Oil leak help (pics)
Old Sep 23, 2016 | 07:01 PM
HankMoody's Avatar
HankMoody
Default Oil leak help (pics)
Guys,
I was installing my F-sport front sway bar, I had to remove the engine cover under the car and noticed this. Anyone else had this problem ? It looks like its coming from that banjo style bolt. Passenger side, 06' IS350
Old Sep 23, 2016 | 08:04 PM
lysis250's Avatar
lysis250
I've had that issue, go to the dealer get a new washer and problem solved.
Old Sep 23, 2016 | 08:24 PM
HankMoody's Avatar
HankMoody
What's the torque on the bolt ?
Old Sep 23, 2016 | 09:28 PM
lysis250's Avatar
lysis250
No clue, I just hand tightened it until I felt it was enough. I'm sure the parts guy can help you out if you want the torque specs.
Old Sep 24, 2016 | 09:17 AM
HankMoody's Avatar
HankMoody
Here's what I found, I hope this will help other members in the future if this problem arises. I just went to the local Toyota dealer with this diagram, I went ahead and got both, the upper and lower washers. Was about $10 in parts.
Old Feb 14, 2017 | 06:50 PM
mitsuboost's Avatar
mitsuboost
HankMoody are those oil supply lines under any pressure? I highly doubt itdue to the banjo style
Old Feb 14, 2017 | 06:59 PM
Gville350's Avatar
Gville350
Probably minimal while during operation, and none when turned off. Why, yours leaking too?
Old Feb 15, 2017 | 04:34 AM
HankMoody's Avatar
HankMoody
More than likely just oil pressure.
Old Feb 15, 2017 | 04:41 AM
HankMoody's Avatar
HankMoody
Oh and just an update.
I recently changed my oil and have been keeping my eye on that repair, so far it's dry as a bone.. Easy fix.
Old Feb 20, 2017 | 10:51 AM
mitsuboost's Avatar
mitsuboost
Yes mine had alot of oil gunked up on it. Also the valve cover gasket was leaking. gonna replace both of those and monitor it to make sure it's nothing more than that...my biggest nightmare is the timing leak 121k on the dash gulp.
Old May 20, 2019 | 09:02 PM
carlospen2's Avatar
carlospen2
Default Same issue
Guys,
Im having the same issue whats the best way to get this out from top of the engine or bottom?
Old May 21, 2019 | 02:13 PM
Gville350's Avatar
Gville350
With the upper plastics removed, one should be able (with the right tools) to be able to work this repair from the top.
Old May 21, 2019 | 03:09 PM
carlospen2's Avatar
carlospen2
Cool yea dealership told me it could be the leak from the banjo or timing cover. After cleaning it it looks like its the banjo so im hoping thats the problem.
Old May 22, 2019 | 01:59 PM
Gville350's Avatar
Gville350
For your sake I hope that's the issue, because it is QUITE an expense and labor intensive to fix the timing cover leak.
Old May 22, 2019 | 04:16 PM
carlospen2's Avatar
carlospen2
Yes ive heard but luckily its still under warranty so thats why im trying to figure this leak out as soon as possible
