AC not cold when hot outside
Old Aug 31, 2016 | 08:46 AM
ShoFly's Avatar
ShoFly
Default AC not cold when hot outside
In mornings my AC can get quite frigid. In afternoon when it's around 90 degrees it will have times where it doesn't work. Yesterday I kept hitting the AC button and it appeared to sound like it was kicking in, but no cold air. This morning was cold. Auto is not turned on.
Is this evident of compressor issue, or a leak? Or just a recharge? Would like to have a little idea before I put it in the shop to hear what they say. Thanks
Old Aug 31, 2016 | 09:54 AM
kickin8's Avatar
kickin8
2IS/2RX/4RX
you can do a visual compressor check - do a recharge if the compressor is working
Old Aug 31, 2016 | 09:57 AM
Zmon's Avatar
Zmon
Does it eventually get cold? When it's 90 degrees out, and the sun is beating on the car all day, it'll take a couple minutes for the plenum to finally cool down so you begin to feel cool air.
Old Aug 31, 2016 | 02:30 PM
355F1's Avatar
355F1
Not like you'd expect. This is the weakest a/c I have ever had in a car. And I've had it since new. Plus I live in Arizona.
Old Sep 2, 2016 | 09:39 AM
Skier76's Avatar
Skier76
I had a similar issue this summer. The A/C works great most of the time. But it feels a bit weak on those days when it's in the 90's and humid out.
Old Sep 2, 2016 | 10:27 AM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
Must have a defective unit. I live in 40C-45C (average) summer temps, and my AC works just fine. I leave it at 25C and it keeps the cabin cooled just fine.
Old Sep 2, 2016 | 11:11 AM
355F1's Avatar
355F1
I have had it tested multiple times at 2 different LExus dealers.
Old Sep 2, 2016 | 02:47 PM
TimboIS's Avatar
TimboIS
Liquid Bra Champion
No need to go to more than one dealer, as the second one will parrot the first, since it's in the system. Sucks for you. I live in hotter climate than you, and mine works just fine.
Old Sep 3, 2016 | 01:44 AM
DennisMik's Avatar
DennisMik
Unless the trips you make are too short, the a/c should do OK. I have had cars with better a/c than the IS, but the IS is adequate. In fact, I also have an RX that cools down quicker than the IS and the interior space in that beast has to be at least 3 times the IS.
parallon
Jul 12, 2014 02:47 AM
Pogigreg
Jul 28, 2011 03:38 PM
svlexus
Mar 28, 2011 07:47 AM
toyofreak
Jun 1, 2010 11:59 AM
jami1
Mar 10, 2010 02:29 PM
