Uneven ride height
I recently installed an Tanabe axle back exhaust on my IS250 and I noticed rubbing on my rear driver side passenger fender. It never used to rub before installing the new exhaust so I'm thinking does the new exhaust really make that much of a difference in weight? I've tried readjusting the coils, resetting spring preload, and raised them up a bit from when I first got the car but still rubs but not as bad after raising it up. I've read that the IS250's sit uneven like that from stock somewhere but just trying to see any other possible causes. Was thinking maybe it needs an alignment and camber adjustment or maybe possibly a dead shock? Any advice would be greatly appreciated, thanks!
I find it hard to believe that an axle back would cause rubbing. The stock axle back is heavier than the Tanabe, so there's no reason it should cause rubbing if you're losing weight. Something has to be coming in contact underneath the car.
If you can, post a pic of your car so I can see how low you are. Because I was maxed out on BC coils on 9.5 wide wheels and never rubbed in the rear, even with beefier tires.
I'm talking about tire rubbing.
hihelloray
Performance
15
Sep 20, 2018 08:06 AM
