IS350 Blank Screen
Old Feb 16, 2018 | 09:18 AM
wickedik's Avatar
wickedik
Default IS350 Blank Screen
Last night while I was driving home, my nav / audio / climate control screen froze. The audio stopped, the AC remained on, and the screen went blank. None of the physical buttons on the unit did anything when pressed either. The car drove fine other than that. When I got home, I shut the car down, and restarted it and everything was fine and back to normal. Has this happened to any of you ? Is this something i should be concerned about?
Old Feb 18, 2018 | 02:14 PM
whitebeast's Avatar
whitebeast
You should check your alternator. Also check on map to see if it is working normal
Old Feb 19, 2018 | 04:39 AM
UnderCover's Avatar
UnderCover
Eh, **** happens sometimes. I once just pulled out of my garage and every single dashboard light came immediately at once...just turned it off and back on, no problems since and that was like a year ago. If it occurs a little more frequently I'd be worried.
Old Feb 19, 2018 | 07:14 AM
mcomer's Avatar
mcomer
You can reboot the system while driving by pressing and holding the Volume/On/Off button in for
a couple of seconds. Same effect as turning off the car and restarting it but available while driving.
Old Feb 20, 2018 | 01:39 AM
wickedik's Avatar
wickedik
ok now there is a different issue, everything works fine except i can't access the cd changer ( which is how i connect to my vais iPod interface). which i press the disc/aux button, it only lets me access the aux. my car is an 06 is35 with ML. any ideas on how to fix it?
Old Feb 21, 2018 | 02:42 AM
wickedik's Avatar
wickedik
thanks guys, i figured it out. had to unplug the aux cable out of the armrest and it works now.
momtogrif
Jan 21, 2021 02:14 PM
colfax
Mar 2, 2019 07:09 PM
bryan11
Aug 1, 2018 11:12 AM
2SwiFt29
Mar 14, 2008 01:45 AM
doug_999
Nov 10, 2003 04:23 PM
