- Oil Consumption / Occasional Rough Start
- Lexus IS250 Tungsten Pearl front end help
- Is this aimgain?
- Front lip install help!!!
- Help repair scatches to my IS350 leather seat?
- finding a rear spoiler
- No electrical power, weird. Please help!
- Clarification on TSIB for Cold Start Rattle
- 06 Lexus IS250 Help! [Looking for plastic cover over oil filter housing]
- What wheels for a black onyx IS350?
- headlight does not turn on lights On lexus is 250 2008
- 60K Mile service cost $$
