Might be a dumb question
So I'm getting uneven tire wear, sloppiness and the boots are shot on my front strut mounts.
Also not sure if it's related but I've gone through 2 sets of sway bar links in 20K miles.
My IS350 has 190K time for struts.
Not looking to lower it but I do like on/off ramps to make a bit of tire noise so an upgrade would be ok.
My question is that when I look at replacement struts like the KYB units like the 551130 / 30, they look like what I have with the upper and lower mount.
The Tokico units HX3797 / 8 look similar but the lower end does not have the mounting loop and bushing.
is there a lower mount kit that needs to be added like the upper mount kit?
I plan to get upper mounts and lower spring cushions and reuse the springs.
Thanks, Lex
Thanks, Lex
Our cars use shocks btw. With that being said , Tein has released two new shocks:
Endura pro ( non adj) and the Endurapro plus ( 16 way adjustable). I was looking at these for my car but I’m buying BC coilovers instead. But these may be a great option for you since you can adjust the firmness. 470.00 from ebay.
Also look into new front bushings: figs, rr racing , or RCF
Thanks for the reply bbaugher47 but that doesn't help explain why one shock has the lower mount loop and the Tokico doesn't. Maybe it's just a stock picture and isn't the actual IS350 unit.
Dan
Dan
You’re correct. The image will often state that it is for illustrative purposes only.
Tokico made our OEM shocks. Both are great.
I think the tokiko doesn't have the "mounting loop and bushing" you're talking about because it might be for the AWD version for our cars. Since there's a CV axle up front, there's a C bracket that connects the LCA to the shock instead of going straight down and connecting to the LCA.
FYI, I went with the KYB shocks and KYB upper mounts.
$88 for each shock and $50 for each mount at Rock Auto, took about 3 hours start to finish. Swapping springs took the majority of time cuz my compressors can't be spun with an impact wrench and have to be run by hand.
