Mark Levinson problem
Old Mar 23, 2018 | 06:22 AM
Toddski's Avatar
Toddski
Default Mark Levinson problem
I had like 3 speakers go out at once. I think I lost some channels in the amp but I was wondering if a fuse could of blown? Does anyone know where the fuse box is at and possibly a link to access it? Thanks
Old Mar 26, 2018 | 12:45 AM
whitebeast's Avatar
whitebeast
Your problem is not release to the fuse cause if the fuse is blown then you won’t have any sound at all.
As for your matter, it could be amp going to be bad (which is really rare) or the speaker itself failing (especially center speaker and SUB)
if I were you, I would rather check the speaker itself than thinking about about failed amp!!!
Good luck!!!
Old Mar 26, 2018 | 11:07 AM
Gville350's Avatar
Gville350
Check the area around or under the amp for moisture. Unfortunately over time it is becoming increasingly common for our amps to get moisture damaged.
Denvergal
Aug 20, 2018 06:06 PM
swong46
Feb 22, 2011 10:55 AM
projekt
GS - 1st Gen (1993-1997)
Apr 24, 2010 07:24 PM
KrazeMatik
Sep 22, 2006 09:34 PM
Koma
Jul 12, 2006 06:42 AM
