PDA
View Full Version : Suspension and Brakes
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 [20]
  1. Anyone have the Tein h-tech springs?
  2. Tein CS coilovers
  3. Car is 8 months old and i get the sqeeky brakes?
  4. eibach anti-roll kit
  5. Rate The Comfort Level A Of Lowered IS
  6. Finally Dropped on Tein SS but 1 Problem
  7. NEEDED: Procedure for installing Eibach Pro Kit
  8. IS350 Brake Knocking Noise !!!!!!!!!!
  9. Ceramic brake pads
  10. What are coilovers? it's advantage over sport suspn?
  11. FIRST POST! Aftermarket Springs affect turning radius?
  12. Big Brake kit
  13. Brakes
  14. Tein CS or Megan Racing?
  15. Any DIY Spring Installs?
  16. Brake pad replacement
  17. Coilovers: Post your opinions
  18. Tein Coil Overs, I'm Confused...
  19. My Tein CS Coilovers are on their way...
  20. Is this a good price for Eibach Pro-kit?
  21. how much for new brakes on 250
  22. EDFC on any brand coilovers?
  23. Pics of iForged Classic (19x8 & 19x10) and Tein CS Installed! (No 56k!!!)
  24. Eibach vs. Stock photo (for those of you considering lowering)
  25. Brake Problems
  26. Detailed Instructions for Coilovers?
  27. Brake Dust Resolution by Lexus
  28. Is this a fair price for Tein Coilovers & Installation?
  29. Installed LMS custom springs
  30. ATTN: Tein Htech and Stech Owners....
  31. Emergency Brake???
  32. Tein CST or SS Cambers
  33. Brake pads and rotors at 14.6k miles?
  34. Where can I order a set of Tein CST coilovers?
  35. Tanabe DF210 & Under Brace installed on my IS
  36. Brake and rotors need to be changed IS350 (solution found please read)
  37. Question for you Tein SS owners
  38. Aftermarket Shocks
  39. 07 IS350 X-Package w/Eibach Pros
  40. JIC Coilovers part 2 [56k warning lots of pictures]
  41. Issue with Tanabe NF210...
  42. JIC Coilovers
  43. Eibach anti-roll and sways?
  44. Anyone with 06 GS Eibach Prokit on 2IS ?
  45. Tein H tech, install prices in s fla
  46. Brakes
  47. TEIN CS Coilovers Installed. +Pics
  48. Eibach pro kit with sport suspension
  49. Lowering IS250.
  50. IS250 to IS350 brake?
  51. Strut Assembly Between RWD and AWD 250s
  52. Eibach pro kit or Tanabe NF210's???
  53. IS250 - Brakes-Need help pls!?
  54. Aren't the Tanabe NF210's suppose to be blue?
  55. TEIN or Eibach springs?
  56. Squeaky Brakes on new IS250 WTF!!!
  57. Finally dropped on Tein CS
  58. What are the available coilovers?
  59. Eibach (or tein etc) Springs and Tire Wear
  60. 2nd gen ISs with big brakes...post up!
  61. Aftermarket wheel/brake caliper clearance question
  62. Question about Eibach settling time?
  63. Want to know about JIC coilover
  64. What is exectly causing the brake squeek?
  65. eibach spring problems
  66. anyone using TEIN s-techs?
  67. IS250 Lowered With Eibach
  68. eibach or tanabe springs for IS350?
  69. do the springs eventually soften?
  70. after springs install..
  71. Lexus 2IS w/Tein CS and 20" Auto Couture Lative (pic)
  72. 2IS Japan-Spec Tein CS/new EDFC review!!!
  73. Brake dust getting on my nerves
  74. Coilover Installation Questions
  75. Alignment After Eibach Install
  76. How to get lowered ride height the cheap way...
  77. TTE Springs
  78. Need help with pricing for eibach pro kit springs...
  79. IS250 Lowering With Eibach
  80. Front brake noise - help?
  81. Need Help With Springs
  82. Where To Get Eibach Pro Kit
  83. Solution To Brake Noise Found! (tested On 2 Different 2is's)
  84. TEIN screwed up my order!!!
  85. Stock Suspension VS Sports Suspension
  86. IS350 Zeal Function XS Coilovers
  87. MKIV Brakes?
  88. HKS Coilovers vs. Tein Coilovers vs Eibach springs, etc etc..
  89. eibach pro kit in stock?
  90. Eibach Springs + Tire Radius = True Height
  91. Eibach Spring Installer needed in Austin Tx
  92. Eibach lowering springs with stock wheels
  93. Eibach Sway bars for the IS350
  94. Need Help, VSC Display on other lights after Eibach Install
  95. Eibach Owners I need a favor! (measurement)
  96. Newbie Q: How to get as close as to Sport Package's Suspension?
  97. Has anybody here installed the Tanabe NF210 springs for a GS on their IS?
  98. tein ss
  99. Any good springs besides Eibach?
  100. Does anybody have pics of Eibach pro kit pics with 20x10 and 20x8.5......
  101. My 2IS Tein CS are here!!!
  102. brake calipers
  103. TEIN CS coilovers are almost here!!!
  104. Brake Squeeling Finally Stopped!!!
  105. 06 GS430 Tanabe DF210 springs for the IS350..
  106. IS350 Sport Pkg Suspension Rattle
  107. drilled brake rotors??
  108. brake pads?
  109. IS250 & IS350 brake difference
  110. Tiny rust spots all over my paint from front brakes?
  111. Spring Install! HELP!
  112. 2IS Tein Comfort Sport Coilovers available!!!
  113. Tein SS Coilover
  114. Brakes are diffrent on the ISX50's?
  115. Aluminum Brake Pedals and Windshield Sunshade Accessories
  116. Do they make IS350 big brake kit yet???
  117. IS250 RWD front disc brakes
  118. Replacement brake pads (low-dust)
  119. Coilovers vs Springs
  120. OFFICIAL: Tanabe Springs for the IS250
  121. SPRINGS are here!!!
  122. Parking Brake Cable Caused External Noise
  123. Modified IS250/350 Handling vs. latest BMW330
  124. Removing middle brake light?
  125. is250 awd lowering springs
  126. Megan Racing Coil-Over
  127. Brake pad shift???
  128. Tanabe/Eibach springs Install Question?
  129. How are your tires and brakes holding up?
  130. Nothing recently on dusty brakes
  131. HKS Kansai Coilovers
  132. JIC Coilover Owners- Need help!
  133. WARNING!!! Counterfeit Tein S. Tech Springs WARNING!!!
  134. Just installed Eibach Pro Kits, Not impressed
  135. Lowering springs / Better handling?
  136. Another IS350 on Eibach springs pictures .
  137. Springs Question
  138. Zeal Function X and XS Coilovers
  139. Is350 Endless Brake!!
  140. Tein SS Coilovers for the IS!!!
  141. Eibach springs for IS
  142. IS350 w/ JIC Coilovers and iForged Daytona wheels
  143. Rear Brake Calipers
  144. Tanabe NF210 for 350 vs. NF210 for GS 06' -> on a IS250 AWD
  145. Sport Springs vs. Normal IS 350 Springs
  146. Parking Brake
  147. does anyone else dislike the Brake Assist?
  148. Baby your brake dust
  149. brakes
  150. Best Deal on Eibach springs?
  151. Suspensions, Springs, Coilovers
  152. Now I am going to do Coilovers...So.....
  153. AWD - planning to lower, need help
  154. Eibach Pro-Kit= AFS light Blinking ???
  155. How about ordering Lexus Sports springs?
  156. Eibach Pro Kit installed
  157. Question: Eibach for is350 on is250?
  158. Looking for pics of Eibach Pro-Kit with 18" wheels
  159. Eibach Sportline spring kit???
  160. Any ETA for aftermarket shocks for the IS350?
  161. Drove to Palm Springs for Memorial Day Weekend.
  162. springs
  163. Ceramic Brake Pads
  164. Eibach or H&R which are the best Springs???
  165. Comparison of Before and After Lowering Springs IS 250 AWD
  166. Eibach Pro-Kit and Tanabe Racing Medallion Pics + Video
  167. Yet Another Annoying Minor Issue - Parking Brake
  168. Eibach Pro Kit = Perfect Drop
  169. Stock Spring Rates?
  170. Pics IS350 JIC coilovers, 19" volk GT-7, 15% tint-50% on front windshield(56k beware)
  171. I lowered my car with the JIC coilovers & 19" volks, now my AFS OFF light is flashing
  172. extremely bouncy
  173. Installing Tanabe NF210 springs on my IS250 AWD
  174. Pics of Eibach Prokit on IS250 RWD
  175. Another Eibach Install w/ PIcs -- But having some Issues -- Please Help
  176. What to do....Put stock springs back in?
  177. Use of e-brake on the IS350?
  178. Eibach pro kit!!!!
  179. Brake Dust
  180. Coil Over Kit ??'s
  181. Best springs out currently?
  182. Brake light problem on the IS?
  183. ** Tanabe GB posted for IS350 Exhaust and Lowering Springs **
  184. Brake problem
  185. Any one tried brake caliper covers instead of paint?
  186. Eibach IS250 Pro-Kit has been released
  187. Need Tips For Brake Kit
  188. Need new rear brakes
  189. Hot News!!! Tein and Road Magnet Coilovers for the 2IS!!!
  190. ** Interest ** Newly released JIC FLT-A2 coilovers for the IS250/350 Available!! **
  191. Making things clear: GS430 2006 Aftermarket Springs fit 2IS??
  192. Coil-overs for 2is
  193. Just changed the oil and noticed the front brakes have small brake cooling ducts
  194. IS 350,GS 430 same front brakes?
  195. New Brake Pads
  196. Parking Brake
  197. brake noise
  198. IS350 w/ Eibach Springs
  199. Good price for lowering springs?
  200. Lowest Lowering Springs....
  201. Bad smell from exhaust or brakes!
  202. Gawd the brake dust!!
  203. Lowering Suspension??
  204. Springs
  205. What are good tires and brakes for an IS ?
  206. H&R lowering springs
  207. 250 & 350 suspension difference..
  208. Eibach Springs
  209. springs
  210. squeaky brakes!
  211. IS350 springs
  212. IS 2/350 EIBACH Anti-Roll Kit Available!
  213. I haven't seen dust from brakes like this since my MB C320...!
  214. Anyone want to switch springs ???
  215. Painted Brake Calipers ?
  216. Looking for IS250 AWD for Coilover R&D
  217. Brakes Squealling
  218. Eibach Pro-Kit
  219. Tien lowering springs
  220. brake dust IS 250
  221. lowering springs?
  222. LED Brake Lights
  223. Electronically Controlled Brakes (ECB) and the Variable Gear Ratio Steering (VGRS)
