Toe Wear
Old Mar 14, 2020 | 01:59 PM
Flipsonic's Avatar
Flipsonic
Default Toe Wear
Got the RC F LCA bushings installed. Decided not to install a rear camber kit and just go with alignment. Hopefully no more toe wear. Just got the alignment done. I’m not an alignment expert but it looks that it’s all toe in now. I’ll let you guys tell me if I should be good now.
Old Mar 15, 2020 | 12:13 PM
2013FSport's Avatar
2013FSport
That looks pretty good. Keep an eye on the wear pattern and adjust pressure to achieve equal wear across the face of the tire.
I'm running 40 psi front, 34 psi rear. Results will vary by car, driver, use....
GL
Old Mar 15, 2020 | 10:11 PM
Flipsonic's Avatar
Flipsonic
GL
So what’s the guideline on adjusting pressure? Higher pressure to compensate if there is still toe wear? When would you run lower pressure?
Old Mar 16, 2020 | 10:03 AM
2013FSport's Avatar
2013FSport
If you have tire tread depth gauge or a veneer caliper, measure in 4 places across the tire. All four.
A month later do it again and compare.
Example on the Rear is at 38 PSI the centers were wearing and there was no edge wear. Lower the pressure.
The fronts were the opposite. Both edges wearing and center has good tread. Increase the pressure until wear is minimized.
JM51526
IS F (2008-2014)
Jun 30, 2014 09:16 AM
HAiS250
Suspension and Brakes
17
May 6, 2012 11:50 PM
soulific
Jun 23, 2010 07:27 PM
MarcusMIA
Oct 14, 2009 07:08 PM
Slow_Sc3
Aug 6, 2008 07:56 AM
