Power Brake Booster
Old Feb 29, 2020 | 12:54 PM
madridm's Avatar
madridm
Default Power Brake Booster
I have a 2007 IS350 3.6L 6 cil. The power brake booster is slowly losing vacuum, I replaced the check valve and grommet with no luck. I am guessing the power brake booster has a leak and need replacement.
Is any way to remove and replace the power brake booster without removing the ABS actuator and pump assembly? I am trying to prevent doing extra work removing the lines and bleeding the system, plus I am not sure if I need to plug it to a computer for any type of calibration.
Any feedback will be appreciated.
JohanH
RX - 1st Gen (1999-2003)
Oct 26, 2022 12:35 PM
JBrickey
Suspension and Brakes
Oct 10, 2019 10:10 AM
hsmac
Dec 30, 2016 12:54 PM
chinzoo
Aug 31, 2007 08:29 AM
