H&r springs, uca hitting?
I have H&Rs and don’t have this issue. Wheel specs?
its definitely secure, I didnt have to remove it when i did the job, all that was removed was the UCA ball joint to the knuckle, tie rod end and lower strut bracket to the LCA and of course the 3 mounting bolts for the strut. Everything was torqued to spec and reassembled properly.
Todays lesson, if youre doing struts, torque your top mount. *facepalm*
I pulled the wheel off to look. I tugged upwards on the whole wheel assembly and kept hearing it. I opened the hood and pulled up on the assembly and i see the top strut mount has about a 1/4 inch of play causeing the knocking, I had to torque the damn top mount bolt 😂😂😂😂😂
chuyrobles
ES - 5th Gen (2007-2012)
15
07-10-18 11:09 AM
Greg5OH
17
06-22-17 10:49 AM
