A/C blower not working, 97 es300
I started the car the other day in a cold morning and all of a sudden the air wouldn't come out at all
the little bars are on full force but nothing...when I play with the settings ( top, top/bottom/, floor ect..) I can hear a small noise, like somthing mechanically trying to work
You need to check for 12 volts at the blower motor when you turn the fan on. It's located under the glove box and you don't have to remove the glove, just remove the black plastic trim cover and you will see the blower motor.
Originally Posted by el gato
after locating it, what do I do?
I have this same exact problem, though unfortunately it has not turned on by itself like for gato. I've tried the diagnostic check for the A/C. Seems to be no problems there. Does anyone know which exact fuse or fuses to look at before I attempt to check the blower motor unit itself? It has been like this for several weeks now as I've been procrastinating on trying to fix this myself.
gtstcactus
04-19-15 03:18 PM
hoonami
02-13-10 07:08 AM
btgt570
06-11-09 10:00 AM
