10mm Spacer Question
Old Oct 12, 2010 | 07:46 PM
msgs350's Avatar
msgs350
Default 10mm Spacer Question
Could i safely run a 10mm spacer on my GS350 AWD with stock Gspider rims without the extened lug nuts? Need to switch back to a winter set-up soon
thanks for the help!
Old Oct 13, 2010 | 04:21 AM
designo's Avatar
designo
Good luck my friend, happy wobbly motoring!
Old Oct 13, 2010 | 05:26 AM
lkapimp216's Avatar
lkapimp216
I had 10 mm without extended studs with factory wheels with no problems. My factory lugs are hubcentric extended so they go into the stud bore I was able to get 8-10 turns
Old Oct 13, 2010 | 06:02 AM
IXI187IXI's Avatar
IXI187IXI
eh imo 10mm is pushing it. take a oem wheel and put it on and see how many turns you can get on a lug.
Old Oct 13, 2010 | 07:09 AM
lkapimp216's Avatar
lkapimp216
If his factory wheels and lugs are like mine he ll be fine I rode around most of the summer with ichiba 10 mm w/ out studs my spacers did have the centerbore extension also though
Old Oct 13, 2010 | 10:09 PM
msgs350's Avatar
msgs350
I'm now thinking about the Ichiba V2 15mm with the bolts on the spacers already. I was using 10mm on stock studs/rims/lug nuts for about 3 months, but now question safety. Thanks for the help so far!
markdav801
Jan 23, 2018 06:09 AM
soleeasii
Aug 11, 2015 01:54 PM
UtoyZ
Jul 7, 2010 09:48 AM
mxis350
Feb 26, 2010 07:12 PM
Bullskim
Nov 21, 2008 12:33 PM
