Driver door will not open INSIDE or OUTSIDE
Old Dec 22, 2013 | 01:52 PM
veblen's Avatar
veblen
Default Driver door will not open INSIDE or OUTSIDE
My driver side door won't open from the inside or the outside. If I put my key into the door to try to unlock it, it feels like it's bound up and doesn't turn all the way. I've already taken my door panel off (breaking it even more than it already was.) inside to try and get a better look, but it hasn't really helped in solving the issue. My little clip that attaches the rod to the handle is still intact.
I'm really unsure of what to try next. I haven't come across a thread where someone has had a problem they described as being similar to mine, usually it's just people who broke that clip.
Any help would be greatly appreciated, having to get out on the passenger side really sucks.
Old Dec 22, 2013 | 02:39 PM
turbodremz's Avatar
turbodremz
Huh, and you can move the latch release by hand from inside? Where in TX are you? If your in Houston, and I have some free time, I'd be willing to swing by and take a look at it.
Old Dec 22, 2013 | 03:25 PM
Biddles's Avatar
Biddles
You should be able to track down the issue. When you pull the handle does the cord move?
Old Dec 22, 2013 | 03:51 PM
veblen's Avatar
veblen
The door panel is off, so no. Everything seems to try to move and actuate up until it doesn't. There isn't anything that is clearly broken.
I'm in Dallas.
Old Dec 30, 2013 | 08:12 PM
veblen's Avatar
veblen
Is there a way to manipulate the lock mechanism from the back side to unlock it? I'd do anything to have my driver's door open again. :/
It seems like the lock is holding me up. If I try to push or pull the lock cord that attaches to the inner door panel, it doesn't want to go all the way into the unlock position.
HandsomeB
GS - 1st Gen (1993-1997)
May 29, 2013 04:35 PM
93ls40082
18
Jan 22, 2010 08:06 AM
JMMMWEL
Feb 4, 2008 01:47 PM
soulsoarer
Jun 18, 2007 04:58 PM
