- Greddy evo3 gs430/is350/is250
- RWD Snow Handling Concern
- Excited
- AFS Light popped on
- Engine Ticking
- Bad day.
- Strange wobble at high speed
- ABS rear sensor 3GS
- Bad Day
- Limited to gen 4
- How long will she last?
- All clean for Matador Red Mica Monday!
- 2006 GS430 shift kit?
- 2010 GS350 AWD tire issue/wear/question
- Thoughts on Stance wheels?
- Changing Transmission Fluid ***DIY w/ pics***
- 06 GS300 Y-Pipe replacement?$$$$
- Hd Radio Display
- TPMS issues
- gs350 no nav convert to nav?
- Gs 300 awd wobble ,yet again
- New head unit(radio replacement) and other questions
- Has any one changed catalytic converters on 06 gs430 p0420 p0430
- Gs300 stereo promblems!!! Help!!
- Rims refinished -- results are blah
- on a roll.. rear calibers seized
- black scratches on rear view mirror
- 0W20 oil in 3GS?
- GS430 Aftermarket Subwoofer
- Request! 3GS Lowered pics! AWD ONLY!
- Emblem part number help?
- My First Lexus (bought today) - Lots of Issues (2006 GS430)
- VIP Modular GS300
- Just washed
- Finally Back at Lexus bye BMW
- how much would you sell your stock rims w/tires??
- Rub marks on seat from belt loop - GS460
- Vais bluetooth audio stream
- O2 sensor Bank 2 Sensor 2 out. Need Help with Denso part number.
- 2006 GS430 -- rear brake calipers seized? CPO?
- Boring!
- Family Lexus
- 2010 GS350 question?
- Finally got the wheels mounted...just the beginning.
- Vossen Wheel Fitment
- Test drove LS460
- Puddle light help. One side brighter!!
- Rear window sunshade, GS350
- New GS460 owner
- 3g awd staggered tire size help
- 90K mile question and a pic!
- exhaust tips
- Plasti-Dip ???
- Anyone ever remove their drip molding?
- Gs350 megan mid pipe
- 2006 AWD exhaust system
- New tires: Continental Control Contact Sport (w/ pics)
- Cigarette lighter fuse?
- Uploading pictures.
- Changed cabin air filter NOT on recirc -- what are consequences?
- P0430 Catalyst System Efficiency Below Threshold Bank 2
- Quick lug nut/wheel locks question
- Rolling rear fenders
- Air Intake Question
- '10 3GS Oil Smell Gas
- Online repair manual
- High beam/DRL light
- GS350 Transmission leaking
- Gs 350 side mirror glass
- What to consider or base your decision on when purchasing a 3rd Gen GS
- Backup camera alignment?
- LFA 19s on my GS350
- Anyone running 255/30/20 on front
- AWD Worth it?
- GS300 AWD Invidia Intermediate Pipe
- 2007 GS 350 Door Hinge Problem
- 3GS custom LED tails
- Can you see the ground through the top of your engine bay?
- Possible issues w/2007 gs350
- Ride height snesor
- Looks good to me!!
- Using oil
- Gloss Black or Black Chrome exhaust tips?
- Awd replacement tires
- 4gs intake on 3gs
- Secondary induction filter
- Check system, tire pressure light, p/s, brake,abs, check engine lights on
- Has anyone actually cleaned the TB?
- Which Vaistech Model?
- Looking for advice with poss gs430 purchase..
- Questions after SWAP and supercharger
- Headlight is focusing down how do i get it to focus further out
- iSimple issue
- Any issues running 235/45/17 on stock 3GS wheels? Anyone done it?
- Anyone do a 06 GS300 alternator rebuild
- Proud Lexus owner
- Lowering Blocks Question
- Wife Strikes Again
- crc maf cleaner-any negative experiences?
- 2006 GS300 Engine Won't Turnover
- 08 GS 460 Jittery Lights
- GS350 Exhaust
- In an accident today,
- GS450h or GS460 which one to get?
- Car burning oil
- Help On Parts
- "Random" Easiest color car to keep clean??
- Spare key fob no longer works, Buy new one or can battery be replaced?
- New 2011 GS 460 owner checking in
- gen 4 maps update
- 2007 gs350 new owner
- Philips Ultinon D4S 6000k (PICTURES)
- Replaced wiper blade inserts -- still streaking
- Need help buying my first GS350
- Need tires for my wheels.....help!!
- Bluetooth issues Samsung phones with Lexus Gen 4 navigation units.
- Proud, New 2008 Obsidian GS460 Owner!
- thread closed
- my engine rebuild for free
- Help Guys!!!!
- Rearview camera for Non NAV 2006 LEXUS GS300
- Is Tape Deck Shot?
- jaguar rear tables
- Sync Android (Galaxy S4) with Lexus GS350
- My Car is Bagged Finally!!!
- Damn salt truck threw salt and rock at my car
- GS460 Roll Call! The Few & Far Between, Unite!
- Philips Ultinon D4S 6000k (Fake or Real)?
- New Pre-Owned 2008 Starfire Pearl GS460 Owner
- Wheel decision
- Confused About Which Used Car to Buy, IS or GS Model
- Trunk Alignment, can it be adjusted
- Help tonight with windshield wiper replacement
- Navigation icon random movement at start up
- Headlight adjustment with Auto leveling
- Proud New GS 460 Owner
- GS300 06 Headlight & Brake Lights On
- 3GS Tramlining and Notchy Steering solved!
- Swapping out projector lenses? Quest for sharper light cutoff..
- Navigation disc
- D4s bulbs hid
- Low bean headlights
- exhaust tips
- Aftermarket Exhaust Tips
- Noise from engine
- NO more Jerry Johnson mailed warranties
- Navigation Map update
- Potential GS 350 AWD Purchase -- Opinions Requested
- The black strip in the trunk
- DRL / High Beams
- Keyfob Replacment?
- 08' Opaline white GS460's new home
- Best HID bulb?(D4S)
- Just how much fluid do I need to buy?
- Fog Light issue
- VVT Actuator Recall and Spark Plugs ??
- Direct injection carbon build up
- 20mm spacer all round on Stock Rims ??????
- BCR Coilovers for '10 GS350 RWD
- 2007 GS 350 Interior parts
- 40+ DIY Videos for Gen 3 GS
- Steering column lights
- iVic 5i Mounting Location in 07 GS350
- Trunk won't open, tried glove box switch and fuse
- Heater blowing cold at idle warm when revving/driving
- Tire recommendations for GS 350
- URGENT need of wheel!!! plz help
- Full speaker replacement
- I broke something inside the gas cap lid
- DRL problem
- Help.
- Replace Lugs Nuts / Center caps
- hi everyone)))
- How do I delete ALL saved Navi. info?
- Becoming Increasing Frustrated with 2007 GS 350
- Newly Installed with BCR Coil & F-Sport Sway Bar
- Headlight and heat question.
- Vsc and vgrs came on and off
- New wheels. Keeping an OEM type look
- Can somone explain to me Staggered AWD Setups
- Im a sucker for clean 5 spokes wheels..
- LED Strip Lights W/ PICS
- v4 vs v5 audio deck comparison
- Screeching brakes on 08 GS
- City/Parking Light
- Rear defrost problem
- Best H.I.D. Bulb
- Diagram/help wiring Fogs to operate independently ?
- Is my coolant ok?
- 08 gs350 afs light problem
- TSB's done?
- Interior Lights Questions
- AWD folks, flat tire?
- got rear ended
- Small mods, here and there....
- Welding on 2007 GS450H
- heartbreaking day
- Anyone know what size nut for the rear endlinks?
- 07 GS350 AWD Alignment Issues
- 2006 GS300 Headlight Problem
- Road noise coming from driver door
- 2006 GS300 RWD tranny interchangeability
- What in the world is this sound?
- GS300 2006. Cannot open rear right door!!
- being stupid...
- Transmission Problems 08 GS
- I Found it! My Car
- Problem with switch box.
- Remote button missing
- AFS Motor
- Frustrated w/AFS - 2 months No Dice (long)
- New shoes on my black beauty
- Newbie... help regarding bumpy ride
- Roxanne, you don't have to put on the red light...
- Bank 1 Sensor 1 is not repsonding!
- 2006 Lexus GS 300 airbags
- New 2007 GS350 owner! Where EXACTLY do I put insulation to stop the rattles?!
- A DYI bible
- trunk wont open
- 2007 GS430 or keep 2007 GS450h
- Help With Choosing Best Sound System
- FS and wtb go in the classifieds only please
- DRL w/ LED flickering issue
- Is this a known problem!?!
- My first Post!
- Key FOB Won't Work When Engine Running?
- Steering Wheel Damper
- Avoiding the rub?
- Fittedtho presents: "What the hell is wintermode?" 2014 car meet PICTURES
- Rubbing issues
- control panel not working
- 22 inch rims on 2007 gs350
- Blacked out tail light lens swap?
- 2GR TRD Supercharger on 450H?
- Do you have this issue with the GS350?
- HELP, staggered wheels on AWD and best tire sizes
- 2006 Lexus, PS windows not working
- anyone no where to find a lower mesh grille for a 2006 gs300
- 2006 3GS GS430 - Suspension advice?
- GT Spec Strut Bar and Painted Calipers last weekend
- Potential Lexus owner with some questions
- 2010 GS350 accident - side damage
- 2006 Lexus gs 300 Key not detected **Already changed batteries**
- New Sets of Rim on my 3GS...
- Alternative to AP2 tips?
- Heating and Cooling Seats
- Seafoam help
- How to replace lower running lights GS450h
- Pic Request : Front & Rear vip Table/Tray ?
- Upgrade from GS430 to GS460?
