2001 GS300 O2 Sensor Problem
Old Feb 13, 2005 | 02:05 PM
Mac851's Avatar
Mac851
Default 2001 GS300 O2 Sensor Problem
When my engine check light came on I went to Auto Zone for a code reading. The code reader indicated #141. I was told this is an O2 Sensor problem regarding Bank 1 Sensor 2. The 2001 GS 300 has 4 sensors and 2 catalytic converters. Has anyone had this same problem and know exactly which sensor needs to be changed? I plan to change the sensor myself. Thanks.
Old Feb 15, 2005 | 01:16 PM
Jet's Avatar
Jet
the code you have should be P0141 which is bank1 sensor 2 heater circuit malf. its not a big deal the sensor just need to be replaced, the sensor should be the one after the cat. on the exhaust manifold that collect exhaust from cylinder 1,2 and 3.
Old Nov 12, 2005 | 11:03 AM
asci01's Avatar
asci01
Could someone tell me the part # for the O2 sensor heater bank 1 sensor 2?
Car: 2000 GS300
Old Nov 12, 2005 | 01:50 PM
VVT-i's Avatar
VVT-i
Car: 2000 GS300
Jet is correct and very clear on the location of the B1 S2 sensor.
If you look at the sensor real close you will the part # stamped on the sensor.
Old Sep 30, 2006 | 04:48 AM
p4ult's Avatar
p4ult
Which is bank 1?
is it near the front of the engine bay (radiator end)?
or
the rear of the engine bay (fire wall end)?
Thanks
Paul
Old Sep 30, 2006 | 06:46 AM
VVT-i's Avatar
VVT-i
Originally Posted by p4ult
Which is bank 1?
or
Thanks
Paul
Bank 1 on the GS300 is the first three cylinders front of the engine bay ( 1,2 and 3). Sensor 2 is the sensor after the catylst convertor.
You will see one sensor located in front of the cat. that is bank 1 sensor 1. Another sensor after the cat. is bank 1 sensor 2.
Old Sep 30, 2006 | 09:22 AM
p4ult's Avatar
p4ult
Your a star, thanks dude
Is this the one you mean?
Ziliton
Feb 11, 2017 02:35 PM
cockerel1
Jun 3, 2014 08:22 PM
swat1727
Aug 23, 2009 12:43 PM
kingof901s
Jul 23, 2009 11:22 AM
swat1727
Nov 2, 2008 10:29 AM
