View Full Version : Suspension and Brakes
Pages :
13
14
15
16
17
18]
19
20
- Need some help with replacement brake pads
- TunedParts Billet rear Member Braces
- Swift Springs on an IS350
- I was convinced until I started reading...
- Eibach spring instructions?
- Does Koni,Bilsteins or KYB make shocks for the IS 250/350?
- eibach pro kit question?
- OEM Lexus rear camber kit
- Final choice 4 AWD springs.
- Most effective handling mods
- factory brake with aftermarket rotor
- Suggestions for Springs (Lowering)
- worn out brake pads
- Brake Dust TSB - Inspection First before Pad Replacement?
- F Sports suspension vs. OEM Sports Suspension
- going with tein s-techs
- e-brake feel loose - IS250/350 -
- tein S. Tech anyone?
- ~Megan LP Series Coilover on the Way~
- AWD Pics (lowered/wheels)
- Camber kit?
- where can i purchase....
- Can anyone rate BSI?
- Got my Tanabe Coilovers...PICS!
- RoadMagnet Springs IS250AWD
- Alignment Issues
- MEGANRACING Springs?
- New Shocks. Is it worth it?
- rear brace and sway bars
- brake pad codes
- Little help about Suspension for my IS350?
- Tein SS VS Tein CS?
- Tom's or Stoptech ??
- first mod, tanabe sustec pro 5
- Clunk noise.
- New brake pads after 14k miles?
- Eibach
- ~how come~
- Brakes TSIB/Rear Mirror
- springs vs. coilovers (springs worth it?)
- Just Installed Satified Ceramic Pads
- IS350 brakes on IS250 (searched)
- DIY Brake pads pn IS250
- Lowest i can go on 20s
- Which spring lowers the most for IS250 AWD
- 18" FT and 19" Rear staggered setup
- Does anyone know?
- Uneven brake wear? Is this normal?
- Rotors which ones?
- Regular ride height with Tein SS Coilovers
- Brake Pads: Toms Vs Stock
- ~I dont get IT~
- How Much To Install Springs?
- Eibach springs for IS250 on an IS350?
- Where can i buy these????
- Sport suspension w/ Tein SS Springs
- Which Springs?
- With all these AWD owners putting springs on their cars successfully........
- Anyone with an 08' 2IS able to get the TSIB brakepads done?
- Stock spring rate for IS250?
- H&R Sport Springs now available for the IS250!
- IS350: H&R Springs
- Best place to buy tein s tech
- I just called Eibach About AWD Springs
- Lexus wants to deny my Brake TSB recall claim!
- Where Can I get Coilovers?
- eibach pro-kit installed on my 2007 is250
- Which Suspension Do I Have?
- Questions about Eibach Pro-Kit
- newb sway bar question
- any diff. with Used or New springs?
- New Rotors & Brake Pads @ 16K miles
- Brake Covers or Paint?
- Tanabe NF210 or the Eibach for IS350?
- rotor resurface ?
- Performance / Handling which is the best springs to get
- New 08 250 - Pushes to left
- Swaybars finally available?
- Why do the Tein CS cost more than the Tein SS.....
- 06-08 IS x50 stock upper pillow mounts
- Tein H. tech vs S. tech
- I am about to pull the trigger on a set of Zeal Function XS coilovers, but........
- brake pads and rotors
- Where can you get Zeal coilovers for the cheapest price....
- Think I need to replace my brakes, at 29k?
- More aggressive suspension
- Opinions on lowering my 350 please !
- brembo rotors?
- which springs would u pick...
- Guess what cspec got in the mail today!
- Air Suspension Companies?
- bags or coilovers?
- Eibach 250 or 350 Prokit for my 350!!!!!
- Need your opinions on TSIB brakes.
- Eibach Pro-Kit vs Tein H-Tech
- Are they any write up or information on the Zeal coilovers for our cars......
- IS250 AWD Suspension?
- tsb and brake dust
- Question for you Tein CS owners that have lowered the suspension all the way
- Anyone know toruque specs for Aarm?
- modded calipers on 08 IS350?
- Tein CS Installation Question
- where can i buy tein cs coilovers???
- How long did you wait to do alignment after springs?
- Lexus F-sport Springs/Shocks, AWD Please?!
- ~Warranty on any coilover?~
- Brembo Brake Kit Anyone?
- Is250 Front right wheel bearing Assembly
- Tire wear/alignment questions
- Which Coilovers or Springs?
- have a question regarding tein cs
- ProKit Installed OEM Springs OUT! :)
- New red stuff pads in front = slight squeal.
- Road Magnet Spring?
- Tsib Brakes
- Brake dust TSIB
- Spring install - average price?
- Why is one of my front tire wear more than the other?
- I have approx. 5000 miles on my Tein CS and.....
- Brake pad DIY.....??
- Lots of JUN-TW suspension stuff on l-tuned
- Espelir Springs for the ISX50
- TOM's Advox Coilovers?
- Suspension Choices for the IS250 AWD?
- H&R Springs picture
- Anyone dropped on LMS?
- Tanabe Under Brace
- Brake TSIB Afterthoughts...
- Anyone know the Part Number for the TSIB Brake pads?
- Which springs and why?
- First Look: 2008 IS350 Brake Dust on the Liquid Graphite 18" Wheels...
- Anyone Put sway bars on their IS, yet?
- NEWS: Tanabe Pro FIVE Coilovers Released
- IS-F sway-bar on IS
- Tein CS stuck valve
- 2008 IS Recalibrated Steering
- Anyone NOT take there IS to the dealer for Alignment??
- I have never in my life driver a "sport" sedan that had as much body roll as.....
- For the spring-only owners (no coilovers), quick question...
- Any special tools for pad replacements?
- Minor Issues with newly installed Tein SS
- I want the bottom of my IS to look like this!
- Brake Dust, Its True
- HELLLP!!! jic magic coilovers..yes or no??
- Anyone try TOM's new coilovers
- I don't get how people say that the Tein CS dont go low enough....
- DIY for installing springs on 2IS?
- Only 9400 Miles and dealer says i need to replace pads?
- Tein Super Street On Is250 Need Help..
- Spring/Shock question
- Is anyone running 19"+ on SportSuspension
- The suspension section is always so slow....
- Who makes good brake pads for IS250 AWD?
- Springs for the AWD?????
- Anti Roll Kit -Is350 Sway Bar Kit
- Brake TSIB Complete - Way Better!!!
- Tein CS on the lowest setting for the front on 20s!
- today is a happy day!
- Tein H-Tech Springs
- Tein tells me that there is a new version of the CS coilovers....
- Wrong brake TSIB?
- Tein CS bump stop question...
- grabby brakes?
- Elimination of 4x4 Height
- Lexon Ohlins Fortuner Coilovers for IS350
- 250 brake tsib
- People with IS250 with X package, do you want to trade your suspension for Tein CS...
- IS350 EBC Red Stuff brakes...Where to buy?
- question about brake stuff??
- REVIEW: Tom's Rear Lower Suspension 6-Link w/ Pictures
- For all (second gen) IS300 2007 owners
- $250 to install lowering springs 2IS?
- Refinished my front brake calipers today
- Sessions/ Aimgain
- Teaser: Tom's Rear Lower Suspension 6-Link
- Wanting swaybars anyone?
- I have a couple tuning questions about my Tein CS and also a writeup.....
- [ask] Swift Springs For Is250/350
- If I drove home with the ebrake on, what if anything did I damage....
- Does anyone use Ceramic brake pads?
- tanabe sustec pro five VS Tein CS ride quality
- TSIB brake squeak question...
- What can you tell me about eibach springs
- Tein SuperStreet Damper w/EDFC installed PICS!! 56k gtfo
- need help from Tein CS owners expertise...
- Clicking noise from rear end when going over road dots with Tein CS....
- Worth spending $1300 on TOM'S front/rear brace and lower suspension???
- Springs? Or would I need coilovers?
- adjusting coilovers?
- Strut bar worth it?
- Megan Racing and Ksport Coilovers
- ING's Body Kit Problems
- Pics of Tein CS and Black MMR installed....
- Well I got my car detailed, finally.....
- Eibach not making sway bars for IS250
- SUPER STREET tein coilovers need help..
- Will adding sway/strut bars and front/rear braces improve steering (more firm)?
- Questions about camber/lowering
- Car Pulls to the Right
- LX-SPORTS Suspension System
- I had the Brake TSB done, but nothing is different....
- Tein CS drop questions
- Leaking shock
- Eibach = kinda disappointing
- EBC green's....250 part number?
- To do the brake TSB or not....
- Suspension & overloading ..stupid Question
- Anyone buy H&R Sport springs for the IS250??
- brake tsb (where to go in CA to get it done)
- DIY...Lower Your ISx50
- Tein CS adjustment?....
- Wheel bearing damage?
- Brake Pad DIY easy??
- I got my new brakes for the TSIB and WOW....
- Front left noise?
- Dropping and Camber/Toe
- What do you think of the updated brake pads
- Suspension Question
- Did they replace your rotors with the brake TSIB?
- [NEW] Tanabe Sustec Pro Five for IS250 and IS350
- GS350 springs on IS350?
- Tein CS - Noise in front left suspension
- supra tt brakes
- I just put Tein CS on my IS350
- After almost a week of driving on my eibachs...
- Supra tt brakes for is250 or 350?
- Has anybody heard anything yet about someone coming out with aftermarket shocks......
- Has anybody ever put eibach IS350 springs on an IS250.....
- Just put the eibachs on my 250......
- **Please help with dealer service department**
- Which springs?
- IS250 AWD on eibach pro kit
- Question about lowering my IS350 Sport
- Are the bumpstops on an X package different then the luxury package....
- Eibach Pro + 4 adults in car = bottom out?
- Bump Stop?....
- IS350 brakes painted with "Lexus" caliper decal
- Lowering Spring DIY
- Has ANYONE installed lowering springs themselves???
- Opinions needed, Tein CS or Tanabe Sustec Pro FIVE
- H&R Springs
- hey i need help asap coilovers or springs
- Which Springs?
- Need you expert opinions
- Tanabe Sustec Underbrace
- Well I ordered my eibachs for the 250 today from....
- Tirerack has a 3 week back order for eibachs....
- Question About TSIB Brakes
- Brake TSIB (Last Question)
- Brake TSIB story
