2010 IS250 suspension noise
Hi all, new to the thread but have always used as a resource. My 2010 is250 is making a noise whenever i go over bumps as well as when I hit the brakes. The sound is a loud pop/clunking noise coming from the front suspension. Any thoughts would be helpful? I took to a shop who said all the suspensioncomponents seemed ok.
My car is doing the same thing as well. I read that it can be a result of a bad lower control arm (LCA). I’d recommend using liquid dry lube and go from there that’s my plan. Good luck!
I had front suspension noise for a while, couldn't figure out what was wrong. Finally took it to my mechanic. He checked and serviced the brakes. Apparently the front pads were sticking and making clunking noise.
All is good, no more annoying noise!.
Was the pop/clicking noise after taking off at low speeds and hitting the brakes? I get that noise but never at high speeds or after been driving the car for a while. I do hear a clunk noise when I hit a bump sometimes but that's different from the pop I hear in the driver side only.
Ornitier
05-13-18 02:49 PM
