- Is it possible HID fogs are causing my electrical issues?
- Navigation question - any way to keep road detail on screen when zooming out?
- THEORY ON FIX 4 WOBBLE ON LOWERED AWD's
- gs300 awd - brakes
- Anyone ever seafoamed your 3GS??
- 194 360Led issue
- Aiming Headlights - Adjust knobs
- Temporary Wheels.. 22's =]
- weird sounds after getting new tires..
- New...intro
- Carson discounted parts shipping code (For you Americans.....)
- intake filter replacement
- New 06 GS300 AWD need new tires
- will vossen wheels rub?
- Custom 07 lexus gs
- Thinking about Getting back into a Lex
- bluetooth audio with iphone 3GS
- Droid Phone + 2006 GS300 Bluetooth?
- Finally Dropped on Iforge
- Winter tires
- quick question on chip rocks!
- New 2011 GS350
- Wheel Question
- Hey guys, need some help with Low tire sensor and auto windows
- Thats messed up !!!
- Squeak and Rattle
- Nitto Tire on Facebook, LIKE to win tires
- power folding side mirror question
- Goodbye Mark Levinson
- Bizarre electrical problem - car stuck
- Newbie with cool mod
- how do you get the drl to match the 6k hids
- ? for 06 GS430
- Newbie Checking In.
- Compressor Runs and Popping Sound
- Audio not working
- 3GS dash alignment issue on my 2007 and the new 2010s as well
- Not a good way to start off Halloween weekend
- Interior lights
- My 3GS and the hot air balloons : Part II
- gear box, dash heat up?
- how many quarts of engine oil....
- New member intro
- Oil Leak
- HID fog lights... who has them?
- Will these wheels fit?
- Further odd mods.... opinions
- how to use seat adjustment pre-sets?
- 2008 NAV w/ ML
- Need Help - Re-installing rubber trim under hood
- pics of my new rims
- help help help.....
- Winter Floor Matts
- Console creaking finally fixed.....by me
- As Halloween approaches,...
- 3GS430 check system issues, please help!
- How Much did you pay for your 3rd GEN?
- Lighting help.
- New personal dropped car tire wear record
- B-Pillar replacement
- Newbie saying Hi!
- Need rotors recommendation..
- Interior Wood Trim Swirls...
- Sirius Radio - Improve Signal Strenght?
- DIY - Trouble with door jamb sensor solved.
- 06 and 07 awd front struts. any aftermarket?
- Glad the Run-Flats are balding!!
- HELP - Headlights On When They Shouldn't Be
- GS300 Power Steering Lines???
- Rattling at start up of car
- Vaistech ML Plus - looks promising
- 2006 GS300 oil question
- 2011 GS350 - Semi-aniline leather, Standard?
- 2010 GS 350 Diesel Noise
- G-Spiders open slot
- I want to install a new throttle body to restore car to original performance
- storage question
- Bottom door weather seal part #s?
- Check VSC + Check ECB +
- Upgraded from 2001 GS300 to 2007 GS350
- Screen keeps turning off...wtf...
- XM install
- New GS350 Owner
- Sidemarkers?
- Another Lexus Toyota Recall (10 million Vehicals), are we effected again
- clear bra on dark color car
- GS300 Maintenance Question
- Replacement GPS Module for Overseas?
- Nice Surprise: I have a VaisTech
- Remote fob battery low warning
- Airport Pics 3
- Are these good deals? 07 GS350 vs 07 GS450h
- Using fogs as DRLs?
- Would you purchase another GS?
- Rough week for the GS
- Powertrain Warranty Extension to 100K miles
- Siris radio
- ANOTHER HEAD/FOG problem !!! help!
- can you change the daytime running lights?
- New rotors @ 60K...normal?
- PollTime!!! Will the 4GS keep its quad lamps?
- Interesting....
- GS300 AWD.... Please Helppp!!!!!
- RECALL: 2006 GS300 potential brake fluid leak
- Change the color of the cover and the brakes
- Lexus 22 inch rims staggered WILL THEY FIT?
- Anti-freeze coolant is always low in reservoir
- Baltimore photoshoot
- truffle mica
- Easy way to upgrade the ML amp and sub?
- Used Headlight Assembly Advice Needed!
- Possible purchase
- Auto Door Lock
- Valve Spring Recall Response
- Getting the GS ready for the Autobahn
- Best Solution to My Issues?
- new rims on my 06 gs300
- My Impressions: 2006 GS 300 AWD vs. 2010 GS 350 RWD
- Clicking noise....
- New 3GS owner.
- 3GS Steering Assist Options?
- will i need an led decoder if i change the daymtime running lights to led?
- Service Info on GS450h
- Hi, would like your opinion!
- Got Locked Out of GS350
- How do I get to back of radio to install ipod connector?
- Car still drove without key card in vehicle
- Missing Lug Nut Lock
- new paint job for 07 Lex GS
- New guy saying hello
- Which brake pads?
- First to mount an iPad in a 3GS :)
- Best place to buy Lexus 10.1 DVD
- new question.... will 08-09 front bumper fit 06-07 model gs
- Back In The Game
- Did you get your gas tank topped off with valve spring replacement?
- Need help on steering fluid...
- i need spacersss!!!
- Lexus Wheel Coming Off While Driving?
- Wish me luck guys!!!!!!!!!!!
- 2011 GS350 AWD vs RX350 AWD
- changing daytime running lights 9005
- New Flat black spray on roof!
- Crooked steering wheel
- 20x9 20x10.5 +25
- Just gotta vent!!!!
- does anyone know if the stock nav system have audion inputs for a subwoofer
- Question with watching movies thru grom or vais?
- Need Replacement Front Windshield
- New to Lexus
- Goodbye Acura! Hello Lexus GS350 AWD!
- Aftermarket Headlight Xenon HID bulbs for 07 GS350?
- A few new additions
- 10mm Spacer Question
- Observations from the OC!
- Steering wheel really is wood...
- 2010 GS 350 - Engine Air Filter
- DIY rear brakes for 06 gs 300 AWD?
- will any dealer do valve spring recall?
- new wheels
- Nav map dvd question
- Rear view mirror appearance TSIB
- Hard Braking Causing Engine Shuddering
- noise around the dash? Nav voice speaker problem?
- Power Steering Problem?
- Airfreshener compartment?
- 2008 GS350 28K Miles - $30K
- Plastidipped OEM Grille
- Does anyone know what size the speakers are located in the door?
- Bent Concave wheel..need help around nyc area
- need help foglight mod???
- Keeping in clean......for now. (PICS)
- Engine power decrease after dealer cleaned throttle body
- Thud sound from the engine/motor
- Got Car Back From Valve Spring Recall And....
- Apsss
- AFS light blinking.....
- GS430 Spark Plugs Parts #?
- AFS, ballast, or light issue?
- 2006 GS430 0-60, 1/4 mile times?
- Windshield wipers - won't go all the way down
- Next mod!
- Weird key fob story
- Adding XM to 07 GS450h with ML
- "Supposedly" the new 2012 GS shots...
- Wanted - Rims for my GS 350
- Are there any Lexus universal TPMS?
- Bluetooth streaming music is awesome!!!!!!!!!!!!!
- Tires...I know I know
- How much for 2008 GS350 AWD CPO car??
- grille question! does it fit
- Gs300 brakes?
- Trading my 09 GS on a 2010 Acura RL
- Chrome door lock knob upgrade
- 2006 GS430 Diagnostic Tool
- iPad mounting ideas in a 3GS?
- CD track issues........
- Product Warning Nokya Hyper-yellow Fog Bulbs
- Non-Trackin' GS's @ the Pursuit
- light vibrate on idle..
- Hi! to all fellow GS owner!
- Weight of wheel - GS430 18"
- Does lexus CPO follow the owner or the car?
- Need Help Please!!!!
- cracked windshield and headlight cover replacement...
- Plastidip Emblems - Matte Black
- Side Rearview Mirror Auto Tilt
- Trackin' GS's at the Pursuit
- Shaking/Pulsating when driving on gravel, AWD?
- what other cars share the gs wheels offset and spacing
- Need Advice - rearview mirror shakes
- Just got my new GS, looking for help and ideas
- I want to welcome myself to gs family :)
- 2006 GS430 rear license plate LED
- 2010 GS350 catalytic converter/throttle ??
- auto-lock when remote is not in range
- He went from ashy to classy!!!
- Mini-mod
- Who is better
- My New GS!
- 2007 GS350 RWD Brakes & Rotors
- Air duct joint in middle console
- New GS450H owner... Need radar detector!
- Uh oh, have a seat!
- Looking to buy GS350 or 450H
- is350 aftermarket intake to a gs350 question?
- smell at cold start?
- HELP: XM INSTALL Parts Question
- Both 12v ports dont work!
- 1 brand new HID - broken
- Heads up display for 3GS
- Sold the Acura TL and bought a Lexus GS 350..What a CAR!!!
- What grille is this? (NWS picture)
- paddle shifter steering wheel
- load index for tires
- Eibach + MRR GT1 19's + Ichiba 10mm = Rubbing!
- Thinking about getting new shoes
- How do I keep the audio screen up without having to push the button?
- Touchnig up front bumper?
- gs350 valve spring recall
- "afs off" light blinking
- TPMS "Check System" - Gah.
- 2006 GS 300- Doors locked, 3 windows down
- gs300 oem hid issue, help please
- Toshiba/Phillips HIR1 light bulbs.
- 2007 Lexus GS350 - Good price?
- +39 + 10mm= what offset?
- Best ipod car dock for an ML 06 GS300?
- sat radio
- What 1st coils or wheels?
