View Full Version : Suspension and Brakes
Pages :
4]
13
14
15
16
17
18
19
20
- IS*50 with BC Coilovers help me with some pics!
- 2008 Lexus IS250 front clicking noise while turning please help?
- My IS F-Sport upgrades
- IS250 vs IS350 rear brake calipers?
- Best ride, quietest, longest lasting 19 Tires?
- Tires size for IS350 AWD
- KYB Struts for Front L/R
- Decided to buy BC Racing Coilovers
- F-Sport 19 inch wheel vs 17 inch wheels?
- Need your opinion on lowering springs...
- Steering wheel pulling right when brake at close to 0 speed
- WTB: IS250/350 AWD coils, prefer used
- Brakes........on fire!
- 2012 IS250 AWD Front Control Arms?
- Help needed: BC Coilovers out of the box rule of thumb for height
- Muffler upgrade, any input? IS 250 F Sport
- 2011 IS350 Brake Resurface?!?
- IS250 rear crossmember differences?
- Eibach Springs and AWD CV Joint Boots failing!!! HELP
- Pictures of suspension with tire off
- Godspeed/Truhart Upper front control arm
- Can i swap my 17" for 18" wheels?
- HSD HR vs. Megan vs. BC......
- How do BC Coilovers handle extra weight?
- Wanting to buy factory springs
- Lexus wants $1,000 to..
- Burnish / bed in brakes experts
- ISF springs on IS250 awd?
- BC Racing coilovers question
- Installed F-Sport Shocks
- Lowering Springs for IS350, Please Advise
- Brake fluid pressure flush
- D2 Racing Lowering Springs
- BBK Question
- Seized rear caliper lower pin/hinge
- What size tyres
- F-Sport Rubber Exhaust Hanger
- 2009 IS250 AWD Lowered w/ Eibach
- Just got my Tein Flex A Coilovers dialed in
- Rear pad shim kit?
- Tire Thread and Suspension - SF Bay Area Local
- How-To Tuesday: Suspension Mods for Your Lexus IS/GS
- 2008 Lexus IS250 RWD Tein S Tech Springs Installed
- Quick IS350 rear caliper question
- 2012 AWD IS350 Camber Kit
- SSR wheels
- Allowable Mods for HPDE Events at Road Atlanta
- Tein S-Tech Springs
- Caliper Brackets
- Excessive tire wear.
- IS250 veering/drifting right, tech says likely caster - bent knuckle/control arm
- Tanabe Coilover
- 2011 IS350 F-Sport Brake Pads
- cutting a hole in shock tower?
- Pre-purchase IS350: thoughts and questions on suspension
- Time for Coilovers?
- Squeal when applying brakes in reverse
- Stock F-sport suspension
- F-Sport Shock/Spring Installation Instructions
- calipers
- 2012 IS250 - Rattling noise from strut?
- EBC Brake Rotors
- Best coilovers for IS250?
- Anyone here with RR-Racing USRS?
- Recommended shocks?
- AutoZone Brake Rotors
- Tire Wear - Alignment Settings
- Koni Sport Kit
- Are they considered struts or shock absorbers?
- How good were your stock shocks with lowering springs?
- AWD torque specs, front suspension
- Fan motor problem?
- Front Brake Shim Kit IS350
- Front upper ball joint popped out and clunking.
- What's the best rear sway bar do you recommended for IS250/IS350 RWD?
- WTB and FS go in the classifieds
- Low Dust Front Brake Pads - 04465-30400
- Akebono brake pads review vs Lexus OEM Pads
- Front strut mount , can I change one side
- front lower control arms xe20 xe30 interchangeable?
- TSB question andd rear suspension
- Quick Wheel Fitment Question
- Parts needed to fit 19x9.5+20 19x11+25
- Brake problem
- Handling Better with Sways?
- 06-08 Solution to brake dust issues?
- Weird Brakeing Problem After Accident
- Trying to understand RCAs'
- Driver's rear BCR coilover shock done?
- Tokico HTS
- IS350 brakes on fire
- Is350 rear sway bar thread
- bottoming out... need suggestions!
- I need help!!! loose steering
- Bc installed.. Rubbing?
- Camber Kit Needed?
- sage rca kit and lowering awd
- Review of Koni FSD + Eibach Pro lowering springs!
- Shocks...upgrade to Koni FSD... springs?
- Too much positive camber on front tires???
- Upgrading from Megan EZ. Advice?
- Alignment Specs. Please comment.
- Caster Bracket needs replacement at 35000 miles.
- brake pad pros and cons
- Lexus is350 2nd gen front brake rotors
- Tein Flex-A Coils with H.B.S or.....? (2015 Release)
- Will I regret Megan EZ's?
- New BBK!
- Shocks are leaking. Upgrade suggestions?
- Front brake pads
- IS350 Front Rotor + Pad DIY
- new pads and rotors??
- 2007 IS350 Swift springs review
- HELP! Need help identifying loose part....
- Spacers on IS350
- 100000 miles on lowering springs?!
- HELP IS250 F sport 20's and H&R springs
- Fitting 19x10 +7 in is250 awd
- Lowering Springs?
- Aggressive offset need help asap!
- 2006 is350 w/ Sport package, want a smoother ride...?
- BC/Swift coilover spring rate question
- Is there a DIY for struts (F&R) and CV axles?
- 2010 IS 250 Rear Shocks Leaking
- Max Brakes
- D2 PRO Lowering Springs question
- Needed advice on replacing brake pads.
- 2007 IS250 AWD Brake Upgrade – IS350/GS350 AWD Parts.
- Anyone installed Rca camber kit for a is350
- Fixing Camber. Whats needed.
- R1 Concept Brake kits
- New brakes and rotors IS250AWD
- Will decreasing wheel size 1" lower my car 1"
- Shocks worn or something else?
- Help with lexus is250 2013 coilver : /
- F-Sport front sway bar part number
- 07 2IS Brake Pedal free play?
- Tein Flex-Z Coilovers
- Air suspension, rear, please, help
- Rotor
- Quick question regarding lowering springs
- Koni Sport kit IS350 review
- lowering
- Does Rear RWD Fsport Shocks Fit the Rear of and AWD?
- Aftermarket AWD Shocks
- Aftermarket Advics Calipers on IS 250
- coilover install in PA
- Brake pad clips & boots covering sliding pins on front brakes
- Lexus is250 awd 17x9.5 fitment
- RR-Racing Lower Control arm bushing review.
- HELP: Stripped stud
- Mixing Brake Pads
- Lower Compression Bushings - What offset?
- HELP!!! Bc Racing KIt
- Rake change and effects?? Help?
- Megan Sway Bars?
- Low AWD improvement - RCA blocks
- camber kit
- considering HKS Hipermax IV GT
- Tanabe Sustec Coilovers - S-0C
- extreme camber = silly toe out
- Do Gs300 awd coilovers same as n fit is250awd
- Hks and Megan's? Scrape?
- Tuning coilovers for best handling
- 2006 IS 250 suspension issues
- StopTech Rotors
- changing coilover height
- Will It Rub?
- front shock replacement for lexus is 250 07
- How do I remove the upper control arm?
- Questions - Installing new springs on a 115k mile 350
- need help for finding brake kit
- Leaking Right Front Strut - replace both?
- Question about Brake
- Help about brakes.
- Air suspension leaking air after a few hours
- Sway bar bushing access cut
- Rear shock replacement - what gas to come apart?
- Buying sway bars? get the right one
- need confirmation for is250 brake conversion please
- Diagrams of Front / Rear breaks with torque specs
- 99 gs300 - quick struts ?
- F-sport rear sway bar bushing
- 2012 is250 awd wheel alignment report
- BC coils 16/12 vs 14/12
- Pads and bedding
- is250AWD front brake upgrades/replacements
- Is250 awd staggered wheel tires
- Air Suspension AWD
- Tein ss coilover info
- Anyone change out front upper control arm bushings?
- 08 2iS
- ISF Brakes on a IS250 question
- Lowest lowering spring for 2is?????
- Lowering my is250
- Need Help!!! [brake pad and rotor advice]
- squeaking creaking sounds from front driver side suspension, sway bushing?
- BC Racing Coilovers for sale - $900
- Is250 brake upgrade help!
- lexus is250
- BC BR Coilovers with spring rate 14/10
- Lowering '07 IS350- Info/Help PLEASE!
- ATTN 2nd Gen suspension gurus: EDFC wiring
- Look for part number for is250
- Sway bar end links - change both at same time?
- Opinions Ideas on Wheels
- Will 255/40/18 Fit On 2006 IS250 AWD ?
- TEIN Street Advance
- HELP - Caliper Movement
- E-Cutout Exhaust on IS250
- 2011 IS250 F Sport
- 2007 IS350 RWD camber kit question?
- Shims and Akebono pads
- Thoughts on Tein Monosport coilovers
- In need of feedback from members that lowered on SPRINGS
- Dealership wants over $1000
- Cusco strut bar help ASAP!!!
- Where to buy OEM low dust???
- Please help!!!!
- Bushing Reset info missing!
- clicking from rear passenger HELP
- Lowering IS250 F-sport
- help with coilovers on 20's
- drop springs question
- swapped my coilovers, front to back
- Ceased Calipers in the rear
- want to make care ride firm/tight again.
- IS-F Shocks/Springs on Non-Sport IS350
- shortened steering knuckles
- BC coil noise
- Lower Spring Insulator Rubbers
- Another coilover question...
- Squeaking
- Megan UCA or SPC ball joints?? 2010 IS 350
- Corner Balancing
- 2012 lexus is250awd air ride system recomendation
- Front shocks
- Can anyone give some review on KYB shocks?
- Lowering springs with OEM shocks.
- Choosing the right camber kits
- is350 brake replacement
- Getting Coilovers
- Camber Kit IS350
- Experts - Which Springs are Front / Rear? Help.
- Help! 2006 AWD Front right HUB ASSEMBLY REPLACEMENT
- RCA / spacers for lowering AWD - update
- Available shock option for the AWD?
- Cusco Sway bars.. upgrade bushings/endlinks?
- Coilovers or Springs + Shocks
