Okay to mix Bridgestone tires? Potenza RE760 & S-04
I’d posted this in the Tires/breaks forum but I guess no one really checks that forum so I thought I’d try here....
I bought a used 2009 IS 250 a little over a month ago. After my mechanic checked it out, his comments were that I would need brake pads in a few months and that the front tires weren't in as good of condition as the rear (and also that I picked a great car, so yay me).
After reading up on this forum and other places, I think I'm gonna go with Akebono brake pads, and the Bridgestone Pole Position S-04s.
Currently, I have the Bridgestone Potenza RE760 Sports (I have OEM 18'' wheels, so 225 front, 255 back). Would it be a problem to get just two front tires now, so the S-04s in the front, and keep the RE760s in the rear? And get two S-04 rear tires in about 6 months or so? Or will I royally eff **** up.
I'm currently experiencing "tramlining" which is a new thing I just learned, when going under 50mph on surface streets. I haven't experienced it on the freeways, but LA roads aren't known to be the best. The slower I go the worse it is. I think this is due to the RE760 Sport tire, and the fact that they're coming to the end f their life. If I'm not right about what is causing the tramlining (it clearly follows bad grooves in the road, on smooth roads the wheels don't pull in either direction) - then please inform me. I'm still learning about all this stuff. Thanks in advance!
Totally fine to mix tires. I had dunlop rears and perelli p zeros on the front. On the other issues , I have no idea.
No problems mixing tires as long as the diameter is all around. You could put tractor or tricycle tires on it and as long as the dimensions are identical, there should be no problem.
