Courtesy Door Light Won't Work
Old Feb 26, 2018 | 02:38 PM
akoster's Avatar
akoster
Exclamation Courtesy Door Light Won't Work
So a while back I replaced my courtesy door lights with LED bulbs. The one on the driver's side works great, but the one on the passenger door doesn't anymore. I bought a replacement light and it didn't work either. I checked to make sure there wasn't a blown fuse and the fuse look fine. What could possibly be the issue? My guess is maybe is something with wiring?
Old Mar 10, 2018 | 03:48 AM
Texas149's Avatar
Texas149
Did you try fitting the LED bulb in the holder the other way around also. LED bulbs are polarity dependant and I am guessing that the one that works you put in the correct way around and the one that don't/didn't was the other (wrong) way around. Unless it is indeed faulty and there is probably a high chance of that with a mass produced unchecked Chinese product.
idealy the power should be OFF when replacing bulbs to eliminate the chance of a voltage spike, so when installing into this posistion ( door courtesy lights) the only way to power off would be to find the fuse for that circuit or dis-connect the battery because having the door open switches the power on! And I guess it would be a bit difficult changing the bulb with the door closed!!!!
if you suspect wiring then fit the bulb that you know works from the other door ( correct way round) to see if it is the wiring or bulb at fault.
Old Mar 10, 2018 | 09:55 AM
sinister2c's Avatar
sinister2c
Try swapping the whole light assembly between doors. Those courtesy lights are a pain to take apart to swap bulbs. I'm just guessing cheap China LED bulbs. I've had many start flickering after a while.
NotFasty
Dec 17, 2018 12:57 PM
my1s250
Oct 21, 2012 12:11 PM
NickawdIs
Aug 14, 2012 11:17 AM
Ciege
RX - 3rd Gen (2010-2015)
Mar 19, 2012 09:16 AM
wcoastls
May 14, 2011 09:09 AM
