- 2006 GS300 w/ 303k Miles
- just relaxing
- Thinking about coming back to Lexus GS family
- Where to get a quart or spray of lexus 1F2 paint?
- Wipers make one rotation immediately upon start up
- Steady Drip in SunRoof
- Anyone with 2006/2007 Gs300/Gs350 wheels painted?
- GS450h on RCF Wheels (20 spoke)
- Transmission drain/fill needed; know of any good indy shops in NY/NJ/CT/NEPA?
- 2006 GS450 h Check PCS System + Warning Trainagle Light
- GS430 body kits
- wow gs350 faster than a ls460
- 2007 GS450H Battery Question (OEM Panasonic/ Aftermarket Options)
- Drip mold clips for rear window
- JoeZ Pipe - Lexus GS300 2006
- new rims need help?
- any spindle style front bumper for the 3GS ?
- Rear View camera override?
- Should I Buy The 08 GS460?!
- 3rd gen buyers guide GS300
- Bumper yellowing questions
- Cannot Find Used GS 460
- GS430 police chase . Must watch.
- Advise needed GS350
- Exhaust: Lexus GS300 (2006)
- RACE : GS430 vs E46 M3
- Finally took some pics
- Door "clicks" twice when opening and closing
- 06 gs430 blown motor?
- Headlight Bulb
- What to look out for in a 2011 GS350 AWD?
- Tyre Pressure Issue
- 2006 GS300 Hesitates from stop
- IS350 Rear F-sport swaybar on GS350
- Ebay roof spolier?
- What paint is for our OEM rims?
- Help lexus gs460 2010
- I need help!! -- I need a Headlight Moisture/Dust Cap!
- 2007 gs350 exhaust delete
- Need Help - Battery has power but no power to dash or car
- Are the 06 GS3s really as bad as they're made out to be?
- Errors! P0031 P2195 P2238 P0137
- Slight vibration at idle
- Rubber seal between doors peeling off?
- How hard would it be to swap 450H grille on '06 GS350?
- Turn off oil change light on gs 350
- Question about GS wheels on my LS
- Turn Signal
- Paint for 3GS 350 silver?
- paint problem?
- Stock Lexus Wheel Chart?
- Just installed Sage 25mm RCA blocks on 08 AWD
- Clanking sound from Front end on 06 GS300
- GS 300, What Transmission ?
- "CHECK VSC" and "CHECK VGRS"
- Toyota meet in colorado
- Radiator flush
- Should I buy this GS 450H?
- New shoes for the gs!
- Head on crash 08' GS 460, no airbags deployed?
- tranny vibrate? struggle to change gear? 3rd to 4th?
- lexus tire and wheel warrenty ,got approved
- Detailed video of powdercoated wheel
- stupid side mirror position bug?
- First time running Staggered setup on AWD
- GS300 audio upgrade - easier starting with an ML setup?
- Is anybody getting their fuel filled at the dealer while this recall is getting done?
- Need to replace drivers seatback
- Interior Lighting Questions
- 3GS Headlight Eyelids???!
- Brake Upgrades
- Replacing with Denso TPMS for 2008 GS350
- Advice needed please!!! :)
- anyone here with 07 or 08 still on original panasonic battery?
- Amp issues
- Rear Brake Caliper Mount Bracket?
- TPMS ID Code format
- (FS) VAIS MultiMediaLinQ VML ipod support
- part number for rear deck cover
- Help replacing corner amber light bulbs - 2008 3GS
- ALexus GS 450H on Verde Parallax Wheels
- 2006 gs300 p0430 cel
- Rearview camera
- Tint shop cracked my bumper! bad sensor!
- Just bought a 2009 GS 350 AWD
- Help! Should I buy this used Lexus?
- anyone know a good 6000k bulb to match my DRL?
- Need some help (VaisTech iVic & rear camera)
- Low tire pressure light on?
- GS350 Paint Repair
- Is it enough to reset the computer by disconnecting the negative terminal battery?!
- Clock Stuck 2006 GS300
- Sport Mode --- 2006 GS430
- Problem starting and now CEL and VSC off!
- Check vsc and check engin! Any help :)
- Cant lock car when its on with keys?
- Lexus GS450h 12/2007 Cold Engine Rattle Sound
- Thinking about getting a GS430
- My extended warranty just paid for itself.
- 2006 lexus gs430 shocks? same as gs300 or gs350?
- Any members installed 9006 Xtreme HID fog light kit on the 3GS 350 plz share
- Codes: C1391,1522,C1776
- New Spark Plugs for '06 GS 300 - $247 Good Deal?
- Passenger airbag OFF illuminated with heavy passenger in seat
- Is this a good deal?
- Fan working loud, Required radiator replacement
- Just installed rotors, rear brake pads doesnt touch the whole surface?
- Removing 3rd brake light
- Widebody ONESTAR GS350 AWD
- Spc rear camber arm?
- 2006 Lexus GS300 Mobil1 oil filter size
- 2006 gs300 engine recall
- Remote doesn't work properly
- 2006 gs300 headlight questions
- 2006 GS reverse lightbulb replacement question...
- My New-To-Me 08' GS350 AWD: First Road Trip (pics, q's)
- reset the oil maint reqd light on a 2011 GS 460
- Squeaky Dash or Suspension
- Tranny fluid change shops in Brooklyn?
- Need advice - warranty expiring
- wheel offset
- My New Baby!!!!
- awd gs300?
- cant get rotors off???
- 2006 ML AMP wringing diagram
- Gas smell on 08 gs450h
- Accuair E-Lelvel Sensor Install
- HID Fog Lights Installation
- 2006 GS300 Replaced battery. Need to Pair back to car.
- Which 3GS one should I get
- wheel locks for 19" f-sport rims question
- TPMS Issue and nobody can find out what or why
- 2007 gs 350 Good buy?
- 07 gs350 mark levinson doesnt sound that good? No bass?
- FS and WTB threads go in the classifieds please
- '09 460 W/ ML Stereo. Can I upgrade?
- Climate Control Blower Motor Issue
- Sunroof shade does not retract with glass?
- 08 GS 460 3rd brake light camera?
- What other cars will 3GS BCR Coil overs fit on?
- What kind of Lube do I use for caliper slider pins?
- Frozen rear caliper
- 2006 GS Garbage??
- Had a Blow out TPMS check System on
- I think I just got the GS300 totalled. See what you think.
- Possible vibration solution for lowered gs
- Headlight ballasts
- GS460 front shock issue
- Engine Noise & Vsc light
- DIY : painting rotor hubs
- hissing noise when hitting the throttle?
- just got my rotors from rock auto! Power Stop rotors & pads
- TSW Bathurst Wheels, anyone fitted these yet?
- Tire Cupping, Thumping, Vibration 152k
- 2006 Gs430 Command screen update?
- tire size differences
- Rear tire wear GS350
- 06 gs300 timing chain waterpump question.
- Mildew smell from AC
- Interior swap
- 2008 Stock Wheels Refinished - Need Advice
- how to adjust AFS lights low beam to low.
- Headlight / fog light one works and one doesnt. Odd?
- Alignment issue?
- +1 ings kit fitment
- engine gone ,gone
- navigation screen help!
- Navigation Disc Location ??????
- Ride Tech Ride Pro E3 Vs Accuair ????
- Walnut blasting
- Side Mirror Auto Tilt in Reverse Question
- bought a new torque wrench... It was already set to 9?
- Where to buy LED bulbs?
- Looking at 2007-2009 GS. How to identify options?
- How do i get ABS to kick in? tried from 30mph-0 quick stop...
- Need Help with a interior Light!!!!!!
- 2011 Design Question
- New Member + Problem
- 5W 30 or 5W 50?
- fan
- Hey 3GS people! What brake pads do you use?
- Scraping sound left front tire area. Help
- 2011 GS350 headlights adjustment - HELP!
- Ticking noise from back end of roof - solved
- What size if the brake bleeder? Brake pedal feeling light like always....
- 3GS retrofit ISF steering wheel with paddle shifters
- need some help on brakes GS300
- Who's GS? Unsafe driver? (DashCam video inside)
- 06 GS430 at 106,000 miles, should I change the timing belt?
- DIY- IS350 steering wheel swap
- VVT Rattle back 1 year after Repair anyone else?
- Brakes issue
- How rare is the 2006 GS430?
- Rdl lights
- made a few changes...
- Lowered and tinted!!
- Rear fender mods
- GS430 oil leak help!
- Hi everyone
- Sun roof
- my car gs430 had problem
- Should I BUY this 2006 gs430 ?!?
- Wheel/Offset Help
- where to buy lug nuts? 3GS 350 07
- problem with 20s set up
- Front camber kit 3GS
- LED D4S Headlights Installed
- Has anyone purchased Power Stop Rotors and Pads?
- Door lock at 10 mph
- Injen on my engine
- Wheel decision
- Need some help... Wheels fitment!
- New GS owner from Tampa, FL.
- Time to replace pads and rotors
- Bought a GS430!
- brake upgrades
- Will these work ????
- 2013/2014 GS/IS Rear calipers will they fit on 3GS?
- can anyone confirm the RWD struts will not fit AWD ?
- DIY rear pads and rotor replacement
- heater/AC issue - HELP
- dropped and alignment
- Build up on exhaust tip?
- Broken Carson tuned front lip, looking for options
- Sparkplug changed
- Car won't start, lights won't go off
- alignment on a sage kit
- Sage Sunday
- what are some GS350 AWD lowering problems?
- Help Radio Issue
- Who makes the loudest exhaust?
- What should I look out for when buying a 3GS?
- lug nut key keeps breaking?
- Maxlux hid bulbs
- Gs350 tape player keep ejecting?
- New Wheels on 06 GS430
- Where do I find body kit that fits?
- change the color of my car
- Dash rattle '11
- Gonna Race my mate - Liberty GT
- DRL Fuse Location and what amp fuse
- 10+ Lexus RX cup holder for GS?
- REAR Sunshade - Visibility Issue
- might need to replace the front windshield on my 07 GS 350, thoughts?
- Completely ripped off at the Dealership (don't ever do extras in service)
- 2006 GS430 Coolant Issue - Air In System?? PLEASE HELP!!!
- Uk Newbie needs some help on Wheel size / offset
- 2006 lexus GS 300 Windshield Wiper Replacement
- Custom GS300
- Tire side walls wearing faster than the middle?
