BRAKE Fluid
Old Dec 23, 2019 | 02:49 PM
MikeFig82's Avatar
MikeFig82
Default BRAKE Fluid
I flushed out my brake fluid a few months ago. Decided to try the Wagner 5.1 break fluid for a change. My question is that it's already turning an dark amber color rather quickly. I normally use the dot 4 valvoline years back. The color is almost rather clear always. With the 5.1 I don't see, or feel any issues with it so far. Just wanted to know the charecteristics of the fast color change was due to contamination or is this normal? I normally just flush out the brake fluid out once a year or so.
Old Dec 23, 2019 | 03:59 PM
2013FSport's Avatar
2013FSport
Specifically what brand and type of Dot 4? Mixing with mineral-oil and silicone-based brake fluids or DOT 5.0 must be avoided. Observe the vehicle manufacturer's change intervals.
I try to pick a brand and type and stay with it as it is nearly impossible to remove all traces of the old stuff. That said, it almost seems like an interaction if it was clear when installed. Any reason for the switch, or just because?
Old Dec 23, 2019 | 04:53 PM
MikeFig82's Avatar
MikeFig82
Yeah I was just looking for a higher boiling point fluid. 5.1 is not silicone compared to DOT 5. I did run about 1.5 liters of the new 5.1 all it took was about one. I'll stick to the 5.1 as of now as I see no issues just the color change.
Old Dec 24, 2019 | 07:30 AM
Gville350's Avatar
Gville350
From my readings alot of folks say that "5" is more viscous with the factory rubber brake lines and eat them away...hence the quicker discoloration of the fluid. Literally, it's the rubber lines breaking down.
Old Dec 24, 2019 | 07:32 AM
MikeFig82's Avatar
MikeFig82
https://blog.amsoil.com/dot-3-and-do...he-difference/
Old Dec 26, 2019 | 09:06 AM
Gville350's Avatar
Gville350
Well now, there's 5.0 and 5.1 brake fluid? LOL! Learn something new everyday. Looks like 5.1 is compatible, but 5.0 is not.
Assuming the OP has true 5.1 fluid, then there shouldn't be any compatibility issues.
Old Dec 26, 2019 | 11:04 AM
MikeFig82's Avatar
MikeFig82
Well this morning I was looking for my tire pressure gauge. I found some leftover 5.1 brake fluid, and I peeked inside the bottle. It has a slight orange tinge to it as well. I just can't remember if it was clear when I first poured it in. Looking on my RockAuto purchase history it been about 6 months now.
Like I said I have no issues with it just that it's an amber color now.
Using Valvoline DOT 4 for many years it would still be clear for the same set period of time.
robd88
Jul 6, 2019 04:19 PM
johnnyreno
Jul 23, 2014 09:10 PM
PlotPoint
14
Jan 20, 2013 02:39 PM
RAMAIR
Oct 11, 2011 10:23 AM
LS430Lexus
Jun 2, 2011 01:20 PM
