ABS VSC AFS lights
ABS VSC AFS lights
hi guys. Getting all these lights on dash. Plugged it up and I am getting a bad front right speed sensor. The thing is, the lights only come on when I do sharp turns. Is this normal for a failing sensor? Also, are there any write ups? Is this a fairly easy job? I searched for threads with no luck. 06 350 RWD.
Mike, thanks a lot! It is indeed more cost effective to replace entire hub assembly with the sensor already attached. Would you know if there are any write ups out there to do this?
https://www.clublexus.com/forums/is-...s-250-a-2.html
Find the PDF on installing the F sport brake kit. It will help you.
drewefx
05-17-08 08:13 PM
