PDA
View Full Version : Suspension and Brakes
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20
  1. Newbie Here.....need lowering spring advise
  2. IS250 F Sport Suspension
  3. Looking to lower my IS250(AWD). Any Suggestions/advice?
  4. Looking to upgrade EVERY suspension part on my 2011 AWD is250
  5. 4th gen GS Strut brace on 2nd gen IS?
  6. Suspension noise
  7. Got coilovers, need tuck...help please.
  8. Lexus is350 better handling
  9. Looking for more braking power
  10. IS250 RWD Coilover recommendations?? Again
  11. Steering
  12. New wheels don’t clear brakes IS350 Sport Package
  13. Looking to run coils on my 2006 Is350. How are Teins?
  14. Accuair E-Level Sensors are ..........
  15. 2011 is250 rear caliper torque spec??
  16. What are these orange hub assemblies called
  17. Inner fender plastics
  18. IS350 New Coilovers
  19. Will Tein Flex Z Coilovers fit 2006-2013 IS250 AWD
  20. Will AWD is350 rear rotors fit a AWD is250?
  21. Wheel Spacer Suggestions
  22. rear sway bar end link wont go back in
  23. OE brake kit upgrade?
  24. 06 AWD is250 in the SNOW!?
  25. Squeaking sound
  26. Discoloring on new rotor
  27. Flapping noise when I accelerate!
  28. Helpless squeaky IS250 brakes
  29. Toe Wear
  30. Power Brake Booster
  31. Stock Ride Height
  32. Rear Tires Premature Wear (Inner)
  33. Brakes keep squeaking?
  34. Chassis loading and weight transfer; proof with picture
  35. IS 250 AWD lower front levers and links from GS AWD?
  36. For Sale items go in the marketplace only
  37. BBK: upgrade stock IS250 Brakes to 2019 GS350 F-Sport Brakes
  38. Ebay Lowering Springs is250
  39. Can I raise this car?
  40. Anti-rattle squeel plates
  41. D2 BC coilovers for 2006 Lexus gs300 awd
  42. Which struts do I need with lowering springs?
  43. Bc racing coils vs fortune auto coils
  44. Mercedes S Class brake upgrade
  45. Grinding/ metal to metal noise while braking
  46. Koni Sport kit with H&R springs
  47. Spacers with OE Double 5 spoke 18s
  48. 250 AWD Shock Replacement Options
  49. Sway / Strut Bars
  50. BRAKE Fluid
  51. Brake pad measurement
  52. Brake Squeal in Reverse
  53. Strut is leaking, replace with F Sport Bilstein?
  54. OEM Tokico Shocks Hydraulic or Gas?
  55. Weird grinding noise coming from back of car
  56. RR Racing coilovers
  57. All 4 strut assembly replaced
  58. Clicking noise coming from both rear wheels after 250 to 350 brake conversion- SOLVED
  59. 2011 IS250 AWD Lower Control Arm Bushing Replacement
  60. Suggestions on offset and rim size. Is 350
  61. Confirmation
  62. AWD IS250 to IS350 Front Brake Conversion
  63. brakes
  64. I removed center nut on top of strut while still on car...is this bad??
  65. How to adjust parking brake
  66. Front brakes squeal after new OE discs, pads, shims, anti-squeal clips, and lube.
  67. Pop Sound when going straight
  68. Is350 awd rotors
  69. info please
  70. 2007 IS250 Brakes Locked
  71. Replacing front Rotor and Pads on IS 350 2011 Brakes Are Locked
  72. Lower ball joint will NOT come out... PLEASE HELP
  73. OEM springs height
  74. Rubbing issue
  75. 2nd Gen AWD is350 2011 Ball Joint Separated from Upper Control Arm
  76. Building a IS250 for AutoX
  77. ABS, Check VSC and 4WD alarms after alternator change
  78. tabs on sturt, purpose?
  79. 2006 is250 AWD suspension help
  80. Lexus isf rear brake bracket fit on isx50?
  81. 01 GS300 rear caliper on 08 IS250?
  82. Suspension torgue specs
  83. Lowering springs
  84. Coilovers rwd is250
  85. C/O ride height with wheels that stick out?
  86. Awd coilovers Val’s rwd coilovers
  87. My IS350(c) brake pad experience
  88. IS250 2006 AWD coilovers ?
  89. Brakes replacement is350
  90. Will IS350 Rotors and Calipers fit the IS250
  91. 2007 IS250 tire set up for 19 inch
  92. Will these rays wheels fit? 18x8 +35 18x9 +25 URGENT
  93. BC Racing Coilovers.
  94. *CANADA* Someone Sell me HKS Hi Power and BC coilovers
  95. Blitz Coilovers good for 2008 IS350?
  96. LCA Bushing identification
  97. Front jack point on 09 IS250?
  98. Where to buy stiffer springs for my coilovers?
  99. Will I Rub? Lowering Springs
  100. What kind of shocks are on 2017 IS300?
  101. Might be a dumb question
  102. BBK and brake fluid.
  103. Brakes shakes when slowing down from high speeds
  104. Rough ride. Where to start?
  105. H&R vs F Sport springs. 2011 Is 350 AWD
  106. Rear LCA/Knuckle bushing
  107. New Brake Master Cylinder
  108. This forum is a bit slow... I'm gonna show off my new toys
  109. 2" Lowering Springs Recommendation
  110. Cusco front sway bar on 06-08 with newer endlink issues
  111. Cost for OEM shocks on 2009 IS150 AWD?
  112. Why should I buy this 08 IS 250?
  113. Need coilovers ASAP
  114. H&R lowering springs on high miles stock struts
  115. Godspeed upper control arm install problem
  116. Guide for front lower ball joint?
  117. Rwd models front lower ball joint replacement
  118. Uneven ride height
  119. BC Racing vs. Megan Racing Coilovers
  120. Caliper bracket difference?
  121. ABS VSC AFS lights
  122. Stock 2012 IS 2nd gen review
  123. PLEASE HELP! 2009 2IS very bad front end clunking sound - worse in turns
  124. Brake Caliper covers and springs
  125. LCA bushing color code vs OEM offset (0, +20/-20)
  126. F sport Blue Caliper paint code
  127. Front suspension noise
  128. Strut/Shock Replacement Parts
  129. F Sport Sway Bars
  130. Coilovers
  131. BC Racing Coilovers
  132. ABS Actuator Replacement
  133. Different size rotors on rear?
  134. Do 2007 GS350 brakes & calipers fit 2012 is250?
  135. Underbrace clearance
  136. Tein Street Advance Z Coilovers
  137. H&r springs, uca hitting?
  138. Metal scraping noise from wheel area
  139. ABS/VCS light
  140. Lexus is250 New Brakes and Rotors
  141. Bleeder pitch IS-350: confirm Fr 10mm x1 x 35mm
  142. Will AWD BC coils fit on my RWD?
  143. Anyone running Megan Street EZ Coilovers? Pic request
  144. 09 is250
  145. Most reccommended rotors and brake pads?
  146. Megan Strut Bar
  147. How many coils on H&R IS250 springs
  148. Replace brake pad sensor 2006 lexus is250?
  149. Air ride setup
  150. Suggestions for 08 IS350 Coilovers - Megan Racing or Tien?
  151. Recently lowered with alignment
  152. Hub or disc rotor loose
  153. IS250 Cryo-treat Rotors?
  154. F Sport Lowering Springs Stock Shocks
  155. ISF absorbers & springs for 2IS '08
  156. OEM Shocks 2006 IS350
  157. F-Sport Springs and shock pairings?
  158. IS350 Parking Brake Cable Adjustment
  159. Figs LCA Bushings FTW!
  160. Wheels might not clear Calipers
  161. Shock replacement?
  162. After Market Master Cylinder LS 96
  163. Greddy x KW coilovers damper adjust
  164. AWD Strut Suggestions
  165. Creaking Noise
  166. HELP! air cups for rears
  167. Mechanic in SoCal (South Bay - Torrance)
  168. Suggestions wanted: pads and rotors for the “everyday” driver
  169. IS-F Rear Bar on AWD Setup
  170. Camber arms awd
  171. friction noise from front brakes
  172. Rear brake retainer clip question
  173. Are rebuilt calipers worth it?
  174. For Sale: IS 250 F-Sport Lowering Springs
  175. Where to start to improve ride quality
  176. Is350 retainer clip missing on rear breaks. Need a quick temp. Fix
  177. IS250 rear brakes, BBK replacement?
  178. Will '11 IS-F springs/shocks alter ride height on '08 IS350?
  179. Metallic noise while braking
  180. winter tires
  181. Brake popping/clicking
  182. Lowering 2is350. Coilovers, or springs?
  183. 2001 IS300 Rim Question
  184. Suspension Air Cup Kit
  185. A warning about the front lower control arm bushings
  186. R1 Concepts Brake Calipers
  187. Eibach Pro Kit vs. H&R Sport vs. TEIN STech Springs
  188. Worthwhile 250 brake upgrade?
  189. Okay to mix Bridgestone tires? Potenza RE760 & S-04
  190. 2010 IS250 suspension noise
  191. Noise From Drivers Side Wheel Well
  192. Ebay suspension
  193. another suspension clunk noise
  194. IS350 front rotors and calipers on IS250
  195. Wheel adapters
  196. WTB coilovers for my 07 is250
  197. Chamber Kit. Do it or not ?
  198. Is350 rwd after market wheels without spacers!
  199. F-Sport Shock/Strut Replacement Recommendation
  200. Which Rotors?
  201. 11.6 or 11.7 inch Rotors - Front and Rear?????
  202. For sale belongs in classifieds
  203. Brake swap/big brake options for IS250
  204. Brake Pads & Rotors
  205. Brakes torques specs IS350 AWD
  206. 2011 IS350awd Brake Bleeding
  207. FIGS rear toe links
  208. Any DIY on ULC bushing install for IS?
  209. For sale items go only in the classifieds
  210. Front squeak over bumps.
  211. 2010 IS250 Canada or US Equipment for Brakes?
  212. Lower Control Arm Bushings
  213. Corroded brake fluid?
  214. AWD IS250 to IS350 Brake Upgrade
  215. Ball joints & control arm bushings
  216. SF Bay Area looking for IS 250 Suspension shop
  217. ISF LCA bushing in a non-ISF
  218. 2IS and 3IS front control arms the same?
  219. AWD Lowering Springs Help
  220. Duralast Gold Brake Pads, thoughts.
  221. Front Upper SPC Ball Joint Installation
  222. Do I need to replace endlinks when changing shocks?
  223. Vibrations from lowering questions
  224. 2008 IS250 sound when braking at turn
  225. left front caliber locking up
  226. BcRacing - Regular V's extreme low kit? Pics request
  227. Shaking 1200rpm to 2000rpm
  228. is250 front brake upgrade
  229. Koni Sport Kit for IS250 on IS350
  230. Clunking Noise heard from inside car but not outside
  231. IS250 F-Sport Brake Identification
  232. Lower Control Arm Bushings Replacement
  233. '08 IS220D - Reasonable lowering
  234. 2011 IS250 Front brakes question.
  235. Replace struts or boots? 2006 AWD 250
  236. Rear Caliper
  237. IS350C - Time for brakes - pads only or rotors too? - what brands?
  238. F-Sport Springs on Monroe/KYB Struts?
  239. 2006-2013 F-Sport Caliper piston size?
  240. lowering my is250 f sport
  241. IS220d Luxuary Brake disc and pads replacement
  242. Mechanic Recommendation for Front Struts Replacement
  243. Creaking/popping when turning with brakes on??
  244. How much is my sport suspension worth?????
  245. Rotor Life
  246. Advice on type of brakes, Rotors and Calipers
  247. Dealer did a sports suspension alignment instead of standard
  248. Help: Brake Replacement Situation
  249. Metal clunking sound when going over bumps - Sway bar link?
  250. Coilover question
