- Sad morning for the SC400....
- Importing SC
- Must act fast: someone will know y/n answer
- Burnt connector...
- can i see some green sc's on aftermarket wheels.
- Some Rare FRP and Carbon Fiber Hoods for the SC300 / SC400 / Soarer
- How much are these wheels?
- One new picture of my 97 SC300
- Gold on gold?
- AC problem/overheating
- A/C fan/thermostat not working
- The latest of my insanity, home made hood!
- red fluid leaking
- income tax time
- the many faces of my car.. now time to sell..
- DTC code 25 and 41 on 1992 SC4
- 99 SC300 for $6900, good buy?
- 03 gs radiator fit in sc
- How to turn on stock amp in 95 sc300
- Snow storm Chicago!!! Some pics.
- Clutch what type?
- 97+ rear bumper extensions
- Electrical Issue? Can't diagnose.
- nor cal meet! if you sc guys havent seen it sign up asap! 40+ cars..
- K&N air filter ?
- trunk pop lock alarm possible?
- Whats the correct way to install a FRONT MAIN SEAL?
- HURRY!!! please help with photoshop!
- fuse blowout??
- passenger side door outer B pillar
- HELP! 03' IS300 manual ecu swap into a 00' sc300?
- Is this 92 sc400 worth $3900? help a brother out thanks.
- Needing a link or website
- 1jz swap time ALL INPUT NEEDED
- rear bumper or wheels?
- Metal Radiator VS. Aluminum
- will these fit??
- which color wheels
- Suggestions for best aftermarket shortshifter
- a/c control unit.
- HID Advice DDM Tuning
- am i missing a lot of stuff for my steering wheel?
- which rear speakers??
- Bulb # for Climate LCD Screen
- 1jz swap idle/turnin off problem
- Automatic Lights
- The SEM experience
- Just Picked Up A Sc300, And Good Ole Minnesota Weather Challenged Me With A Guard Rai
- My Car Got A BooBoo!
- 4runner dizzy on sc300
- identifying bad LCA
- Some Pics from the Philadelphia Auto Show.
- Interior: Teaser.
- On the topic of 315s
- rare 1jz
- Opinions on this turbo kit?
- JDM Soarer Questions
- 1j/2j turbo single w/ Catalytic Converter? in CA
- Common driveshaft length?
- Anyone on B&G lowering springs?
- Red, Black, and White Unite!!! SC-Shoot (pic HEAVY)...
- Selling Black housing headlights.
- where can i buy stock 1jz twin turbos at??
- who wants to help me with my 1jz swap FL!
- doing a 1jz swap on my sc300 question
- DIY SC400/300 High Beam Refinishing
- DIY red out taillights how
- which wheel??? i cant decide!!!
- lots of grinding in the rear.
- LED tailight bulbs
- what kind of wheels are these on my sc?
- High beam refinish
- fed & canada vs. ca
- Rolling shot! fap fap fap
- need some knowledge
- will the sc400 run without a fuel pump ecu? fuel pump harness is bypassed.
- Fender Rolling Tool, Anybody Ever Heard Of Or Tried This Kind?
- what are your guises top speed?
- NEED HELP!! No power coming to the stereo.
- Time for new cat's does anyone know any that are aftermarket CA legal?
- strange battery problem
- Supra Tanabe Shocks+Springs
- quick question.. installing coilovers as we speak
- The Soarer Story-Documentry
- Need wire diagram and pinout schematic for Soarer harness
- gas variety.
- differant answers
- crank pully diameter
- $550 turbo kit for sc300
- new member, first lexus
- Hello Sc owners, need some opinions about keyless ignition start system
- Local Tampa SC400 guru needed for hire
- 18 245 45..or..18 225 35
- I use tac cloth to wipe my car
- 1JZGTE, NA-T 1/4 and 0-60
- Went on a mini shoot today
- Two of a kind
- Cutting my springs.
- curious pic request??
- TRAC problem.
- 1JZ wire harness body plugs questions
- 2000 Lexus SC400 offfers??
- I just put these wheels on my LEX
- rough idle after na-t install help
- what is causing this?
- smog test results-failed again PLEASE HELP
- odd power steering issue?
- Exhaust / Cat question on my 93 SC4
- First time buying rims; need CL's help.
- good deal????????????????????
- color?
- Aftermarket or Modified Steering wheel!
- Yota Pickup w/ Supra Motor
- am i doing something wrong??
- Braking problems
- To Everyone Who Has The LS400 Brake Upgrade, What Pad and Rotors Are You Using?
- sem and oem black match?
- Input on these 2 set of rims
- Washe Nozzle Upgrade
- seafoamed sc4 now throws cel... code 13
- Decent parts dept in Bay Area?
- first motor pull !!! any tips?
- Whats the easiest way to drop in a motor-JZ??
- Where does this go from the FUSE BOX, + or - battery??
- Bluetooth microphone placement in your SC...
- my car glows! :o
- new owner of 92 sc400
- sc300 c-arms help!
- central to southern CA coast tuners?
- Sometimes you just have to laugh
- Quick photoshop at work...
- Soarer JDM OEM Parts?
- 19x8.5 offset30 19x9.5 offset15
- My NEW Toy!!!!!!
- Help! Sc300 trac control!!!
- SC400 differential, What fits?
- How much did you pay for your SC ?
- 1JZ- HELP identifying this PLUG?
- quick suspension question
- R154 Replacement Synchro Problem
- Proud new Papa
- Center Console - Rubber Coating
- Thinking about picking this up.
- SOS please help, tape stuck on sc deck wont stop
- rear emblem removal residue
- Saw this sc listing
- is300 2003 steering wheel.
- supra tt calipers fit??
- Has anyone ever used the carbon fiber film on the side of your front windows?
- Autoshine kit with 18's?
- love junk yards.
- 1992 sc400
- getting rid of my sc4 for a ....
- Headlight adjustment
- auto to manual conversion of 95 SC300
- san diego fender roll
- Will these wheels fit?
- '95 sc400 and part# for earl's solo bleeder screws?
- speed question
- Puddle Light info and Pics Thread
- Steering Wheel Compatibility
- What to look for in used SC
- HX35. Trying to do it right.
- ANY ONE know a good place in Fl for 1jz swap into sc300
- Japanese Vs US Headlights?
- Pictures From 2010
- why i dont let other people work on my car(s)
- Need Help, car shaking after tps fell off.
- Sc 300 MPG Improvement!!!!!
- (Simple) Supra suspension question....
- Favor (99 SC400) fuse/relay picture
- No heat its freezing wtf? Helppp!!!!
- Opal White to Royal Sapphire Pearl
- Need help with AMP
- cuts off at stops
- T3/T4 turbo.. sc400
- throttle body part
- Sc400 Boggs, now will not start.
- New owner of 92 SC400, have questions
- a rethink on fender mods...
- Red 98 Sc300 on MA 128/95 today??
- jdm A/T ecu and harness on w58 M/T question
- How much more is a SC with a stock W58 worth compared to an auto??
- Video - Some SC400 shots... 1uz stuff.. etc..and alien voices!
- is my engine healthy??
- Look at the Wheels
- White 1997+ SC300 w/ XXR Wheels @ Cars and Coffee
- Miles on half a tank...
- Topspeed Pro 1 exhaust installed pics
- intercooler size and piping question?
- possible trade
- Vertex Rep Sides and Rear
- Coincidence or what? Thought I would share!
- Idle problem
- Dead SC300 :(
- full tank of gas.
- riding on 285 then this threads for u
- Does this look right? Serp belt tensioner too close to PS pulley
- what side is what on 97+ side skirts and body filler question
- O2 sensor
- battle version rear end installed
- w58 on 1uzfe clutch ???????????
- Shout out to Chris at wheelsdirect
- How much have you sunk in your SC?
- New transmission, or new solenoid?
- How much is a stock 5spd sc300 worth now a days?
- SC300 wiper problem
- Has anyone replaced there catalytic converter themselves?
- 92 SC300, GTE, 72MM, E85. The story.
- Anime Soarer
- Aftermarket Deck - Sc400 Nakamichi Where are these wires?
- Speeding Ticket
- Wheel Situation: Redrilling, wobble bolts, adapters, etc. for 5x112mm wheel.
- What is this warning light
- Supra Tanabe Sustec Shocks
- no crank no start
- Going to pull motor out soon, need advice
- Update, My SC (Sand Storm) got new shoes
- what type of bulb and socket
- Request info/pics on W58 swap, please.
- Are the windows the same beteen the Sc400 & sc300
- Flush Tire/Wheel??
- 18's or 19's???????????????????
- Looking for an SC300, got some unique questions
- HIDs 6000k vs 8000k
- sooo....my front bumper hates me...
- photo shoot today tell me what you think?
- car dies when try to start the car???
- Speed Sensor issues?
- exhaust question, please help!!!
- Time for wheels...
- Timing belt time #2
- Soarer sighting in music video
- Chinese quality
- 95 sc400 how safe is it to get the subframe
- new tps sensor no difference...
- 95 sc300 hottttt!!!
- sc turns off for quick sec. then turns back on
- Man...did i mess up?
- Will a MK3 Supra power steering pump work for 1JZ swap
- spark plugs
- Oil Feed to turbo on a 1.5JZ??
- union bolt
- Carbon fiber help
- Code 27 write-up DIY diagnosis and repair SC300
- Help with strut/spring question
- New paint =)
- Need your advice: Would YOU spend this $$
- My power steering is acting strange
