No Spark at Ignition Coil
Old Jan 1, 2014 | 10:30 AM
bmxkeeler's Avatar
bmxkeeler
Default No Spark at Ignition Coil
Where does the ignition coil receive it's signal from? I'm trying to troubleshoot a no start. It's not getting a signal to the coil. Ive replaced the distributor and the ECU to no avail,
Old Jan 1, 2014 | 03:26 PM
turbodremz's Avatar
turbodremz
Have you traced and check wiring from the distributor to the ecu? If you already replaced those 2, last thing to check is for damaged wires.
Old Jan 2, 2014 | 05:19 AM
bmxkeeler's Avatar
bmxkeeler
I can do that now.
I found this wiring diagram https://www.clublexus.com/forums/att...cu-pin-out.jpg
Basically I just need to inspect wires 25, 26, 27, 57, and 58? On the engine side I just need to check the wires around the coild and distributor correct?
Old Jan 2, 2014 | 08:53 AM
ScWift92's Avatar
ScWift92
Originally Posted by bmxkeeler
I can do that now.
Hopefully This Helps
Old Jan 2, 2014 | 05:18 PM
2jz610's Avatar
2jz610
Check for broken wire by clip... I just had two break on me in inch away from clips... Chaze bays for new ones..
Old Jul 22, 2016 | 09:50 AM
TyStephens's Avatar
TyStephens
Did you ever get this resolved? if so what did you find to be the culprit
KC95SC400
Jun 26, 2015 12:57 PM
youngstah
GS - 1st Gen (1993-1997)
13
Feb 20, 2012 09:23 PM
ImWildBill
22
Oct 7, 2011 08:18 AM
maxgee
Jul 12, 2010 05:10 PM
artur1976
13
Feb 22, 2006 09:54 PM
