Sidemarkers?
Old Oct 22, 2010 | 03:42 PM
BLu_Gs3's Avatar
BLu_Gs3
Default Sidemarkers?
Anyone has them installed on their GS? How much did the body shop charge you?
Old Oct 22, 2010 | 04:25 PM
ReyRey305's Avatar
ReyRey305
ive been wanting to put side markers for the longest time now... Let me know if you find out please...
Old Oct 22, 2010 | 07:52 PM
BinaryJay's Avatar
BinaryJay
Do you really want them cutting into your factory panels and paint jobs for side markers? That will be the weakest spot on the panel and will be very prone to be the nucleus of rust.
Old Oct 22, 2010 | 08:09 PM
dunnojack's Avatar
dunnojack
not if you paint it well.
and isn't there a rubber backing to the sidemarker as well, so that should seal it
Old Oct 22, 2010 | 10:18 PM
slk_dds's Avatar
slk_dds
It should not cos more than $100 for any motorsports shop to installed the sidemarkers; drilled, sanded, cleaned, primed, and touch-up paint the areas before the final installation of the sidemarkers.
Old Oct 22, 2010 | 11:45 PM
rominl's Avatar
rominl
exclusive matchup
agree, that would be the price i shoot for
Old Oct 25, 2010 | 12:57 AM
arnieosp's Avatar
arnieosp
None of that is necessary if they know what they are doing. To avoid all of the above, they will place several layers of masking tape on the fender, draw an outline of the hole on top of the masking tape, then drill the metal through the masking tape. No paint damage, all you need to touch up is the exposed metal edge inside the new hole.
Old Oct 25, 2010 | 05:02 AM
IXI187IXI's Avatar
IXI187IXI
exactly, no need to do all that other work
Old Oct 25, 2010 | 12:14 PM
1STLXS's Avatar
1STLXS
I had them installed but it was all part of the installation of my body kit and the car was completely painted. Someone mentioned drilling the fender but actually with the side markers I got you had to cut the fender. The side markers have two plastic clips that lock into the fender wall so you pretty much have to cut the fender the shape of the marker but with a smaller opening so the marker sits snug and then there is the wiring to make them functional. So your talking about more than just a couple of hours of labor. At say $50.00/hr you could easily look at $200.00 (2 hr per side) unless you do it yourself.
MasonGrey
Jun 3, 2016 09:36 PM
jerryray
RX - 3rd Gen (2010-2015)
Oct 14, 2011 12:32 PM
