Having some problems with '06 IS 350
Old Apr 4, 2018 | 09:33 AM
dserban's Avatar
dserban
Default Having some problems with '06 IS 350
I have 140,000 miles on this car. It runs good but I noticed a couple of things:
In certain conditions, the wheels skid and a yellow light in the right bottom corner comes on. It goes off fast though.
Making a hard turn, there is a sound coming from the front of the car. Is like metal rubbing on metal.
When driving it seems the car is not stable. My mechanic says it doesn't need an alignment.
My wife, who drives the car most of the time is getting worry.
Any ideas?
Old Apr 4, 2018 | 09:39 AM
wickedik's Avatar
wickedik
Maybe you are driving too fast and the vsc is engaging and preventing you from spinning out. Try driving more safely.
other than that, more info would be required.. are your tires bald? is your car lowered?
Old Apr 4, 2018 | 09:46 AM
Zmon's Avatar
Zmon
If your wheels are skidding, you're either taking off too quickly, your tires are junk, or your tires are low on tread. Never had a problem with that on my Michelin Pilot Sport A/S3+'s except when I let the tread wear down (4/32 or 3/32 iirc). Colder conditions will also affect all-season tires, they'll be more likely to skid when they usually don't at warmer temperatures.
Check your struts for leaks, check CV boots, check sway bar links. Chances are, at 140k, if you've never replaced any suspension components, there's a good possibility of some of them being bad.
Old Apr 4, 2018 | 09:57 AM
dserban's Avatar
dserban
The tires are Michelin Pilot and still good thread on them. The car is not lowered and I did not change any suspension components on it.
Old Apr 5, 2018 | 06:31 PM
Kingdom934's Avatar
Kingdom934
Metal to metal under load turns, I would inspect with the wheel off. Maybe a brake pad shim might be rubbing or the dust shield might be touching something as things heat up.
You mention it does not seem stable. Does it seem like it wanders. Does it do it on uneven road condition? Turns? Does the car drive straight when on a flat even highroads? Any excessive abnormal wear on the rear and front tires?
Old Apr 5, 2018 | 08:03 PM
dserban's Avatar
dserban
I noticed on the freeway but the car keeps the straight line. Is hard to describe. I don’t see any abnormal wear on the tires. They will need to be changed in about 10k miles.
Old Apr 6, 2018 | 08:01 AM
Bichon's Avatar
Bichon
Metal scraping noise could be the disc brake dust shield.
When you say it feel unstable, do you mean tramlining (i.e., where the car tends to follow ruts in the road)? Do you have the OEM sized wheels and tires?
Old Apr 6, 2018 | 09:07 AM
dserban's Avatar
dserban
I bought the car used six years ago. I did change the tires since and I think the wheel are OEM. And yes, your description sounds accurate.
Old Apr 6, 2018 | 12:09 PM
Kingdom934's Avatar
Kingdom934
Hmm...
It could just be due to worn tires. I can't remember when I ran worn tires where the road ruts would tend to be felt more in the wheel. Higher tire pressure might give more road feel as well.
If the tires are near the wear bar line, it wouldn't be a bad idea to replace them. Also, possibility the TPMS sensors too while your there.
Old Apr 11, 2018 | 07:26 PM
dserban's Avatar
dserban
I have an update. My mechanic says it needs shocks and struts.
but $1,300 is a little much
Old Apr 11, 2018 | 07:47 PM
Kingdom934's Avatar
Kingdom934
That price seems to be an average price. At least when compared around to a independent shop. It'll be cheaper if you DIY of course.
Old Apr 11, 2018 | 08:00 PM
zguy57's Avatar
zguy57
Other than tires, what would cause that wander on uneven/bumpy roads that you speak of? I haven't had my 350 long and I feel like it does it really bad sometimes although I have adjusted to it.
Old Apr 11, 2018 | 08:13 PM
Kingdom934's Avatar
Kingdom934
This doesn't apply to the IS350/250, but my other cars with dead/ very weak shock absorbers/struts, the tire sometimes feels like it's 'hopping' off the ground under rough roads which leads to stability issues. Wouldn't be a bad time to inspect the shocks to see if they are leaking more so since a lot of the 2IS are getting to that 10 year mark with over 100K miles.
Tire pressure can also affect the feel as well. Higher inflated tires might give you more feedback than say lower inflated tires. I tend to go on the higher side, but follow what the door panel says, which is about 36/38 I believe?
Old Apr 11, 2018 | 10:14 PM
dserban's Avatar
dserban
The question now are other problems going to surface or is better to trade it while is worth something?
Old Apr 12, 2018 | 07:34 PM
StanleyR's Avatar
StanleyR
The longer you leave the problems, the more you'll damage other wheel and suspension components.
You'll mostly sacrifice your safety.
e-man
Jan 12, 2020 08:05 PM
MrParis
Dec 6, 2014 11:17 AM
rvkbj2345
Wheels, Tires & Brakes Forum
Jan 21, 2014 07:18 AM
sonyman
Jun 9, 2006 06:08 PM
DjXquizit
Aug 15, 2003 05:10 PM
