quick question.. installing coilovers as we speak
Old Jan 29, 2011 | 09:41 AM
cheez's Avatar
cheez
Default quick question.. installing coilovers as we speak
wut do i do about the sway bar links? theyre too long to fit back after i put in the coilovers
Old Feb 27, 2011 | 06:31 AM
tray50z's Avatar
tray50z
install v-tach
Old Feb 27, 2011 | 06:58 AM
SH_JZZ30's Avatar
SH_JZZ30
They should fit easily. What coilovers are you running btw?
Old Feb 27, 2011 | 07:13 AM
t70 supra's Avatar
t70 supra
never had this problem i unhooked mine but most links are fried i would replace them when u have them out
Old Feb 27, 2011 | 07:45 AM
SChema's Avatar
SChema
You may have to adjust the ride height (lowered) after you bolt up the link. May not have enough room after the control arm is compressed a bit.
On a different subject matter. Does anyone's links pop going into corners or over bumps? I'm not slammed but down to about a finger gap. I'm thinking the lowered height is causing my links to bind. I thought about purchasing shorter ones to see if it cures the problem or not.
Old Feb 27, 2011 | 08:26 AM
SH_JZZ30's Avatar
SH_JZZ30
Mine doesn't make any noise at all. You can try tightening the top nut of your coilovers with an air gun. Or maybe your end links are just bad.
Old Feb 27, 2011 | 09:29 AM
SChema's Avatar
SChema
Sorry for the thread jack OP.
I'm thinking the links are bad, like you said. I've unbolted them and drove around with no noise. Once they are bolted back up, they pop again. Thanks, SH.
Old Feb 27, 2011 | 09:59 AM
cheez's Avatar
cheez
i got them to fit but i get the popping sound too. but i could not tighten them all the way because they were rusted to hell. im probably gonna grind them off and put new ones. maybe that will stop the popping :/
Sc0pe
VIP Style
Aug 5, 2014 05:19 PM
daniel6155
Suspension and Brakes
Nov 10, 2010 04:54 PM
woodpecker
Apr 11, 2010 11:59 AM
johnny.h
Dec 17, 2009 03:19 PM
