- Megan exhaust axle back
- TPMS Light
- Loaner question
- HELP!!! Drip Molding Peeling!
- Broken rocker arm and bent valves at 30,000 miles?!?
- Air filter selection and install
- Joining the 08+ shift plate changeup bandwagon.
- Install HID kits
- Any suggestion on a bodykit that goes right on the stock????
- Back-Up Camera Stopped Working!
- HID Fog Light FAIL
- GS Buying Question
- Is there a way to manually eject the NAV DVD?
- Steering stuck
- powder coating vs painting
- Need help on tires issue
- New camera pics
- will this size wheel work?
- aftermarket hid headlight ballast?
- tire sensors
- How to upgrade NAV Maps?
- Nav Disk will not eject, any ideas??
- Question about petrol & tsw wheels
- Amber Corner Reflectors Inside Headlights
- RearView Mirror Question
- When money and taste are no issue: Gold Plated 3GS
- wow. defective leather from factory?
- wheel fitment
- I need advice in a set up for GS350 AWD.
- Advice on buying a 07 GS350
- Anyone Used "Finish Line Wheels" for OEM Wheels?
- What Lip kit is this?
- Getting a CPO GS350?
- Re-Setting sunroof
- Fabulous GS Eyelines?
- Anyone running this size wheel?
- did get a good deal?
- fuel smell near master cylinder
- Where can i buy this chrome trim!
- Chrome Shifter Base....
- My new exhaust
- Got in a wreck this morning! This sucks.
- Is This The New GS
- debadge pics
- Need help for the puddle light changing!!!
- Where to buy replacement leather for backseat?
- Grill Chrome Molding
- Navigation DVD
- Blacked out tail lights
- Hit a pothole..damage done
- fsport sway bars: what is the final word?
- in the market for 07-08
- Is FIGS making a front camber fix?!
- Dash Rattle TSB, how long?
- where to buy carsontuned kit?
- ISF rims
- Special thanks to EXACT + s4play for my custom Sharkfin Diffuser
- 06 GS headlight Problem
- Does the 02-06 LS430 have a larger caliper than the GS350
- Door lock operation signal not working
- New GS owner.....
- I Need Advice from you Wheel Gurus
- Wheel Spacer Help
- No aftermarket parts?!?!
- TSW Wheels fitment question
- GS 350 colors
- battery changeout
- Should I buy this grill?
- where's the fuse for Radio/Nav located??
- Will these wheels fit my GS350?
- 2 questions
- Sunroof Not Working
- Negetave camber in one side!!
- opinions
- Wiring Harness differences between 06 and 08+ for Display Unit
- Front & Rear Interior Light Problems...
- New RECALL INFO
- Buying 08 GS460
- Another Recall - Pedal Entrapment Related
- Trunk Light - Dead?
- My 06 GS300 on 20" Rims
- 22 inch offsets.need some info!
- Matte Black Emblem While on Car
- Sat Radio: what cost and what parts
- 08 GS350 vs 08 535i
- Trade in + Offer for 2007 GSh
- Features Question!
- burning semll
- Best Intake for 06 GS300?
- Doing Waterpump: What else?
- Navigation - Street Name Announcement
- Oem 18'
- Are you running more toe if your lowered?
- GS 350 Jack Points?
- OEM grill for 2008 GS350 same as 2008 GS450h?
- LED all around
- VIN Decoding
- Whats the best tire size for this setup?
- Should I buy a 2007 GS 430?
- Nav sending me out of the way/wrong direction
- Two question in one thread!
- Burnt out bulb ends up being burnt out harness. FML.
- Camber kit for an AWD GS 350
- Legit D4S bulbs?
- Its going to be a fun summer
- Interior Cabin Air Filter Problem
- New lexus gs350 drift machine 2010 d1gp
- Wheels Lexus GS430 SLAMMED VIP
- i pod connection from is to gs ?
- GS 350 exhaust ?
- Can you add Tire Pressure Monitor system?
- 3 Car Seats In The Back???
- 2006 gs430 - warranty almost up!
- Front Axle Bearing / Hub Assembly Failed!
- Officially a Lexus owner!
- Changing rear brake pads ('09 GS 350 AWD) - can anyone help?
- How to play mp3 files on 5.1?
- 06 Sunroof question..
- Tire Preasure Sensor advice needed
- Squeaking brakes
- need help making decision 3rd gen gs
- what would you offer for this gs350
- Anybody with AVS and F-Sport Sway Bars!
- Just some pics from today ~ Enjoy!
- 20" wheels question, please advice
- Parking Lights..Which bulbs are better for light output?
- Someone please help me confirm my GS350 purchase was the right one!!!
- COLD Engin stalled first time ever of mine GS300 Y2007
- removing driver headrest
- Smart Card Key Programming
- lexus factory alarm question
- Lights Point Low, Side mirrors won't move
- iphone 4 not transferring contacts
- Seat position for long legged drivers
- Low MPG?
- Potenza RE960AS
- Best matching HID fogs w/factory low beam?
- Headlight Issues - HELP
- Fogs on without lowbeams?
- Check out my new license plate frames
- Wheel spacer help?
- Just bought a gs350 love the car but..
- Lexus is the last mfg to have a cassette deck, 2010
- looking for black center console
- Is the 2007 GS430 actually weaker than 2006 GS430???
- How do I know if I have PCS or adaptive cruise control???
- Reliable source for inexpensive genuine Philips HID bulbs?
- battery died-now no start
- awd rim/tires staggered setup question
- 2007-10 Better than 06' GS
- Think-design LED turn signal conversion kit
- Puddle light housing
- HELP- 2007gs350- water in the car.
- 09+ rear bumper on 07 gs
- Will IS-F calipers fit a 3GS?
- CPO owners that are affected by VSR recall......
- Would AWD benefit me?
- $500 savings card vs gift card?
- Need some helpp!!
- Body kit
- Should I...? (buy a 2005 GS300?)
- Are these mod's right for me?
- Front parking sensor
- Extended Warranty at 63K miles
- rear passenger side sensor keeps going off but nothings there!
- How to do the best launch?
- looking for contacts in socal for key fob purchase and programing
- 2007 GS350 trunk liner issue
- Update: New Centercaps,F-Sport Swaybars & Black Pearl Emblems!
- Transmission oil change
- How much does paint work lower value of car??
- 2007 GS 350 NAV Disc Update ?
- PS nav override installer in Philly area
- what offsets will work on 06up gs from other lexus cars
- Navigation system * Map DVD / Firmware
- Lexus CPO... worth it? Any Issues?
- valve spring recall and oil change
- since i posted and got no answers about uas
- GS NAV Questions..
- Best Fog light HID kit to match Garax 6000k?
- Brake problem?
- down
- iPod4 Phone paired but no sound
- Buying 2008+ Side Mirrors
- Tire Pressure Sensor HELP - RESET
- 3g front lip needed
- How to remove Circled Tabs (trunk door tabs)??
- New Lexus owner and need some advice plz!!
- Lease questions..
- Quad Tip exhaust.
- Does this combination exist?
- 2011 gs350
- Finally went with Continental ExtremeContact DWS
- Moonroof... what am I doing wrong here?
- My alignment guy told me to do the following...
- Has anyone installed JLC Reverse LED Bulbs?
- How difficult would a wood swap be?
- Hello 3rd gen GS forum!
- Blinker mod help.
- My recall letter.
- Midwest weather killing my paint!!!!!!!!
- Help with TSB
- stuck in 3rd gear in sport mode
- Hey Guys...Need Help
- Hello From New GS 350 Owner
- Poor Gas mileage (22 mpg @60 mph)
- XM satelite and Vais Tech
- Radio Interference w/ Rear Defroster Enabled
- What does the Gen 4 10.1 Nav Update disc do??
- Safety Recall Notice GS 06
- spring installers in orange county, ca?
- Air Filter and Carbon Filter, Is this Necessary
- I think these look sweet on a GS, your thoughts?
- NEED GS 430 and AWD in South Florida!!!
- Prestigious Society Nav Override
- Is a/c -heater smell inevitable?
- Hid-d4s ballast stop working
- Can Low Res Navi in GS430 be swapped out for the newer ones???
- Is HTC EVO 4G's bluetooth compatible with the GS430???
- Gonna buy a GS430 tomorrow.. anything i should know about this car first???
- GS vs. IS!?
- Headlight condensation.
- need a place that installs uas in s.fl.
- Looking for TPMS Sensors for 2006 Lexus GS300
- Rear lamps MOD for NON-US Lexus GS
- LED blinkers for 3rd gen GS?
- Would you do a swap on your GS for a CT200h?
- Looking for cars to photoshoot in So.Fla area
- GS-AWD - Anybody make front lower control arm bushings?
- Another Recall......
- After battery disconnect, settings won't respond
- GS in the snow
- Tire size
- Autoweek Magazine '11 GS350 review
- Slight knocking noise when idle
- I'm Not Getting A $500 Gift Card
- Had 60k done on 2007 gs350; no spark plugs?
- Question about 2006 ML system
- Yet another GS recall
- Seen the Chevy Malibu ad with the GS next door ?
- Picture REQUEST. HOW LOW DO U RIDE>>...?
- Anybody like their gs 350?
- Ooh, that smell !
- One of the speakers died last night - video
- Airbag question
- GS350 vs IS350 gear ratio
- You might want to see this VIP Modular GS......
- UAS Installation
- NEW PIX + Rollin shot.......
- My car wiggles....WHY?
