rear strake clips
Subscribe
Mar 6, 2018 | 04:21 PM
anyone know what the part number is for the clips the hold up the rear strakes?
rear strakes are those little flappy pieces of plastic/urethane that keep air moving around the tires (see image circled below). the front has them too.
if not, is there a good website you guys use to see blow up parts? sewell used to be a good source...
Reply 0
Mar 6, 2018 | 04:23 PM
I got these from the auto parts store.
https://www.clublexus.com/forums/is-...eflectors.html
Reply 1
Mar 6, 2018 | 10:36 PM
I ended up putting a clip into the hole and screwing a 10mm #12 OEM screw in there same type of screw that hold front lip. I only did it for one of the two. Other one is still OEM clip holding strong for 10 years.
the OEM clip is same as these on Amazon...
https://www.amazon.com/uxcell%C2%AE-Fender-Retainer-Bumper-MR200300/dp/B00NQBARLM
Reply 0
Mar 7, 2018 | 06:54 AM
I don;t really know the part number but you could try using 3M double sided tape after cleaning the area very well or try zip tying it up
Reply 0
Mar 7, 2018 | 09:22 AM
perfect thanks guys!
double side will probably not work for too long due to the wind and dirt. zip tie is my last resort.
Reply 0
Mar 7, 2018 | 10:07 AM
are those important to have? i dont think mine has those wind deflectors.
Reply 0
Subscribe
